This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4!spring-doc.cn
Message Converters
The AmqpTemplate also defines several methods for sending and receiving messages that delegate to a MessageConverter. The MessageConverter provides a single method for each direction: one for converting to a Message and another for converting from a Message. Notice that, when converting to a Message, you can also provide properties in addition to the object. The object parameter typically corresponds to the Message body. The following listing shows the MessageConverter interface definition:spring-doc.cn
public interface MessageConverter {
    Message toMessage(Object object, MessageProperties messageProperties)
            throws MessageConversionException;
    Object fromMessage(Message message) throws MessageConversionException;
The relevant Message-sending methods on the AmqpTemplate are simpler than the methods we discussed previously, because they do not require the Message instance. Instead, the MessageConverter is responsible for “creating” each Message by converting the provided object to the byte array for the Message body and then adding any provided MessageProperties. The following listing shows the definitions of the various methods:spring-doc.cn
void convertAndSend(Object message) throws AmqpException;
void convertAndSend(String routingKey, Object message) throws AmqpException;
void convertAndSend(String exchange, String routingKey, Object message)
void convertAndSend(Object message, MessagePostProcessor messagePostProcessor)
void convertAndSend(String routingKey, Object message,
    MessagePostProcessor messagePostProcessor) throws AmqpException;
void convertAndSend(String exchange, String routingKey, Object message,
On the receiving side, there are only two methods: one that accepts the queue name and one that relies on the template’s “queue” property having been set. The following listing shows the definitions of the two methods:spring-doc.cn
Object receiveAndConvert() throws AmqpException;
Object receiveAndConvert(String queueName) throws AmqpException;
The MessageListenerAdapter mentioned in Asynchronous Consumer also uses a MessageConverter.
SimpleMessageConverter
The default implementation of the MessageConverter strategy is called SimpleMessageConverter. This is the converter that is used by an instance of RabbitTemplate if you do not explicitly configure an alternative. It handles text-based content, serialized Java objects, and byte arrays.spring-doc.cn
Converting From a Message
If the content type of the input Message begins with "text" (for example, "text/plain"), it also checks for the content-encoding property to determine the charset to be used when converting the Message body byte array to a Java String. If no content-encoding property had been set on the input Message, it uses the UTF-8 charset by default. If you need to override that default setting, you can configure an instance of SimpleMessageConverter, set its defaultCharset property, and inject that into a RabbitTemplate instance.spring-doc.cn
If the content-type property value of the input Message is set to "application/x-java-serialized-object", the SimpleMessageConverter tries to deserialize (rehydrate) the byte array into a Java object. While that might be useful for simple prototyping, we do not recommend relying on Java serialization, since it leads to tight coupling between the producer and the consumer. Of course, it also rules out usage of non-Java systems on either side. With AMQP being a wire-level protocol, it would be unfortunate to lose much of that advantage with such restrictions. In the next two sections, we explore some alternatives for passing rich domain object content without relying on Java serialization.spring-doc.cn
For all other content-types, the SimpleMessageConverter returns the Message body content directly as a byte array.spring-doc.cn
See Java Deserialization for important information.spring-doc.cn
Converting To a Message
When converting to a Message from an arbitrary Java Object, the SimpleMessageConverter likewise deals with byte arrays, strings, and serializable instances. It converts each of these to bytes (in the case of byte arrays, there is nothing to convert), and it sets the content-type property accordingly. If the Object to be converted does not match one of those types, the Message body is null.spring-doc.cn
SerializerMessageConverter
This converter is similar to the SimpleMessageConverter except that it can be configured with other Spring Framework Serializer and Deserializer implementations for application/x-java-serialized-object conversions.spring-doc.cn
Jackson2JsonMessageConverter
This section covers using the Jackson2JsonMessageConverter to convert to and from a Message. It has the following sections:spring-doc.cn
Converting to a Message
