This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.5! |
Exclusive Consumer
Starting with version 1.3, you can configure the listener container with a single exclusive consumer.
This prevents other containers from consuming from the queues until the current consumer is cancelled.
The concurrency of such a container must be 1
When using exclusive consumers, other containers try to consume from the queues according to the recoveryInterval
property and log a WARN
message if the attempt fails.
