This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4!spring-doc.cn
Adding Custom Client Connection Properties
The CachingConnectionFactory now lets you access the underlying connection factory to allow, for example, setting custom client properties. The following example shows how to do so:spring-doc.cn
connectionFactory.getRabbitConnectionFactory().getClientProperties().put("thing1", "thing2");
These properties appear in the RabbitMQ Admin UI when viewing the connection.spring-doc.cn
