Web Migrations
Favor Relative URIs
When redirecting to a login endpoint, Spring Security has favored absolute URIs in the past. For example, if you set your login page like so:spring-doc.cn
http
    .formLogin((form) -> form.loginPage("/my-login"))
http {
    formLogin {
        loginPage = "/my-login"
<http ...>
    <form-login login-page="/my-login"/>
</http>
then when redirecting to /my-login Spring Security would use a Location: like the following:spring-doc.cn
302 Found
However, this is no longer necessary given that the RFC is was based on is now obsolete.spring-doc.cn
In Spring Security 7, this is changed to use a relative URI like so:spring-doc.cn
302 Found
Most applications will not notice a difference. However, in the event that this change causes problems, you can switch back to the Spring Security 6 behavior by setting the favorRelativeUrls value:spring-doc.cn
LoginUrlAuthenticationEntryPoint entryPoint = new LoginUrlAuthenticationEntryPoint("/my-login");
entryPoint.setFavorRelativeUris(false);
http
    .exceptionHandling((exceptions) -> exceptions.authenticaitonEntryPoint(entryPoint))
LoginUrlAuthenticationEntryPoint entryPoint = LoginUrlAuthenticationEntryPoint("/my-login")
http {
    exceptionHandling {
        authenticationEntryPoint = entryPoint
<http entry-point-ref="myEntryPoint">
</http>
<b:bean id="myEntryPoint" class="org.springframework.security.web.authentication.LoginUrlAuthenticationEntryPoint">
    <b:property name="favorRelativeUris" value="true"/>
</b:bean>
PortResolver
Spring Security uses an API called PortResolver to provide a workaround for a bug in Internet Explorer. The workaround is no longer necessary and can cause users problems in some scenarios. For this reason, Spring Security 7 will remove the PortResolver interface.spring-doc.cn
To prepare for this change, users should expose the PortResolver.NO_OP as a Bean named portResolver. This ensures that the PortResolver implementation that is used is a no-op (e.g. does nothing) which simulates the removal of PortResolver. An example configuration can be found below:spring-doc.cn
PortResolver portResolver() {
	return PortResolver.NO_OP;
open fun portResolver(): PortResolver {
<util:constant id="portResolver"
    static-field="org.springframework.security.web.PortResolver.NO_OP">
