This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.3! |
OAuth2
Spring Security provides comprehensive OAuth 2.0 support. This section discusses how to integrate OAuth 2.0 into your servlet based application.
Overview
Spring Security’s OAuth 2.0 support consists of two primary feature sets:
OAuth2 Login is a very powerful OAuth2 Client feature that deserves its own section in the reference documentation. However, it does not exist as a standalone feature and requires OAuth2 Client in order to function. |
These feature sets cover the resource server and client roles defined in the OAuth 2.0 Authorization Framework, while the authorization server role is covered by Spring Authorization Server, which is a separate project built on Spring Security.
The resource server and client roles in OAuth2 are typically represented by one or more server-side applications. Additionally, the authorization server role can be represented by one or more third parties (as is the case when centralizing identity management and/or authentication within an organization) -or- it can be represented by an application (as is the case with Spring Authorization Server).
For example, a typical OAuth2-based microservices architecture might consist of a single user-facing client application, several backend resource servers providing REST APIs and a third party authorization server for managing users and authentication concerns. It is also common to have a single application representing only one of these roles with the need to integrate with one or more third parties that are providing the other roles.
Spring Security handles these scenarios and more. The following sections cover the roles provided by Spring Security and contain examples for common scenarios.
OAuth2 Resource Server
This section contains a summary of OAuth2 Resource Server features with examples. See OAuth 2.0 Resource Server for complete reference documentation. |
To get started, add the spring-security-oauth2-resource-server
dependency to your project.
When using Spring Boot, add the following starter:
Gradle
Maven
implementation 'org.springframework.boot:spring-boot-starter-oauth2-resource-server'
<dependency>
<artifactId>spring-boot-starter-oauth2-resource-server</artifactId>
</dependency>
See Getting Spring Security for additional options when not using Spring Boot. |
Consider the following use cases for OAuth2 Resource Server:
I want to protect access to the API using OAuth2 (authorization server provides JWT or opaque access token)
I want to protect access to the API using a JWT (custom token)
Protect Access with an OAuth2 Access Token
It is very common to protect access to an API using OAuth2 access tokens. In most cases, Spring Security requires only minimal configuration to secure an application with OAuth2.
There are two types of Bearer
tokens supported by Spring Security which each use a different component for validation:
JWT support uses a
JwtDecoder
bean to validate signatures and decode tokens -
Opaque token support uses an
OpaqueTokenIntrospector
bean to introspect tokens
JWT Support
The following example configures a JwtDecoder
bean using Spring Boot configuration properties:
spring:
security:
oauth2:
resourceserver:
jwt:
issuer-uri: https://my-auth-server.com
When using Spring Boot, this is all that is required. The default arrangement provided by Spring Boot is equivalent to the following:
Java
Kotlin
@EnableWebSecurity
public class SecurityConfig {
public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
http
.authorizeHttpRequests((authorize) -> authorize
.anyRequest().authenticated()
.oauth2ResourceServer((oauth2) -> oauth2
.jwt(Customizer.withDefaults())
return http.build();
public JwtDecoder jwtDecoder() {
return JwtDecoders.fromIssuerLocation("https://my-auth-server.com");
import org.springframework.security.config.annotation.web.invoke
@EnableWebSecurity
fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
http {
authorizeHttpRequests {
oauth2ResourceServer {
jwt { }
return http.build()
fun jwtDecoder(): JwtDecoder {
Opaque Token Support
The following example configures an OpaqueTokenIntrospector
spring:
security:
oauth2:
resourceserver:
opaquetoken:
introspection-uri: https://my-auth-server.com/oauth2/introspect
client-id: my-client-id
client-secret: my-client-secret
Java
Kotlin
@EnableWebSecurity
http
.opaqueToken(Customizer.withDefaults())
public OpaqueTokenIntrospector opaqueTokenIntrospector() {
return new SpringOpaqueTokenIntrospector(
"https://my-auth-server.com/oauth2/introspect", "my-client-id", "my-client-secret");
@EnableWebSecurity
http {
opaqueToken { }
return http.build()
fun opaqueTokenIntrospector(): OpaqueTokenIntrospector {
return SpringOpaqueTokenIntrospector(
Protect Access with a custom JWT
It is a fairly common goal to protect access to an API using JWTs, particularly when the frontend is developed as a single-page application.
