This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4! |
Delayed Message Exchange
Version 1.6 introduces support for the Delayed Message Exchange Plugin
The plugin is currently marked as experimental but has been available for over a year (at the time of writing). If changes to the plugin make it necessary, we plan to add support for such changes as soon as practical. For that reason, this support in Spring AMQP should be considered experimental, too. This functionality was tested with RabbitMQ 3.6.0 and version 0.0.1 of the plugin. |
To use a RabbitAdmin
to declare an exchange as delayed, you can set the delayed
property on the exchange bean to
true
The RabbitAdmin
uses the exchange type (Direct
, Fanout
, and so on) to set the x-delayed-type
argument and
declare the exchange with type x-delayed-message
The delayed
property (default: false
) is also available when configuring exchange beans using XML.
The following example shows how to use it:
<rabbit:topic-exchange name="topic" delayed="true" />
To send a delayed message, you can set the x-delay
header through MessageProperties
, as the following examples show:
MessageProperties properties = new MessageProperties();
properties.setDelay(15000);
template.send(exchange, routingKey,
MessageBuilder.withBody("foo".getBytes()).andProperties(properties).build());
rabbitTemplate.convertAndSend(exchange, routingKey, "foo", new MessagePostProcessor() {
public Message postProcessMessage(Message message) throws AmqpException {
message.getMessageProperties().setDelay(15000);
return message;
To check if a message was delayed, use the getReceivedDelay()
method on the MessageProperties
It is a separate property to avoid unintended propagation to an output message generated from an input message.
