This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4!spring-doc.cn
Changes in 3.1 Since 3.0
Java 17, Spring Framework 6.1
This version requires Spring Framework 6.1 and Java 17.spring-doc.cn
Exclusive Consumer Logging
Log messages reporting access refusal due to exclusive consumers are now logged at DEBUG level by default. It remains possible to configure your own logging behavior by setting the exclusiveConsumerExceptionLogger and closeExceptionLogger properties on the listener container and connection factory respectively. In addition, the SimpleMessageListenerContainer consumer restart after such an exception is now logged at DEBUG level by default (previously INFO). A new method logRestart() has been added to the ConditionalExceptionLogger to allow this to be changed. See Consumer Events and Logging Channel Close Events for more information.spring-doc.cn
Connections Enhancement
Connection Factory supported backoff policy when creating connection channel. See Choosing a Connection Factory for more information.spring-doc.cn
