This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4!spring-doc.cn
RabbitMQ AMQP 1.0 Support
Version 4.0 introduces spring-rabbitmq-client module for AMQP 1.0 protocol support on RabbitMQ.spring-doc.cn
This artifact is based on the com.rabbitmq.client:amqp-client library and therefore can work only with RabbitMQ and its AMQP 1.0 protocol support. It cannot be used for any arbitrary AMQP 1.0 broker. For that purpose a JMS bridge and respective Spring JMS integration is recommended so far.spring-doc.cn
This dependency has to be added to the project to be able to interact with RabbitMQ AMQP 1.0 support:spring-doc.cn
maven
<dependency>
  <groupId>org.springframework.amqp</groupId>
  <artifactId>spring-rabbitmq-client</artifactId>
  <version>4.0.0-SNAPSHOT</version>
</dependency>
gradle
compile 'org.springframework.amqp:spring-rabbitmq-client:4.0.0-SNAPSHOT'
The spring-rabbit (for AMQP 0.9.1 protocol) comes as a transitive dependency for reusing some common API in this new client, for example, exceptions, the @RabbitListener support. It is not necessary to use both functionality in the target project, but RabbitMQ allows both AMQP 0.9.1 and 1.0 co-exists.spring-doc.cn
For more information about RabbitMQ AMQP 1.0 Java Client see its documentation.spring-doc.cn
RabbitMQ AMQP 1.0 Environment
The com.rabbitmq.client.amqp.Environment is the first thing which has to be added to the project for connection management and other common settings. It is an entry point to a node or a cluster of nodes. The environment allows creating connections. It can contain infrastructure-related configuration settings shared between connections, e.g. pools of threads, metrics and/or observation:spring-doc.cn
Environment environment() {
    return new AmqpEnvironmentBuilder()
            .connectionSettings()
            .port(5672)
            .environmentBuilder()
The same Environment instance can be used for connecting to different RabbitMQ brokers, then connection setting must be provided on specific connection. See below.spring-doc.cn
AMQP Connection Factory
The org.springframework.amqp.rabbitmq.client.AmqpConnectionFactory abstraction was introduced to manage com.rabbitmq.client.amqp.Connection. Don’t confuse it with a org.springframework.amqp.rabbit.connection.ConnectionFactory which is only for AMQP 0.9.1 protocol. The SingleAmqpConnectionFactory implementation is present to manage one connection and its settings. The same Connection can be shared between many producers, consumers and management. The multi-plexing is handled by the link abstraction for AMQP 1.0 protocol implementation internally in the AMQP client library. The Connection has recovery capabilities and also handles topology.spring-doc.cn
In most cases there is just enough to add this bean into the project:spring-doc.cn
AmqpConnectionFactory connectionFactory(Environment environment) {
    return new SingleAmqpConnectionFactory(environment);
See SingleAmqpConnectionFactory setters for all connection-specific setting.spring-doc.cn
RabbitMQ Topology Management
For topology management (exchanges, queues and binding between) from the application perspective, the RabbitAmqpAdmin is present, which is an implementation of existing AmqpAdmin interface:spring-doc.cn
RabbitAmqpAdmin admin(AmqpConnectionFactory connectionFactory) {
    return new RabbitAmqpAdmin(connectionFactory);
The same bean definitions for Exchange, Queue, Binding and Declarables instances as described in the Configuring the Broker has to be used to manage topology. The RabbitAdmin from spring-rabbit can also do that, but it happens against AMQP 0.9.1 connection, and since RabbitAmqpAdmin is based on the AMQP 1.0 connection, the topology recovery is handled smoothly from there, together with publishers and consumers recovery.spring-doc.cn
The RabbitAmqpAdmin performs respective beans scanning in its start() lifecycle callback. The initialize(), as well-as all other RabbitMQ entities management methods can be called manually at runtime. Internally the RabbitAmqpAdmin uses com.rabbitmq.client.amqp.Connection.management() API to perform respective topology manipulations.spring-doc.cn
RabbitAmqpTemplate
