This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.5!spring-doc.cn
Changes in 1.4 Since 1.3
@RabbitListener Annotation
POJO listeners can be annotated with @RabbitListener, enabled by @EnableRabbit or <rabbit:annotation-driven />. Spring Framework 4.1 is required for this feature. See Annotation-driven Listener Endpoints for more information.spring-doc.cn
RabbitMessagingTemplate Added
A new RabbitMessagingTemplate lets you interact with RabbitMQ by using spring-messaging Message instances. Internally, it uses the RabbitTemplate, which you can configure as normal. Spring Framework 4.1 is required for this feature. See Messaging Integration for more information.spring-doc.cn
Listener Container missingQueuesFatal Attribute
1.3.5 introduced the missingQueuesFatal property on the SimpleMessageListenerContainer. This is now available on the listener container namespace element. See Message Listener Container Configuration.spring-doc.cn
RabbitTemplate ConfirmCallback Interface
The confirm method on this interface has an additional parameter called cause. When available, this parameter contains the reason for a negative acknowledgement (nack). See Correlated Publisher Confirms and Returns.spring-doc.cn
RabbitConnectionFactoryBean Added
RabbitConnectionFactoryBean creates the underlying RabbitMQ ConnectionFactory used by the CachingConnectionFactory. This enables configuration of SSL options using Spring’s dependency injection. See Configuring the Underlying Client Connection Factory.spring-doc.cn
Using CachingConnectionFactory
The CachingConnectionFactory now lets the connectionTimeout be set as a property or as an attribute in the namespace. It sets the property on the underlying RabbitMQ ConnectionFactory. See Configuring the Underlying Client Connection Factory.spring-doc.cn
Log Appender
The Logback org.springframework.amqp.rabbit.logback.AmqpAppender has been introduced. It provides options similar to org.springframework.amqp.rabbit.log4j.AmqpAppender. For more information, see the JavaDoc of these classes.spring-doc.cn
The Log4j AmqpAppender now supports the deliveryMode property (PERSISTENT or NON_PERSISTENT, default: PERSISTENT). Previously, all log4j messages were PERSISTENT.spring-doc.cn
The appender also supports modification of the Message before sending — allowing, for example, the addition of custom headers. Subclasses should override the postProcessMessageBeforeSend().spring-doc.cn
Listener Queues
The listener container now, by default, redeclares any missing queues during startup. A new auto-declare attribute has been added to the <rabbit:listener-container> to prevent these re-declarations. See auto-delete Queues.spring-doc.cn
RabbitTemplate: mandatory and connectionFactorySelector Expressions
The mandatoryExpression, sendConnectionFactorySelectorExpression, and receiveConnectionFactorySelectorExpression SpEL Expression properties have been added to RabbitTemplate. The mandatoryExpression is used to evaluate a mandatory boolean value against each request message when a ReturnCallback is in use. See Correlated Publisher Confirms and Returns. The sendConnectionFactorySelectorExpression and receiveConnectionFactorySelectorExpression are used when an AbstractRoutingConnectionFactory is provided, to determine the lookupKey for the target ConnectionFactory at runtime on each AMQP protocol interaction operation. See Routing Connection Factory.spring-doc.cn
Listeners and the Routing Connection Factory
You can configure a SimpleMessageListenerContainer with a routing connection factory to enable connection selection based on the queue names. See Routing Connection Factory.spring-doc.cn
RabbitTemplate: RecoveryCallback Option
The recoveryCallback property has been added for use in the retryTemplate.execute(). See Adding Retry Capabilities.spring-doc.cn
MessageConversionException Change
This exception is now a subclass of AmqpException. Consider the following code:spring-doc.cn
try {
    template.convertAndSend("thing1", "thing2", "cat");
catch (AmqpException e) {
catch (MessageConversionException e) {
The second catch block is no longer reachable and needs to be moved above the catch-all AmqpException catch block.spring-doc.cn
RabbitMQ 3.4 Compatibility
Spring AMQP is now compatible with the RabbitMQ 3.4, including direct reply-to. See Compatibility and RabbitMQ Direct reply-to for more information.spring-doc.cn
ContentTypeDelegatingMessageConverter Added
The ContentTypeDelegatingMessageConverter has been introduced to select the MessageConverter to use, based on the contentType property in the MessageProperties. See Message Converters for more information.spring-doc.cn
