Simple Broker
The built-in simple message broker handles subscription requests from clients, stores them in memory, and broadcasts messages to connected clients that have matching destinations. The broker supports path-like destinations, including subscriptions to Ant-style destination patterns.spring-doc.cn
Applications can also use dot-separated (rather than slash-separated) destinations. See Dots as Separators.
If configured with a task scheduler, the simple broker supports STOMP heartbeats. To configure a scheduler, you can declare your own TaskScheduler bean and set it through the MessageBrokerRegistry. Alternatively, you can use the one that is automatically declared in the built-in WebSocket configuration, however, you’ll need @Lazy to avoid a cycle between the built-in WebSocket configuration and your WebSocketMessageBrokerConfigurer. For example:spring-doc.cn
@EnableWebSocketMessageBroker
public class WebSocketConfig implements WebSocketMessageBrokerConfigurer {
	private TaskScheduler messageBrokerTaskScheduler;
	@Autowired
	public void setMessageBrokerTaskScheduler(@Lazy TaskScheduler taskScheduler) {
		this.messageBrokerTaskScheduler = taskScheduler;
	public void configureMessageBroker(MessageBrokerRegistry registry) {
		registry.enableSimpleBroker("/queue/", "/topic/")
				.setHeartbeatValue(new long[] {10000, 20000})
				.setTaskScheduler(this.messageBrokerTaskScheduler);