The OAuth2 Resource Server support in Spring Security can be used for any type of Bearer
token, including a custom JWT.
All that is required to protect an API using JWTs is a JwtDecoder
bean, which is used to validate signatures and decode tokens.
Spring Security will automatically use the provided bean to configure protection within the SecurityFilterChain
spring:
security:
oauth2:
resourceserver:
jwt:
public-key-location: classpath:my-public-key.pub
You can provide the public key as a classpath resource (called |
Java
Kotlin
@EnableWebSecurity
http
return NimbusJwtDecoder.withPublicKey(publicKey()).build();
private RSAPublicKey publicKey() {
@EnableWebSecurity
http {
jwt { }
return http.build()
private fun publicKey(): RSAPublicKey {
Spring Security does not provide an endpoint for minting tokens.
However, Spring Security does provide the |
OAuth2 Client
This section contains a summary of OAuth2 Client features with examples. See OAuth 2.0 Client and OAuth 2.0 Login for complete reference documentation. |
To get started, add the spring-security-oauth2-client
Gradle
Maven
implementation 'org.springframework.boot:spring-boot-starter-oauth2-client'
<dependency>
<artifactId>spring-boot-starter-oauth2-client</artifactId>
</dependency>
Consider the following use cases for OAuth2 Client:
I want to log users in using OAuth 2.0 or OpenID Connect 1.0
I want to use
RestClient
to obtain an access token for users in order to access a third-party API -
I want to use
WebClient
I want to do both (log users in and access a third-party API)
I want to use the
client_credentials
grant type to obtain a single token per application -
I want to enable an extension grant type
I want to customize an existing grant type
I want to customize token request parameters
I want to customize the
RestOperations
used by OAuth2 Client components
Log Users In with OAuth2
It is very common to require users to log in via OAuth2.
OpenID Connect 1.0 provides a special token called the id_token
which is designed to provide an OAuth2 Client with the ability to perform user identity verification and log users in.
In certain cases, OAuth2 can be used directly to log users in (as is the case with popular social login providers that do not implement OpenID Connect such as GitHub and Facebook).
The following example configures the application to act as an OAuth2 Client capable of logging users in with OAuth2 or OpenID Connect:
Java
Kotlin
@EnableWebSecurity
http
.oauth2Login(Customizer.withDefaults());
@EnableWebSecurity
http {
oauth2Login { }
return http.build()
In addition to the above configuration, the application requires at least one ClientRegistration
to be configured through the use of a ClientRegistrationRepository
bean.
The following example configures an InMemoryClientRegistrationRepository
spring:
security:
oauth2:
client:
registration:
my-oidc-client:
provider: my-oidc-provider
authorization-grant-type: authorization_code
scope: openid,profile
provider:
my-oidc-provider:
issuer-uri: https://my-oidc-provider.com
With the above configuration, the application now supports two additional endpoints:
The login endpoint (e.g.
/oauth2/authorization/my-oidc-client
) is used to initiate login and perform a redirect to the third party authorization server. -
The redirection endpoint (e.g.
/login/oauth2/code/my-oidc-client
) is used by the authorization server to redirect back to the client application, and will contain acode
parameter used to obtain anid_token
and/oraccess_token
via the access token request.
The presence of the |
Access Protected Resources
Making requests to a third party API that is protected by OAuth2 is a core use case of OAuth2 Client.
This is accomplished by authorizing a client (represented by the OAuth2AuthorizedClient
class in Spring Security) and accessing protected resources by placing a Bearer
token in the Authorization
header of an outbound request.
The following example configures the application to act as an OAuth2 Client capable of requesting protected resources from a third party API:
Java
Kotlin
@EnableWebSecurity
http
.oauth2Client(Customizer.withDefaults());
@EnableWebSecurity
http {
oauth2Client { }
return http.build()
The above example does not provide a way to log users in.
You can use any other login mechanism (such as |
bean.
spring:
security:
oauth2:
client:
registration:
my-oauth2-client:
provider: my-auth-server
scope: message.read,message.write
provider:
my-auth-server:
In addition to configuring Spring Security to support OAuth2 Client features, you will also need to decide how you will be accessing protected resources and configure your application accordingly.
Spring Security provides implementations of OAuth2AuthorizedClientManager
for obtaining access tokens that can be used to access protected resources.