As mentioned in the previous section, relying on Java serialization is generally not recommended. One rather common alternative that is more flexible and portable across different languages and platforms is JSON (JavaScript Object Notation). The converter can be configured on any RabbitTemplate instance to override its usage of the SimpleMessageConverter default. The Jackson2JsonMessageConverter uses the com.fasterxml.jackson 2.x library. The following example configures a Jackson2JsonMessageConverter:spring-doc.cn
<bean class="org.springframework.amqp.rabbit.core.RabbitTemplate">
    <property name="connectionFactory" ref="rabbitConnectionFactory"/>
    <property name="messageConverter">
        <bean class="org.springframework.amqp.support.converter.Jackson2JsonMessageConverter">
            <!-- if necessary, override the DefaultClassMapper -->
            <property name="classMapper" ref="customClassMapper"/>
        </bean>
    </property>
</bean>
As shown above, Jackson2JsonMessageConverter uses a DefaultClassMapper by default. Type information is added to (and retrieved from) MessageProperties. If an inbound message does not contain type information in MessageProperties, but you know the expected type, you can configure a static type by using the defaultType property, as the following example shows:spring-doc.cn
<bean id="jsonConverterWithDefaultType"
      class="o.s.amqp.support.converter.Jackson2JsonMessageConverter">
    <property name="classMapper">
        <bean class="org.springframework.amqp.support.converter.DefaultClassMapper">
            <property name="defaultType" value="thing1.PurchaseOrder"/>
        </bean>
    </property>
</bean>
In addition, you can provide custom mappings from the value in the TypeId header. The following example shows how to do so:spring-doc.cn
public Jackson2JsonMessageConverter jsonMessageConverter() {
    Jackson2JsonMessageConverter jsonConverter = new Jackson2JsonMessageConverter();
    jsonConverter.setClassMapper(classMapper());
    return jsonConverter;
public DefaultClassMapper classMapper() {
    DefaultClassMapper classMapper = new DefaultClassMapper();
    Map<String, Class<?>> idClassMapping = new HashMap<>();
    idClassMapping.put("thing1", Thing1.class);
    idClassMapping.put("thing2", Thing2.class);
    classMapper.setIdClassMapping(idClassMapping);
    return classMapper;
Now, if the sending system sets the header to thing1, the converter creates a Thing1 object, and so on. See the Receiving JSON from Non-Spring Applications sample application for a complete discussion about converting messages from non-Spring applications.spring-doc.cn
Starting with version 2.4.3, the converter will not add a contentEncoding message property if the supportedMediaType has a charset parameter; this is also used for the encoding. A new method setSupportedMediaType has been added:spring-doc.cn
String utf16 = "application/json; charset=utf-16";
converter.setSupportedContentType(MimeTypeUtils.parseMimeType(utf16));
Converting from a Message
Inbound messages are converted to objects according to the type information added to headers by the sending system.spring-doc.cn
Starting with version 2.4.3, if there is no contentEncoding message property, the converter will attempt to detect a charset parameter in the contentType message property and use that. If neither exist, if the supportedMediaType has a charset parameter, it will be used for decoding, with a final fallback to the defaultCharset property. A new method setSupportedMediaType has been added:spring-doc.cn
In versions prior to 1.6, if type information is not present, conversion would fail. Starting with version 1.6, if type information is missing, the converter converts the JSON by using Jackson defaults (usually a map).spring-doc.cn
Also, starting with version 1.6, when you use @RabbitListener annotations (on methods), the inferred type information is added to the MessageProperties. This lets the converter convert to the argument type of the target method. This only applies if there is one parameter with no annotations or a single parameter with the @Payload annotation. Parameters of type Message are ignored during the analysis.spring-doc.cn
By default, the inferred type information will override the inbound TypeId and related headers created by the sending system. This lets the receiving system automatically convert to a different domain object. This applies only if the parameter type is concrete (not abstract or an interface) or it is from the java.util package. In all other cases, the TypeId and related headers is used. There are cases where you might wish to override the default behavior and always use the TypeId information. For example, suppose you have a @RabbitListener that takes a Thing1 argument but the message contains a Thing2 that is a subclass of Thing1 (which is concrete). The inferred type would be incorrect. To handle this situation, set the TypePrecedence property on the Jackson2JsonMessageConverter to TYPE_ID instead of the default INFERRED. (The property is actually on the converter’s DefaultJackson2JavaTypeMapper, but a setter is provided on the converter for convenience.) If you inject a custom type mapper, you should set the property on the mapper instead.
