Using the @Bean Annotation
@Bean is a method-level annotation and a direct analog of the XML <bean/> element. The annotation supports some of the attributes offered by <bean/>, such as:spring-doc.cn
You can use the @Bean annotation in a @Configuration-annotated or in a @Component-annotated class.spring-doc.cn
Declaring a Bean
To declare a bean, you can annotate a method with the @Bean annotation. You use this method to register a bean definition within an ApplicationContext of the type specified as the method’s return value. By default, the bean name is the same as the method name. The following example shows a @Bean method declaration:spring-doc.cn
public class AppConfig {
	public TransferServiceImpl transferService() {
		return new TransferServiceImpl();
class AppConfig {
	fun transferService() = TransferServiceImpl()
The preceding configuration is exactly equivalent to the following Spring XML:spring-doc.cn
<beans>
	<bean id="transferService" class="com.acme.TransferServiceImpl"/>
</beans>
Both declarations make a bean named transferService available in the ApplicationContext, bound to an object instance of type TransferServiceImpl, as the following text image shows:spring-doc.cn
transferService -> com.acme.TransferServiceImpl
You can also use default methods to define beans. This allows composition of bean configurations by implementing interfaces with bean definitions on default methods.spring-doc.cn
public interface BaseConfig {
	default TransferServiceImpl transferService() {
public class AppConfig implements BaseConfig {
You can also declare your @Bean method with an interface (or base class) return type, as the following example shows:spring-doc.cn
	public TransferService transferService() {
class AppConfig {
	fun transferService(): TransferService {
		return TransferServiceImpl()
However, this limits the visibility for advance type prediction to the specified interface type (TransferService). Then, with the full type (TransferServiceImpl) known to the container only once the affected singleton bean has been instantiated. Non-lazy singleton beans get instantiated according to their declaration order, so you may see different type matching results depending on when another component tries to match by a non-declared type (such as @Autowired TransferServiceImpl, which resolves only once the transferService bean has been instantiated).spring-doc.cn
If you consistently refer to your types by a declared service interface, your @Bean return types may safely join that design decision. However, for components that implement several interfaces or for components potentially referred to by their implementation type, it is safer to declare the most specific return type possible (at least as specific as required by the injection points that refer to your bean).
Bean Dependencies
A @Bean-annotated method can have an arbitrary number of parameters that describe the dependencies required to build that bean. For instance, if our TransferService requires an AccountRepository, we can materialize that dependency with a method parameter, as the following example shows:spring-doc.cn
	public TransferService transferService(AccountRepository accountRepository) {
		return new TransferServiceImpl(accountRepository);
class AppConfig {
	fun transferService(accountRepository: AccountRepository): TransferService {
		return TransferServiceImpl(accountRepository)
The resolution mechanism is pretty much identical to constructor-based dependency injection. See the relevant section for more details.spring-doc.cn
Receiving Lifecycle Callbacks
Any classes defined with the @Bean annotation support the regular lifecycle callbacks and can use the @PostConstruct and @PreDestroy annotations from JSR-250. See JSR-250 annotations for further details.spring-doc.cn
The regular Spring lifecycle callbacks are fully supported as well. If a bean implements InitializingBean, DisposableBean, or Lifecycle, their respective methods are called by the container.spring-doc.cn
The standard set of *Aware interfaces (such as BeanFactoryAware, BeanNameAware, MessageSourceAware, ApplicationContextAware, and so on) are also fully supported.spring-doc.cn
The @Bean annotation supports specifying arbitrary initialization and destruction callback methods, much like Spring XML’s init-method and destroy-method attributes on the bean element, as the following example shows:spring-doc.cn
public class BeanOne {
	public void init() {
		// initialization logic
public class BeanTwo {
	public void cleanup() {
		// destruction logic
	@Bean(initMethod = "init")
	public BeanOne beanOne() {
		return new BeanOne();
	@Bean(destroyMethod = "cleanup")
	public BeanTwo beanTwo() {
		return new BeanTwo();
class BeanOne {
	fun init() {
class BeanTwo {
	fun cleanup() {
class AppConfig {
	fun beanOne() = BeanOne()
	fun beanTwo() = BeanTwo()