The RabbitAmqpTemplate is an implementation of the AsyncAmqpTemplate and performs various send/receive operations with AMQP 1.0 protocol. Requires an AmqpConnectionFactory and can be configured with some defaults. Even if com.rabbitmq.client:amqp-client library comes with a com.rabbitmq.client.amqp.Message, the RabbitAmqpTemplate still exposes an API based on the well-known org.springframework.amqp.core.Message with all the supporting classes like MessageProperties and MessageConverter abstraction. The conversion to/from com.rabbitmq.client.amqp.Message is done internally in the RabbitAmqpTemplate. All the methods return a CompletableFuture to obtain operation results eventually. The operations with plain object require message body conversion and SimpleMessageConverter is used by default. See Message Converters for more information about conversions.spring-doc.cn
Usually, just one bean like this is enough to perform all the possible template pattern operation:spring-doc.cn
RabbitAmqpTemplate rabbitTemplate(AmqpConnectionFactory connectionFactory) {
    return new RabbitAmqpTemplate(connectionFactory);
It can be configured for some default exchange and routing key or just queue. The RabbitAmqpTemplate have a default queue for receive operation and another default queue for request-reply operation where temporary queue is created for the request by the client if not present.spring-doc.cn
Here are some samples of RabbitAmqpTemplate operations:spring-doc.cn
DirectExchange e1() {
    return new DirectExchange("e1");
Queue q1() {
    return QueueBuilder.durable("q1").deadLetterExchange("dlx1").build();
Binding b1() {
    return BindingBuilder.bind(q1()).to(e1()).with("k1");
@Test
void defaultExchangeAndRoutingKey() {
    this.rabbitAmqpTemplate.setExchange("e1");
    this.rabbitAmqpTemplate.setRoutingKey("k1");
	this.rabbitAmqpTemplate.setReceiveQueue("q1");
    assertThat(this.rabbitAmqpTemplate.convertAndSend("test1"))
            .succeedsWithin(Duration.ofSeconds(10));
    assertThat(this.rabbitAmqpTemplate.receiveAndConvert())
            .isEqualTo("test1");
Here we declared an e1 exchange, q1 queue and bind it into that exchange with a k1 routing key. Then we use a default setting for RabbitAmqpTemplate to publish messages to the mentioned exchange with the respective routing key and use q1 as default queue for receiving operations. There are overloaded variants for those methods to send to specific exchange or queue (for send and receive). The receiveAndConvert() operations with a ParameterizedTypeReference<T> requires a SmartMessageConverter to be injected into the RabbitAmqpTemplate.spring-doc.cn
The next example demonstrate and RPC implementation with RabbitAmqpTemplate (assuming same RabbitMQ objects as in the previous example):spring-doc.cn
@Test
void verifyRpc() {
    String testRequest = "rpc-request";
    String testReply = "rpc-reply";
    CompletableFuture<Object> rpcClientResult = this.template.convertSendAndReceive("e1", "k1", testRequest);
    AtomicReference<String> receivedRequest = new AtomicReference<>();
    CompletableFuture<Boolean> rpcServerResult =
            this.rabbitAmqpTemplate.<String, String>receiveAndReply("q1",
                     payload -> {
                         receivedRequest.set(payload);
                         return testReply;
    assertThat(rpcServerResult).succeedsWithin(Duration.ofSeconds(10)).isEqualTo(true);
    assertThat(rpcClientResult).succeedsWithin(Duration.ofSeconds(10)).isEqualTo(testReply);
    assertThat(receivedRequest.get()).isEqualTo(testRequest);
The correlation and replyTo queue are managed internally. The server side can be implemented with a @RabbitListener POJO method described below.spring-doc.cn
The RabbitMQ AMQP 1.0 Consumer
As with many other messaging implementations for consumer side, the spring-rabbitmq-client modules comes with the RabbitAmqpListenerContainer which is, essentially, an implementation of well-know MessageListenerContainer. It does exactly the same as DirectMessageListenerContainer, but for RabbitMQ AMQP 1.0 support. Requires an AmqpConnectionFactory and at least one queue to consume from. Also, the MessageListener (or AMQP 1.0 specific RabbitAmqpMessageListener) must be provided. Can be configured with an autoSettle = false, with the meaning of AcknowledgeMode.MANUAL. In that case, the Message provided to the MessageListener has in its MessageProperties an AmqpAcknowledgment callback for target logic consideration.spring-doc.cn
The RabbitAmqpMessageListener has a contract for com.rabbitmq.client:amqp-client abstractions:spring-doc.cn
 * Process an AMQP message.