When converting from the Message, an incoming MessageProperties.getContentType() must be JSON-compliant (contentType.contains("json") is used to check). Starting with version 2.2, application/json is assumed if there is no contentType property, or it has the default value application/octet-stream. To revert to the previous behavior (return an unconverted byte[]), set the converter’s assumeSupportedContentType property to false. If the content type is not supported, a WARN log message Could not convert incoming message with content-type […​], is emitted and message.getBody() is returned as is — as a byte[]. So, to meet the Jackson2JsonMessageConverter requirements on the consumer side, the producer must add the contentType message property — for example, as application/json or text/x-json or by using the Jackson2JsonMessageConverter, which sets the header automatically. The following listing shows a number of converter calls:
@RabbitListener
public void thing1(Thing1 thing1) {...}
@RabbitListener
public void thing1(@Payload Thing1 thing1, @Header("amqp_consumerQueue") String queue) {...}
@RabbitListener
public void thing1(Thing1 thing1, o.s.amqp.core.Message message) {...}
@RabbitListener
public void thing1(Thing1 thing1, o.s.messaging.Message<Foo> message) {...}
@RabbitListener
public void thing1(Thing1 thing1, String bar) {...}
@RabbitListener
public void thing1(Thing1 thing1, o.s.messaging.Message<?> message) {...}
In the first four cases in the preceding listing, the converter tries to convert to the Thing1 type. The fifth example is invalid because we cannot determine which argument should receive the message payload. With the sixth example, the Jackson defaults apply due to the generic type being a WildcardType.spring-doc.cn
You can, however, create a custom converter and use the targetMethod message property to decide which type to convert the JSON to.spring-doc.cn
This type inference can only be achieved when the @RabbitListener annotation is declared at the method level. With class-level @RabbitListener, the converted type is used to select which @RabbitHandler method to invoke. For this reason, the infrastructure provides the targetObject message property, which you can use in a custom converter to determine the type.
Starting with version 1.6.11, Jackson2JsonMessageConverter and, therefore, DefaultJackson2JavaTypeMapper (DefaultClassMapper) provide the trustedPackages option to overcome Serialization Gadgets vulnerability. By default and for backward compatibility, the Jackson2JsonMessageConverter trusts all packages — that is, it uses * for the option.
Starting with version 2.4.7, the converter can be configured to return Optional.empty() if Jackson returns null after deserializing the message body. This facilitates @RabbitListener s to receive null payloads, in two ways:spring-doc.cn
@RabbitListener(queues = "op.1")
void listen(@Payload(required = false) Thing payload) {
    handleOptional(payload); // payload might be null
@RabbitListener(queues = "op.2")
void listen(Optional<Thing> optional) {
    handleOptional(optional.orElse(this.emptyThing));
To enable this feature, set setNullAsOptionalEmpty to true; when false (default), the converter falls back to the raw message body (byte[]).spring-doc.cn
Jackson2JsonMessageConverter converter() {
    Jackson2JsonMessageConverter converter = new Jackson2JsonMessageConverter();
    converter.setNullAsOptionalEmpty(true);
    return converter;
Deserializing Abstract Classes
Prior to version 2.2.8, if the inferred type of a @RabbitListener was an abstract class (including interfaces), the converter would fall back to looking for type information in the headers and, if present, used that information; if that was not present, it would try to create the abstract class. This caused a problem when a custom ObjectMapper that is configured with a custom deserializer to handle the abstract class is used, but the incoming message has invalid type headers.spring-doc.cn
Starting with version 2.2.8, the previous behavior is retained by default. If you have such a custom ObjectMapper and you want to ignore type headers, and always use the inferred type for conversion, set the alwaysConvertToInferredType to true. This is needed for backwards compatibility and to avoid the overhead of an attempted conversion when it would fail (with a standard ObjectMapper).spring-doc.cn