Spring Security registers a default |
The easiest way to use an OAuth2AuthorizedClientManager
is via a ClientHttpRequestInterceptor
that intercepts requests through a RestClient
, which is already available when spring-web
is on the classpath.
The following example uses the default OAuth2AuthorizedClientManager
to configure a RestClient
capable of accessing protected resources by placing Bearer
tokens in the Authorization
header of each request:
RestClient
with ClientHttpRequestInterceptor
Java
Kotlin
public class RestClientConfig {
public RestClient restClient(OAuth2AuthorizedClientManager authorizedClientManager) {
OAuth2ClientHttpRequestInterceptor requestInterceptor =
new OAuth2ClientHttpRequestInterceptor(authorizedClientManager);
return RestClient.builder()
.requestInterceptor(requestInterceptor)
fun restClient(authorizedClientManager: OAuth2AuthorizedClientManager): RestClient {
val requestInterceptor = OAuth2ClientHttpRequestInterceptor(authorizedClientManager)
.build()
This configured RestClient
can be used as in the following example:
RestClient
to Access Protected Resources-
Java
Kotlin
import static org.springframework.security.oauth2.client.web.client.RequestAttributeClientRegistrationIdResolver.clientRegistrationId;
@RestController
public class MessagesController {
private final RestClient restClient;
public MessagesController(RestClient restClient) {
this.restClient = restClient;
@GetMapping("/messages")
public ResponseEntity<List<Message>> messages() {
Message[] messages = this.restClient.get()
.uri("http://localhost:8090/messages")
.attributes(clientRegistrationId("my-oauth2-client"))
.retrieve()
.body(Message[].class);
return ResponseEntity.ok(Arrays.asList(messages));
public record Message(String message) {
import org.springframework.security.oauth2.client.web.client.RequestAttributeClientRegistrationIdResolver.clientRegistrationId
import org.springframework.web.client.body
@RestController
class MessagesController(private val restClient: RestClient) {
fun messages(): ResponseEntity<List<Message>> {
val messages = restClient.get()
.retrieve()
.body<Array<Message>>()!!
.toList()
return ResponseEntity.ok(messages)
data class Message(val message: String)
Access Protected Resources with WebClient
Java
Kotlin
@EnableWebSecurity
http
@EnableWebSecurity
http {
oauth2Client { }
return http.build()
bean.
spring:
security:
oauth2:
client:
registration:
my-oauth2-client:
provider:
my-auth-server:
Instead of configuring a RestClient
, another way to use an OAuth2AuthorizedClientManager
is via an ExchangeFilterFunction
that intercepts requests through a WebClient
To use WebClient
, you will need to add the spring-webflux
dependency along with a reactive client implementation:
Gradle
Maven
implementation 'org.springframework:spring-webflux'
implementation 'io.projectreactor.netty:reactor-netty'
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-webflux</artifactId>
</dependency>
<dependency>
<groupId>io.projectreactor.netty</groupId>
<artifactId>reactor-netty</artifactId>
</dependency>
to configure a WebClient
WebClient
with ExchangeFilterFunction
Java
Kotlin
public class WebClientConfig {
public WebClient webClient(OAuth2AuthorizedClientManager authorizedClientManager) {
ServletOAuth2AuthorizedClientExchangeFilterFunction filter =
new ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager);
return WebClient.builder()
.apply(filter.oauth2Configuration())
fun webClient(authorizedClientManager: OAuth2AuthorizedClientManager): WebClient {
val filter = ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager)
.build()
This configured WebClient
WebClient
Java
Kotlin
import static org.springframework.security.oauth2.client.web.reactive.function.client.ServletOAuth2AuthorizedClientExchangeFilterFunction.clientRegistrationId;
@RestController
private final WebClient webClient;
public MessagesController(WebClient webClient) {
this.webClient = webClient;
return this.webClient.get()
.retrieve()
.toEntityList(Message.class)
.block();
import org.springframework.security.oauth2.client.web.reactive.function.client.ServletOAuth2AuthorizedClientExchangeFilterFunction.clientRegistrationId
@RestController
class MessagesController(private val webClient: WebClient) {
return webClient.get()
.retrieve()
.toEntityList<Message>()
.block()!!
