This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.3! |
OIDC Logout
Once an end user is able to login to your application, it’s important to consider how they will log out.
Generally speaking, there are three use cases for you to consider:
I want to perform only a local logout
I want to log out both my application and the OIDC Provider, initiated by my application
I want to log out both my application and the OIDC Provider, initiated by the OIDC Provider
Local Logout
To perform a local logout, no special OIDC configuration is needed.
Spring Security automatically stands up a local logout endpoint, which you can configure through the logout()
DSL.
OpenID Connect 1.0 Client-Initiated Logout
OpenID Connect Session Management 1.0 allows the ability to log out the end user at the Provider by using the Client. One of the strategies available is RP-Initiated Logout.
If the OpenID Provider supports both Session Management and Discovery, the client can obtain the end_session_endpoint
URL
from the OpenID Provider’s Discovery Metadata.
You can do so by configuring the ClientRegistration
with the issuer-uri
, as follows:
spring:
security:
oauth2:
client:
registration:
okta:
client-id: okta-client-id
provider:
okta:
issuer-uri: https://dev-1234.oktapreview.com
Also, you should configure OidcClientInitiatedLogoutSuccessHandler
, which implements RP-Initiated Logout, as follows:
Java
Kotlin
@EnableWebSecurity
public class OAuth2LoginSecurityConfig {
@Autowired
private ClientRegistrationRepository clientRegistrationRepository;
http
.anyRequest().authenticated()
.oauth2Login(withDefaults())
.logout(logout -> logout
.logoutSuccessHandler(oidcLogoutSuccessHandler())
return http.build();
private LogoutSuccessHandler oidcLogoutSuccessHandler() {
OidcClientInitiatedLogoutSuccessHandler oidcLogoutSuccessHandler =
new OidcClientInitiatedLogoutSuccessHandler(this.clientRegistrationRepository);
// Sets the location that the End-User's User Agent will be redirected to
// after the logout has been performed at the Provider
oidcLogoutSuccessHandler.setPostLogoutRedirectUri("{baseUrl}");
return oidcLogoutSuccessHandler;
@EnableWebSecurity
@Autowired
private lateinit var clientRegistrationRepository: ClientRegistrationRepository
http {
authorizeHttpRequests {
oauth2Login { }
logout {
logoutSuccessHandler = oidcLogoutSuccessHandler()
return http.build()
private fun oidcLogoutSuccessHandler(): LogoutSuccessHandler {
val oidcLogoutSuccessHandler = OidcClientInitiatedLogoutSuccessHandler(clientRegistrationRepository)
By default, |
OpenID Connect 1.0 Back-Channel Logout
OpenID Connect Session Management 1.0 allows the ability to log out the end user at the Client by having the Provider make an API call to the Client. This is referred to as OIDC Back-Channel Logout.
To enable this, you can stand up the Back-Channel Logout endpoint in the DSL like so:
Java
Kotlin
OidcBackChannelLogoutHandler oidcLogoutHandler() {
return new OidcBackChannelLogoutHandler();
http
.authorizeHttpRequests((authorize) -> authorize
.oidcLogout((logout) -> logout
.backChannel(Customizer.withDefaults())
fun oidcLogoutHandler(): OidcBackChannelLogoutHandler {
return OidcBackChannelLogoutHandler()
http {
authorizeRequests {
oauth2Login { }
oidcLogout {
backChannel { }
return http.build()
Then, you need a way listen to events published by Spring Security to remove old OidcSessionInformation
entries, like so:
Java
Kotlin
public HttpSessionEventPublisher sessionEventPublisher() {
return new HttpSessionEventPublisher();
open fun sessionEventPublisher(): HttpSessionEventPublisher {
return HttpSessionEventPublisher()
This will make so that if HttpSession#invalidate
is called, then the session is also removed from memory.
And that’s it!
This will stand up the endpoint /logout/connect/back-channel/{registrationId}
which the OIDC Provider can request to invalidate a given session of an end user in your application.
oidcLogout requires that oauth2Login also be configured.
oidcLogout requires that the session cookie be called JSESSIONID in order to correctly log out each session through a backchannel.