Using Spring Data Projection Interfaces
Starting with version 2.2, you can convert JSON to a Spring Data Projection interface instead of a concrete type. This allows very selective, and low-coupled bindings to data, including the lookup of values from multiple places inside the JSON document. For example the following interface can be defined as message payload type:spring-doc.cn
interface SomeSample {
  @JsonPath({ "$.username", "$.user.name" })
  String getUsername();
@RabbitListener(queues = "projection")
public void projection(SomeSample in) {
    String username = in.getUsername();
Accessor methods will be used to lookup the property name as field in the received JSON document by default. The @JsonPath expression allows customization of the value lookup, and even to define multiple JSON path expressions, to lookup values from multiple places until an expression returns an actual value.spring-doc.cn
To enable this feature, set the useProjectionForInterfaces to true on the message converter. You must also add spring-data:spring-data-commons and com.jayway.jsonpath:json-path to the class path.spring-doc.cn
When used as the parameter to a @RabbitListener method, the interface type is automatically passed to the converter as normal.spring-doc.cn
Converting From a Message With RabbitTemplate
As mentioned earlier, type information is conveyed in message headers to assist the converter when converting from a message. This works fine in most cases. However, when using generic types, it can only convert simple objects and known “container” objects (lists, arrays, and maps). Starting with version 2.0, the Jackson2JsonMessageConverter implements SmartMessageConverter, which lets it be used with the new RabbitTemplate methods that take a ParameterizedTypeReference argument. This allows conversion of complex generic types, as shown in the following example:spring-doc.cn
Thing1<Thing2<Cat, Hat>> thing1 =
    rabbitTemplate.receiveAndConvert(new ParameterizedTypeReference<Thing1<Thing2<Cat, Hat>>>() { });
Starting with version 2.1, the AbstractJsonMessageConverter class has been removed. It is no longer the base class for Jackson2JsonMessageConverter. It has been replaced by AbstractJackson2MessageConverter.
MarshallingMessageConverter
Yet another option is the MarshallingMessageConverter. It delegates to the Spring OXM library’s implementations of the Marshaller and Unmarshaller strategy interfaces. You can read more about that library here. In terms of configuration, it is most common to provide only the constructor argument, since most implementations of Marshaller also implement Unmarshaller. The following example shows how to configure a MarshallingMessageConverter:spring-doc.cn
        <bean class="org.springframework.amqp.support.converter.MarshallingMessageConverter">
            <constructor-arg ref="someImplemenationOfMarshallerAndUnmarshaller"/>
        </bean>
    </property>
</bean>
Jackson2XmlMessageConverter
This class was introduced in version 2.1 and can be used to convert messages from and to XML.spring-doc.cn
Both Jackson2XmlMessageConverter and Jackson2JsonMessageConverter have the same base class: AbstractJackson2MessageConverter.spring-doc.cn
The AbstractJackson2MessageConverter class is introduced to replace a removed class: AbstractJsonMessageConverter.
The Jackson2XmlMessageConverter uses the com.fasterxml.jackson 2.x library.spring-doc.cn
You can use it the same way as Jackson2JsonMessageConverter, except it supports XML instead of JSON. The following example configures a Jackson2JsonMessageConverter:spring-doc.cn
<bean id="xmlConverterWithDefaultType"
        class="org.springframework.amqp.support.converter.Jackson2XmlMessageConverter">
            <property name="defaultType" value="foo.PurchaseOrder"/>
        </bean>
    </property>
</bean>
See Jackson2JsonMessageConverter for more information.spring-doc.cn
Starting with version 2.2, application/xml is assumed if there is no contentType property, or it has the default value application/octet-stream. To revert to the previous behavior (return an unconverted byte[]), set the converter’s assumeSupportedContentType property to false.