Access Protected Resources for the Current User
When a user is logged in via OAuth2 or OpenID Connect, the authorization server may provide an access token that can be used directly to access protected resources.
This is convenient because it only requires a single ClientRegistration
to be configured for both use cases simultaneously.
This section combines Log Users In with OAuth2 and Access Protected Resources into a single configuration.
Other advanced scenarios exist, such as configuring one |
The following example configures the application to act as an OAuth2 Client capable of logging the user in and requesting protected resources from a third party API:
Java
Kotlin
@EnableWebSecurity
http
@EnableWebSecurity
http {
oauth2Login { }
oauth2Client { }
return http.build()
bean.
spring:
security:
oauth2:
client:
registration:
my-combined-client:
scope: openid,profile,message.read,message.write
provider:
my-auth-server:
The main difference between the previous examples (Log Users In with OAuth2, Access Protected Resources) and this one is what is configured via the |
RestClient
Java
Kotlin
requestInterceptor.setClientRegistrationIdResolver(clientRegistrationIdResolver());
private static ClientRegistrationIdResolver clientRegistrationIdResolver() {
return (request) -> {
Authentication authentication = SecurityContextHolder.getContext().getAuthentication();
return (authentication instanceof OAuth2AuthenticationToken principal)
? principal.getAuthorizedClientRegistrationId()
: null;
.build()
private fun clientRegistrationIdResolver(): OAuth2ClientHttpRequestInterceptor.ClientRegistrationIdResolver {
return OAuth2ClientHttpRequestInterceptor.ClientRegistrationIdResolver { request ->
val authentication = SecurityContextHolder.getContext().authentication
if (authentication is OAuth2AuthenticationToken) {
authentication.authorizedClientRegistrationId
} else {
null
RestClient
to Access Protected Resources (Current User)-
Java
Kotlin
@RestController
.retrieve()
@RestController
.retrieve()
.toList()
Unlike the previous example, notice that we do not need to tell Spring Security about the |
Use the Client Credentials Grant
This section focuses on additional considerations for the client credentials grant type. See Access Protected Resources for general setup and usage with all grant types. |
The client credentials grant allows a client to obtain an access_token
on behalf of itself.
The client credentials grant is a simple flow that does not involve a resource owner (i.e. a user).
It is important to note that typical use of the client credentials grant implies that any request (or user) can potentially obtain an access token and make protected resources requests to a resource server. Exercise caution when designing applications to ensure that users cannot make unauthorized requests since every request will be able to obtain an access token. |
When obtaining access tokens within a web application where users can log in, the default behavior of Spring Security is to obtain an access token per user.
By default, access tokens are scoped to the principal name of the current user which means every user will receive a unique access token. |
Clients using the client credentials grant typically require access tokens to be scoped to the application instead of to individual users so there is only one access token per application.
In order to scope access tokens to the application, you will need to set a strategy for resolving a custom principal name.
The following example does this by configuring a RestClient
with the RequestAttributePrincipalResolver
RestClient
for client_credentials
Java
Kotlin
requestInterceptor.setPrincipalResolver(new RequestAttributePrincipalResolver());
requestInterceptor.setPrincipalResolver(RequestAttributePrincipalResolver())
.build()
With the above configuration in place, a principal name can be specified for each request. The following example demonstrates how to scope access tokens to the application by specifying a principal name:
Java
Kotlin
import static org.springframework.security.oauth2.client.web.client.RequestAttributePrincipalResolver.principal;
@RestController
.attributes(principal("my-application"))
.retrieve()
import org.springframework.security.oauth2.client.web.client.RequestAttributePrincipalResolver.principal
@RestController
.retrieve()
.toList()
When specifying a principal name via attributes as in the above example, there will only be a single access token and it will be used for all requests. |
Enable an Extension Grant Type
A common use case involves enabling and/or configuring an extension grant type.
For example, Spring Security provides support for the jwt-bearer
and token-exchange
grant types, but does not enable them by default because they are not part of the core OAuth 2.0 specification.
With Spring Security 6.2 and later, we can simply publish a bean for one or more OAuth2AuthorizedClientProvider
and they will be picked up automatically.