Back-Channel Logout Architecture
Consider a ClientRegistration
whose identifier is registrationId
The overall flow for a Back-Channel logout is like this:
At login time, Spring Security correlates the ID Token, CSRF Token, and Provider Session ID (if any) to your application’s session id in its
OidcSessionRegistry
implementation. -
Then at logout time, your OIDC Provider makes an API call to
/logout/connect/back-channel/registrationId
including a Logout Token that indicates either thesub
(the End User) or thesid
(the Provider Session ID) to logout. -
Spring Security validates the token’s signature and claims.
If the token contains a
sid
claim, then only the Client’s session that correlates to that provider session is terminated. -
Otherwise, if the token contains a
sub
claim, then all that Client’s sessions for that End User are terminated.
Remember that Spring Security’s OIDC support is multi-tenant.
This means that it will only terminate sessions whose Client matches the aud claim in the Logout Token.
One notable part of this architecture’s implementation is that it propagates the incoming back-channel request internally for each corresponding session.
Initially, this may seem unnecessary.
However, recall that the Servlet API does not give direct access to the HttpSession
store.
By making an internal logout call, the corresponding session can now be invalidated.
Additionally, forging a logout call internally allows for each set of LogoutHandler
s to be run against that session and corresponding SecurityContext
Customizing the Session Logout Endpoint
With OidcBackChannelLogoutHandler
published, the session logout endpoint is {baseUrl}/logout/connect/back-channel/{registrationId}
If OidcBackChannelLogoutHandler
is not wired, then the URL is {baseUrl}/logout/connect/back-channel/{registrationId}
, which is not recommended since it requires passing a CSRF token, which can be challenging depending on the kind of repository your application uses.
In the event that you need to customize the endpoint, you can provide the URL as follows:
Java
Kotlin
http // ... .oidcLogout((oidc) -> oidc .backChannel((backChannel) -> backChannel .logoutUri("http://localhost:9000/logout/connect/back-channel/+{registrationId}+") ) );
http { oidcLogout { backChannel { logoutUri = "http://localhost:9000/logout/connect/back-channel/+{registrationId}+" } } }
Customizing the Session Logout Cookie Name
By default, the session logout endpoint uses the JSESSIONID
cookie to correlate the session to the corresponding OidcSessionInformation
However, the default cookie name in Spring Session is SESSION
You can configure Spring Session’s cookie name in the DSL like so:
Java
Kotlin
@Bean OidcBackChannelLogoutHandler oidcLogoutHandler(OidcSessionRegistry oidcSessionRegistry) { OidcBackChannelLogoutHandler logoutHandler = new OidcBackChannelLogoutHandler(oidcSessionRegistry); logoutHandler.setSessionCookieName("SESSION"); return logoutHandler; }
@Bean open fun oidcLogoutHandler(val sessionRegistry: OidcSessionRegistry): OidcBackChannelLogoutHandler { val logoutHandler = OidcBackChannelLogoutHandler(sessionRegistry) logoutHandler.setSessionCookieName("SESSION") return logoutHandler }
Customizing the OIDC Provider Session Registry
By default, Spring Security stores in-memory all links between the OIDC Provider session and the Client session.
There are a number of circumstances, like a clustered application, where it would be nice to store this instead in a separate location, like a database.
You can achieve this by configuring a custom OidcSessionRegistry
, like so:
Java
Kotlin
@Component
public final class MySpringDataOidcSessionRegistry implements OidcSessionRegistry {
private final OidcProviderSessionRepository sessions;
public void saveSessionInformation(OidcSessionInformation info) {
this.sessions.save(info);
public OidcSessionInformation removeSessionInformation(String clientSessionId) {
return this.sessions.removeByClientSessionId(clientSessionId);
public Iterable<OidcSessionInformation> removeSessionInformation(OidcLogoutToken token) {
return token.getSessionId() != null ?
this.sessions.removeBySessionIdAndIssuerAndAudience(...) :
this.sessions.removeBySubjectAndIssuerAndAudience(...);
@Component
class MySpringDataOidcSessionRegistry: OidcSessionRegistry {
val sessions: OidcProviderSessionRepository
fun saveSessionInformation(info: OidcSessionInformation) {
fun removeSessionInformation(clientSessionId: String): OidcSessionInformation {
fun removeSessionInformation(token: OidcLogoutToken): Iterable<OidcSessionInformation> {
