This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4! |
Micrometer Observation Documentation
This section describes the Micrometer integration.
Observability - Metrics
Below you can find a list of all metrics declared by this project.
Listener Observation
Observation for Rabbit listeners.
Metric name spring.rabbit.listener
(defined by convention class RabbitListenerObservation$DefaultRabbitListenerObservationConvention
). Type timer
Metric name spring.rabbit.listener.active
). Type long task timer
KeyValues that are added after starting the Observation might be missing from the *.active metrics. |
Micrometer internally uses nanoseconds for the baseunit. However, each backend determines the actual baseunit. (i.e. Prometheus uses seconds)
Name of the enclosing class RabbitListenerObservation
Name |
Description |
The queue the listener is plugged to. |
Listener id. |
Stream Listener Observation
Observation for Rabbit stream listeners.
Metric name spring.rabbit.stream.listener
(defined by convention class RabbitStreamListenerObservation$DefaultRabbitStreamListenerObservationConvention
). Type timer
Metric name spring.rabbit.stream.listener.active
Name of the enclosing class RabbitStreamListenerObservation
All tags must be prefixed with spring.rabbit.stream.listener prefix!
Name |
Description |
Listener id. |
Stream Template Observation
Observation for `RabbitStreamTemplate`s.
Metric name spring.rabbit.stream.template
(defined by convention class RabbitStreamTemplateObservation$DefaultRabbitStreamTemplateObservationConvention
). Type timer
Metric name spring.rabbit.stream.template.active
Name of the enclosing class RabbitStreamTemplateObservation
All tags must be prefixed with spring.rabbit.stream.template prefix!
Name |
Description |
Bean name of the template. |
Observation for RabbitTemplates.
Metric name spring.rabbit.template
(defined by convention class RabbitTemplateObservation$DefaultRabbitTemplateObservationConvention
). Type timer
Metric name spring.rabbit.template.active
Name of the enclosing class RabbitTemplateObservation
Name |
Description |
The destination exchange (empty if default exchange). |
The destination routing key. |
Observability - Spans
Below you can find a list of all spans declared by this project.
Listener Observation Span
Span name spring.rabbit.listener
Name |
Description |
The delivery tag. |
Listener id. |
Stream Listener Observation Span
Span name spring.rabbit.stream.listener
Name |
Description |
Listener id. |
Stream Template Observation Span
Span name spring.rabbit.stream.template
Name |
Description |
Span name spring.rabbit.template
Name |
Description |
Observability - Conventions
Below you can find a list of all GlobalObservationConvention
and ObservationConvention
ObservationConvention Class Name |
Applicable ObservationContext Class Name |