The following example simply enables the jwt-bearer
grant type:
jwt-bearer
Grant Type-
Java
Kotlin
public OAuth2AuthorizedClientProvider jwtBearer() {
return new JwtBearerOAuth2AuthorizedClientProvider();
fun jwtBearer(): OAuth2AuthorizedClientProvider {
return JwtBearerOAuth2AuthorizedClientProvider()
A default OAuth2AuthorizedClientManager
will be published automatically by Spring Security when one is not already provided.
Any custom |
In order to achieve the above configuration prior to Spring Security 6.2, we had to publish this bean ourselves and ensure we re-enabled default grant types as well. To understand what is being configured behind the scenes, here’s what the configuration might have looked like:
jwt-bearer
Grant Type (prior to 6.2)-
Java
Kotlin
public OAuth2AuthorizedClientManager authorizedClientManager(
ClientRegistrationRepository clientRegistrationRepository,
OAuth2AuthorizedClientRepository authorizedClientRepository) {
OAuth2AuthorizedClientProvider authorizedClientProvider =
OAuth2AuthorizedClientProviderBuilder.builder()
.authorizationCode()
.refreshToken()
.clientCredentials()
.password()
.provider(new JwtBearerOAuth2AuthorizedClientProvider())
DefaultOAuth2AuthorizedClientManager authorizedClientManager =
new DefaultOAuth2AuthorizedClientManager(
clientRegistrationRepository, authorizedClientRepository);
authorizedClientManager.setAuthorizedClientProvider(authorizedClientProvider);
return authorizedClientManager;
fun authorizedClientManager(
clientRegistrationRepository: ClientRegistrationRepository,
authorizedClientRepository: OAuth2AuthorizedClientRepository
): OAuth2AuthorizedClientManager {
val authorizedClientProvider = OAuth2AuthorizedClientProviderBuilder.builder()
.refreshToken()
.password()
.provider(JwtBearerOAuth2AuthorizedClientProvider())
.build()
val authorizedClientManager = DefaultOAuth2AuthorizedClientManager(
Customize an Existing Grant Type
The ability to enable extension grant types by publishing a bean also provides the opportunity for customizing an existing grant type without the need to re-define the defaults.
For example, if we want to customize the clock skew of the OAuth2AuthorizedClientProvider
for the client_credentials
grant, we can simply publish a bean like so:
Java
Kotlin
public OAuth2AuthorizedClientProvider clientCredentials() {
ClientCredentialsOAuth2AuthorizedClientProvider authorizedClientProvider =
new ClientCredentialsOAuth2AuthorizedClientProvider();
authorizedClientProvider.setClockSkew(Duration.ofMinutes(5));
return authorizedClientProvider;
fun clientCredentials(): OAuth2AuthorizedClientProvider {
val authorizedClientProvider = ClientCredentialsOAuth2AuthorizedClientProvider()
Customize Token Request Parameters
The need to customize request parameters when obtaining an access token is fairly common.
For example, let’s say we want to add a custom audience
parameter to the token request because the provider requires this parameter for the authorization_code
grant.
With Spring Security 6.2 and later, we can simply publish a bean of type OAuth2AccessTokenResponseClient
with the generic type OAuth2AuthorizationCodeGrantRequest
and it will be used by Spring Security to configure OAuth2 Client components.
