This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4! |
Programmatic Endpoint Registration
RabbitListenerEndpoint
provides a model of a Rabbit endpoint and is responsible for configuring the container for that model.
The infrastructure lets you configure endpoints programmatically in addition to the ones that are detected by the RabbitListener
annotation.
The following example shows how to do so:
@EnableRabbit
public class AppConfig implements RabbitListenerConfigurer {
public void configureRabbitListeners(RabbitListenerEndpointRegistrar registrar) {
SimpleRabbitListenerEndpoint endpoint = new SimpleRabbitListenerEndpoint();
endpoint.setId("someRabbitListenerEndpoint");
endpoint.setQueueNames("anotherQueue");
endpoint.setMessageListener(message -> {
// processing
registrar.registerEndpoint(endpoint);
In the preceding example, we used SimpleRabbitListenerEndpoint
, which provides the actual MessageListener
to invoke, but you could just as well build your own endpoint variant to describe a custom invocation mechanism.
the id property is required for SimpleRabbitListenerEndpoint definition.
It should be noted that you could just as well skip the use of @RabbitListener
altogether and register your endpoints programmatically through RabbitListenerConfigurer
