This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4! |
Polling Consumer
The AmqpTemplate
itself can be used for polled Message
reception.
By default, if no message is available, null
is returned immediately.
There is no blocking.
Starting with version 1.5, you can set a receiveTimeout
, in milliseconds, and the receive methods block for up to that long, waiting for a message.
A value less than zero means block indefinitely (or at least until the connection to the broker is lost).
Version 1.6 introduced variants of the receive
methods that allows the timeout be passed in on each call.
Since the receive operation creates a new QueueingConsumer for each message, this technique is not really appropriate for high-volume environments.
Consider using an asynchronous consumer or a receiveTimeout of zero for those use cases.
Starting with version 2.4.8, when using a non-zero timeout, you can specify arguments passed into the basicConsume
method used to associate the consumer with the channel.
For example: template.addConsumerArg("x-priority", 10)
There are four simple receive
methods available.
As with the Exchange
on the sending side, there is a method that requires that a default queue property has been set
directly on the template itself, and there is a method that accepts a queue parameter at runtime.
Version 1.6 introduced variants to accept timeoutMillis
to override receiveTimeout
on a per-request basis.
The following listing shows the definitions of the four methods:
Message receive() throws AmqpException;
Message receive(String queueName) throws AmqpException;
Message receive(long timeoutMillis) throws AmqpException;
Message receive(String queueName, long timeoutMillis) throws AmqpException;
As in the case of sending messages, the AmqpTemplate
has some convenience methods for receiving POJOs instead of Message
instances, and implementations provide a way to customize the MessageConverter
used to create the Object
returned:
The following listing shows those methods:
Object receiveAndConvert() throws AmqpException;
Object receiveAndConvert(String queueName) throws AmqpException;
Object receiveAndConvert(long timeoutMillis) throws AmqpException;
Object receiveAndConvert(String queueName, long timeoutMillis) throws AmqpException;
Starting with version 2.0, there are variants of these methods that take an additional ParameterizedTypeReference
argument to convert complex types.
The template must be configured with a SmartMessageConverter
See Converting From a Message
With RabbitTemplate
for more information.
Similar to sendAndReceive
methods, beginning with version 1.3, the AmqpTemplate
has several convenience receiveAndReply
methods for synchronously receiving, processing and replying to messages.
The following listing shows those method definitions:
<R, S> boolean receiveAndReply(ReceiveAndReplyCallback<R, S> callback)
<R, S> boolean receiveAndReply(String queueName, ReceiveAndReplyCallback<R, S> callback)
<R, S> boolean receiveAndReply(ReceiveAndReplyCallback<R, S> callback,
String replyExchange, String replyRoutingKey) throws AmqpException;
<R, S> boolean receiveAndReply(String queueName, ReceiveAndReplyCallback<R, S> callback,
ReplyToAddressCallback<S> replyToAddressCallback) throws AmqpException;
The AmqpTemplate
implementation takes care of the receive
and reply
phases.
In most cases, you should provide only an implementation of ReceiveAndReplyCallback
to perform some business logic for the received message and build a reply object or message, if needed.
Note, a ReceiveAndReplyCallback
may return null
In this case, no reply is sent and receiveAndReply
works like the receive
method.
This lets the same queue be used for a mixture of messages, some of which may not need a reply.
Automatic message (request and reply) conversion is applied only if the provided callback is not an instance of ReceiveAndReplyMessageCallback
, which provides a raw message exchange contract.
The ReplyToAddressCallback
is useful for cases requiring custom logic to determine the replyTo
address at runtime against the received message and reply from the ReceiveAndReplyCallback
By default, replyTo
information in the request message is used to route the reply.
The following listing shows an example of POJO-based receive and reply:
boolean received =
this.template.receiveAndReply(ROUTE, new ReceiveAndReplyCallback<Order, Invoice>() {
public Invoice handle(Order order) {
return processOrder(order);
if (received) {
log.info("We received an order!");