 * @param message the message to process.
 * @param context the consumer context to settle message.
 *                Null if container is configured for {@code autoSettle}.
void onAmqpMessage(Message message, Consumer.Context context);
Where the first argument is a native received com.rabbitmq.client.amqp.Message and context is a native callback for message settlement, similar to the mentioned above AmqpAcknowledgment abstraction.spring-doc.cn
The RabbitAmqpMessageListener can handle and settle messages in batches when batchSize option is provided. For this purpose the MessageListener.onMessageBatch() contract must be implemented. The batchReceiveDuration option is used to schedule a force release for not full batches to avoid memory and consumer credits exhausting.spring-doc.cn
Usually, the RabbitAmqpMessageListener class is not used directly in the target project, and POJO method annotation configuration via @RabbitListener is chosen for declarative consumer configuration. The RabbitAmqpListenerContainerFactory must be registered under the RabbitListenerAnnotationBeanPostProcessor.DEFAULT_RABBIT_LISTENER_CONTAINER_FACTORY_BEAN_NAME, and @RabbitListener annotation process will register RabbitAmqpMessageListener instance into the RabbitListenerEndpointRegistry. The target POJO method invocation is handled by specific RabbitAmqpMessageListenerAdapter implementation, which extends a MessagingMessageListenerAdapter and reuses a lot of its functionality, including request-reply scenarios (async or not). So, all the concepts described in the Annotation-driven Listener Endpoints are applied with this RabbitAmqpMessageListener as well.spring-doc.cn
In addition to traditional messaging payload and headers, the @RabbitListener POJO method contract can be with these parameters:spring-doc.cn
  • com.rabbitmq.client.amqp.Message - the native AMQP 1.0 message without any conversions;spring-doc.cn
  • org.springframework.amqp.core.Message - Spring AMQP message abstraction as conversion result from the native AMQP 1.0 message;spring-doc.cn
  • org.springframework.messaging.Message - Spring Messaging abstraction as conversion result from the Spring AMQP message;spring-doc.cn
  • Consumer.Context - RabbitMQ AMQP client consumer settlement API;spring-doc.cn
  • org.springframework.amqp.core.AmqpAcknowledgment - Spring AMQP acknowledgment abstraction: delegates to the Consumer.Context.spring-doc.cn
The following example demonstrates a simple @RabbitListener for RabbitMQ AMQP 1.0 interaction with the manual settlement:spring-doc.cn
@Bean(RabbitListenerAnnotationBeanPostProcessor.DEFAULT_RABBIT_LISTENER_CONTAINER_FACTORY_BEAN_NAME)
RabbitAmqpListenerContainerFactory rabbitAmqpListenerContainerFactory(AmqpConnectionFactory connectionFactory) {
    return new RabbitAmqpListenerContainerFactory(connectionFactory);
final List<String> received = Collections.synchronizedList(new ArrayList<>());
CountDownLatch consumeIsDone = new CountDownLatch(11);
@RabbitListener(queues = {"q1", "q2"},
        ackMode = "#{T(org.springframework.amqp.core.AcknowledgeMode).MANUAL}",
        concurrency = "2",
        id = "testAmqpListener")
void processQ1AndQ2Data(String data, AmqpAcknowledgment acknowledgment, Consumer.Context context) {
    try {
        if ("discard".equals(data)) {
            if (!this.received.contains(data)) {
                context.discard();
            else {
                throw new MessageConversionException("Test message is rejected");
        else if ("requeue".equals(data) && !this.received.contains(data)) {
            acknowledgment.acknowledge(AmqpAcknowledgment.Status.REQUEUE);
        else {
            acknowledgment.acknowledge();
        this.received.add(data);
    finally {
        this.consumeIsDone.countDown();