By default, beans defined with Java configuration that have a public close or shutdown method are automatically enlisted with a destruction callback. If you have a public close or shutdown method and you do not wish for it to be called when the container shuts down, you can add @Bean(destroyMethod = "") to your bean definition to disable the default (inferred) mode.spring-doc.cn
You may want to do that by default for a resource that you acquire with JNDI, as its lifecycle is managed outside the application. In particular, make sure to always do it for a DataSource, as it is known to be problematic on Jakarta EE application servers.spring-doc.cn
The following example shows how to prevent an automatic destruction callback for a DataSource:spring-doc.cn
public DataSource dataSource() throws NamingException {
	return (DataSource) jndiTemplate.lookup("MyDS");
fun dataSource(): DataSource {
	return jndiTemplate.lookup("MyDS") as DataSource
Also, with @Bean methods, you typically use programmatic JNDI lookups, either by using Spring’s JndiTemplate or JndiLocatorDelegate helpers or straight JNDI InitialContext usage but not the JndiObjectFactoryBean variant (which would force you to declare the return type as the FactoryBean type instead of the actual target type, making it harder to use for cross-reference calls in other @Bean methods that intend to refer to the provided resource here).spring-doc.cn
In the case of BeanOne from the example above the preceding note, it would be equally valid to call the init() method directly during construction, as the following example shows:spring-doc.cn
		BeanOne beanOne = new BeanOne();
		beanOne.init();
		return beanOne;
class AppConfig {
	fun beanOne() = BeanOne().apply {
		init()
When you work directly in Java, you can do anything you like with your objects and do not always need to rely on the container lifecycle.
Specifying Bean Scope
Spring includes the @Scope annotation so that you can specify the scope of a bean.spring-doc.cn
Using the @Scope Annotation
You can specify that your beans defined with the @Bean annotation should have a specific scope. You can use any of the standard scopes specified in the Bean Scopes section.spring-doc.cn
The default scope is singleton, but you can override this with the @Scope annotation, as the following example shows:spring-doc.cn
public class MyConfiguration {
	@Scope("prototype")
	public Encryptor encryptor() {
	@Scope("prototype")
	fun encryptor(): Encryptor {
@Scope and scoped-proxy
Spring offers a convenient way of working with scoped dependencies through scoped proxies. The easiest way to create such a proxy when using the XML configuration is the <aop:scoped-proxy/> element. Configuring your beans in Java with a @Scope annotation offers equivalent support with the proxyMode attribute. The default is ScopedProxyMode.DEFAULT, which typically indicates that no scoped proxy should be created unless a different default has been configured at the component-scan instruction level. You can specify ScopedProxyMode.TARGET_CLASS, ScopedProxyMode.INTERFACES or ScopedProxyMode.NO.spring-doc.cn
If you port the scoped proxy example from the XML reference documentation (see scoped proxies) to our @Bean using Java, it resembles the following:spring-doc.cn
// an HTTP Session-scoped bean exposed as a proxy
@SessionScope
public UserPreferences userPreferences() {
	return new UserPreferences();
public Service userService() {
	UserService service = new SimpleUserService();
	// a reference to the proxied userPreferences bean
	service.setUserPreferences(userPreferences());
	return service;
@SessionScope
fun userPreferences() = UserPreferences()
fun userService(): Service {
	return SimpleUserService().apply {
Customizing Bean Naming
By default, configuration classes use a @Bean method’s name as the name of the resulting bean. This functionality can be overridden, however, with the name attribute, as the following example shows:spring-doc.cn
	@Bean("myThing")
	public Thing thing() {
		return new Thing();
class AppConfig {
	@Bean("myThing")
	fun thing() = Thing()
Bean Aliasing
As discussed in Naming Beans, it is sometimes desirable to give a single bean multiple names, otherwise known as bean aliasing. The name attribute of the @Bean annotation accepts a String array for this purpose. The following example shows how to set a number of aliases for a bean:spring-doc.cn
	@Bean({"dataSource", "subsystemA-dataSource", "subsystemB-dataSource"})
	public DataSource dataSource() {
		// instantiate, configure and return DataSource bean...
class AppConfig {
	@Bean("dataSource", "subsystemA-dataSource", "subsystemB-dataSource")
Bean Description
Sometimes, it is helpful to provide a more detailed textual description of a bean. This can be particularly useful when beans are exposed (perhaps through JMX) for monitoring purposes.spring-doc.cn
To add a description to a @Bean, you can use the @Description annotation, as the following example shows:spring-doc.cn
	@Description("Provides a basic example of a bean")
		return new Thing();
class AppConfig {
