This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4! |
Micrometer Observation
Using Micrometer for observation is now supported, since version 3.0, for the RabbitTemplate
and listener containers.
Set observationEnabled
on each component to enable observation; this will disable Micrometer Timers because the timers will now be managed with each observation.
When using annotated listeners, set observationEnabled
on the container factory.
Refer to Micrometer Tracing for more information.
To add tags to timers/traces, configure a custom RabbitTemplateObservationConvention
or RabbitListenerObservationConvention
to the template or listener container, respectively.
The default implementations add the name
tag for template observations and listener.id
tag for containers.
You can either subclass DefaultRabbitTemplateObservationConvention
or DefaultRabbitListenerObservationConvention
or provide completely new implementations.
See Micrometer Observation Documentation for more details.
Due to ambiguity in how traces should be handled in a batch, observations are NOT created for Batch Listener Containers. |
