This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4! |
Using Container Factories
Listener container factories were introduced to support the @RabbitListener
and registering containers with the RabbitListenerEndpointRegistry
, as discussed in Programmatic Endpoint Registration.
Starting with version 2.1, they can be used to create any listener container — even a container without a listener (such as for use in Spring Integration). Of course, a listener must be added before the container is started.
There are two ways to create such containers:
Use a SimpleRabbitListenerEndpoint
Add the listener after creation
The following example shows how to use a SimpleRabbitListenerEndpoint
to create a listener container:
public SimpleMessageListenerContainer factoryCreatedContainerSimpleListener(
SimpleRabbitListenerContainerFactory rabbitListenerContainerFactory) {
SimpleRabbitListenerEndpoint endpoint = new SimpleRabbitListenerEndpoint();
endpoint.setQueueNames("queue.1");
endpoint.setMessageListener(message -> {
return rabbitListenerContainerFactory.createListenerContainer(endpoint);
The following example shows how to add the listener after creation:
public SimpleMessageListenerContainer factoryCreatedContainerNoListener(
SimpleMessageListenerContainer container = rabbitListenerContainerFactory.createListenerContainer();
container.setMessageListener(message -> {
container.setQueueNames("test.no.listener.yet");
return container;
In either case, the listener can also be a ChannelAwareMessageListener
, since it is now a sub-interface of MessageListener
These techniques are useful if you wish to create several containers with similar properties or use a pre-configured container factory such as the one provided by Spring Boot auto configuration or both.
Containers created this way are normal @Bean instances and are not registered in the RabbitListenerEndpointRegistry .
