Fine-tuning Annotation-based Autowiring with @Primary
Because autowiring by type may lead to multiple candidates, it is often necessary to have more control over the selection process. One way to accomplish this is with Spring’s @Primary annotation. @Primary indicates that a particular bean should be given preference when multiple beans are candidates to be autowired to a single-valued dependency. If exactly one primary bean exists among the candidates, it becomes the autowired value.spring-doc.cn
Consider the following configuration that defines firstMovieCatalog as the primary MovieCatalog:spring-doc.cn
public class MovieConfiguration {
	@Primary
	public MovieCatalog firstMovieCatalog() { ... }
	public MovieCatalog secondMovieCatalog() { ... }
	@Primary
	fun firstMovieCatalog(): MovieCatalog { ... }
	fun secondMovieCatalog(): MovieCatalog { ... }
With the preceding configuration, the following MovieRecommender is autowired with the firstMovieCatalog:spring-doc.cn
public class MovieRecommender {
	@Autowired
	private MovieCatalog movieCatalog;
	@Autowired
	private lateinit var movieCatalog: MovieCatalog
The corresponding bean definitions follow:spring-doc.cn
	xmlns:context="http://www.springframework.org/schema/context"
		https://www.springframework.org/schema/context/spring-context.xsd">
	<context:annotation-config/>
	<bean class="example.SimpleMovieCatalog" primary="true">
		<!-- inject any dependencies required by this bean -->
	</bean>
	<bean class="example.SimpleMovieCatalog">
	</bean>
	<bean id="movieRecommender" class="example.MovieRecommender"/>
</beans>