ContentTypeDelegatingMessageConverter
This class was introduced in version 1.4.2 and allows delegation to a specific MessageConverter based on the content type property in the MessageProperties. By default, it delegates to a SimpleMessageConverter if there is no contentType property or there is a value that matches none of the configured converters. The following example configures a ContentTypeDelegatingMessageConverter:spring-doc.cn
<bean id="contentTypeConverter" class="ContentTypeDelegatingMessageConverter">
    <property name="delegates">
        <map>
            <entry key="application/json" value-ref="jsonMessageConverter" />
            <entry key="application/xml" value-ref="xmlMessageConverter" />
        </map>
    </property>
</bean>
This section covers how to deserialize Java objects.spring-doc.cn
There is a possible vulnerability when deserializing java objects from untrusted sources.spring-doc.cn
If you accept messages from untrusted sources with a content-type of application/x-java-serialized-object, you should consider configuring which packages and classes are allowed to be deserialized. This applies to both the SimpleMessageConverter and SerializerMessageConverter when it is configured to use a DefaultDeserializer either implicitly or via configuration.spring-doc.cn
By default, the allowed list is empty, meaning no classes will be deserialized.spring-doc.cn
You can set a list of patterns, such as thing1., thing1.thing2.Cat or .MySafeClass.spring-doc.cn
The patterns are checked in order until a match is found. If there is no match, a SecurityException is thrown.spring-doc.cn
You can set the patterns using the allowedListPatterns property on these converters. Alternatively, if you trust all message originators, you can set the environment variable SPRING_AMQP_DESERIALIZATION_TRUST_ALL or system property spring.amqp.deserialization.trust.all to true.spring-doc.cn
Message Properties Converters
The MessagePropertiesConverter strategy interface is used to convert between the Rabbit Client BasicProperties and Spring AMQP MessageProperties. The default implementation (DefaultMessagePropertiesConverter) is usually sufficient for most purposes, but you can implement your own if needed. The default properties converter converts BasicProperties elements of type LongString to String instances when the size is not greater than 1024 bytes. Larger LongString instances are not converted (see the next paragraph). This limit can be overridden with a constructor argument.spring-doc.cn
Starting with version 1.6, headers longer than the long string limit (default: 1024) are now left as LongString instances by default by the DefaultMessagePropertiesConverter. You can access the contents through the getBytes[], toString(), or getStream() methods.spring-doc.cn
Previously, the DefaultMessagePropertiesConverter “converted” such headers to a DataInputStream (actually it just referenced the LongString instance’s DataInputStream). On output, this header was not converted (except to a String — for example, java.io.DataInputStream@1d057a39 by calling toString() on the stream).spring-doc.cn
Large incoming LongString headers are now correctly “converted” on output, too (by default).spring-doc.cn
A new constructor is provided to let you configure the converter to work as before. The following listing shows the Javadoc comment and declaration of the method:spring-doc.cn
 * Construct an instance where LongStrings will be returned
 * unconverted or as a java.io.DataInputStream when longer than this limit.
 * Use this constructor with 'true' to restore pre-1.6 behavior.
 * @param longStringLimit the limit.
 * @param convertLongLongStrings LongString when false,
 * DataInputStream when true.
 * @since 1.6
public DefaultMessagePropertiesConverter(int longStringLimit, boolean convertLongLongStrings) { ... }
Also starting with version 1.6, a new property called correlationIdString has been added to MessageProperties. Previously, when converting to and from BasicProperties used by the RabbitMQ client, an unnecessary byte[] <→ String conversion was performed because MessageProperties.correlationId is a byte[], but BasicProperties uses a String. (Ultimately, the RabbitMQ client uses UTF-8 to convert the String to bytes to put in the protocol message).spring-doc.cn
To provide maximum backwards compatibility, a new property called correlationIdPolicy has been added to the DefaultMessagePropertiesConverter. This takes a DefaultMessagePropertiesConverter.CorrelationIdPolicy enum argument. By default it is set to BYTES, which replicates the previous behavior.spring-doc.cn
For inbound messages:spring-doc.cn
For outbound messages:spring-doc.cn
  • STRING: Only the correlationIdString property is mappedspring-doc.cn
  • BYTES: Only the correlationId property is mappedspring-doc.cn
  • BOTH: Both properties are considered, with the String property taking precedencespring-doc.cn
Also starting with version 1.6, the inbound deliveryMode property is no longer mapped to MessageProperties.deliveryMode. It is mapped to MessageProperties.receivedDeliveryMode instead. Also, the inbound userId property is no longer mapped to MessageProperties.userId. It is mapped to MessageProperties.receivedUserId instead. These changes are to avoid unexpected propagation of these properties if the same MessageProperties object is used for an outbound message.spring-doc.cn
Starting with version 2.2, the DefaultMessagePropertiesConverter converts any custom headers with values of type Class<?> using getName() instead of toString(); this avoids consuming application having to parse the class name out of the toString() representation. For rolling upgrades, you may need to change your consumers to understand both formats until all producers are upgraded.spring-doc.cn