The following example customizes token request parameters for the authorization_code
grant without the DSL:
Java
Kotlin
public OAuth2AccessTokenResponseClient<OAuth2AuthorizationCodeGrantRequest> authorizationCodeAccessTokenResponseClient() {
OAuth2AuthorizationCodeGrantRequestEntityConverter requestEntityConverter =
new OAuth2AuthorizationCodeGrantRequestEntityConverter();
requestEntityConverter.addParametersConverter(parametersConverter());
DefaultAuthorizationCodeTokenResponseClient accessTokenResponseClient =
new DefaultAuthorizationCodeTokenResponseClient();
accessTokenResponseClient.setRequestEntityConverter(requestEntityConverter);
return accessTokenResponseClient;
private static Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> parametersConverter() {
return (grantRequest) -> {
MultiValueMap<String, String> parameters = new LinkedMultiValueMap<>();
parameters.set("audience", "xyz_value");
return parameters;
fun authorizationCodeAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2AuthorizationCodeGrantRequest> {
val requestEntityConverter = OAuth2AuthorizationCodeGrantRequestEntityConverter()
val accessTokenResponseClient = DefaultAuthorizationCodeTokenResponseClient()
private fun parametersConverter(): Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> {
return Converter<OAuth2AuthorizationCodeGrantRequest, MultiValueMap<String, String>> { grantRequest ->
LinkedMultiValueMap<String, String>().also { parameters ->
parameters["audience"] = "xyz_value"
Notice that we don’t need to customize the |
Prior to Spring Security 6.2, we had to ensure that this customization was applied for both OAuth2 Login (if we are using this feature) and OAuth2 Client components using the Spring Security DSL. To understand what is being configured behind the scenes, here’s what the configuration might have looked like:
Java
Kotlin
@EnableWebSecurity
http
.oauth2Login((oauth2Login) -> oauth2Login
.tokenEndpoint((tokenEndpoint) -> tokenEndpoint
.accessTokenResponseClient(accessTokenResponseClient)
.oauth2Client((oauth2Client) -> oauth2Client
.authorizationCodeGrant((authorizationCode) -> authorizationCode
@EnableWebSecurity
val tokenResponseClient = DefaultAuthorizationCodeTokenResponseClient()
tokenResponseClient.setRequestEntityConverter(requestEntityConverter)
http {
oauth2Login {
tokenEndpoint {
accessTokenResponseClient = tokenResponseClient
oauth2Client {
authorizationCodeGrant {
return http.build()
For other grant types we can publish additional OAuth2AccessTokenResponseClient
beans to override the defaults.
For example, to customize token requests for the client_credentials
grant we can publish the following bean:
Java
Kotlin
public OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> clientCredentialsAccessTokenResponseClient() {
OAuth2ClientCredentialsGrantRequestEntityConverter requestEntityConverter =
new OAuth2ClientCredentialsGrantRequestEntityConverter();
DefaultClientCredentialsTokenResponseClient accessTokenResponseClient =
new DefaultClientCredentialsTokenResponseClient();
private static Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>> parametersConverter() {
fun clientCredentialsAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2ClientCredentialsGrantRequest> {
val requestEntityConverter = OAuth2ClientCredentialsGrantRequestEntityConverter()
val accessTokenResponseClient = DefaultClientCredentialsTokenResponseClient()
private fun parametersConverter(): Converter<OAuth2ClientCredentialsGrantRequest, MultiValueMap<String, String>> {
Spring Security automatically resolves the following generic types of OAuth2AccessTokenResponseClient
beans:
(seeDefaultAuthorizationCodeTokenResponseClient
OAuth2RefreshTokenGrantRequest
(seeDefaultRefreshTokenTokenResponseClient
(seeDefaultClientCredentialsTokenResponseClient
OAuth2PasswordGrantRequest
(seeDefaultPasswordTokenResponseClient
JwtBearerGrantRequest
(seeDefaultJwtBearerTokenResponseClient
TokenExchangeGrantRequest
(seeDefaultTokenExchangeTokenResponseClient
Publishing a bean of type |
Customize the RestOperations
used by OAuth2 Client Components
Another common use case is the need to customize the RestOperations
used when obtaining an access token.
We might need to do this to customize processing of the response (via a custom HttpMessageConverter
) or to apply proxy settings for a corporate network (via a customized ClientHttpRequestFactory
With Spring Security 6.2 and later, we can simply publish beans of type OAuth2AccessTokenResponseClient
and Spring Security will configure and publish an OAuth2AuthorizedClientManager
bean for us.
The following example customizes the RestOperations
for all of the supported grant types:
RestOperations
for OAuth2 Client-
Java
Kotlin
accessTokenResponseClient.setRestOperations(restTemplate());
public OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> refreshTokenAccessTokenResponseClient() {
DefaultRefreshTokenTokenResponseClient accessTokenResponseClient =
new DefaultRefreshTokenTokenResponseClient();
public OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> passwordAccessTokenResponseClient() {
DefaultPasswordTokenResponseClient accessTokenResponseClient =
new DefaultPasswordTokenResponseClient();
public OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> jwtBearerAccessTokenResponseClient() {
DefaultJwtBearerTokenResponseClient accessTokenResponseClient =
new DefaultJwtBearerTokenResponseClient();
public OAuth2AccessTokenResponseClient<TokenExchangeGrantRequest> tokenExchangeAccessTokenResponseClient() {
DefaultTokenExchangeTokenResponseClient accessTokenResponseClient =
new DefaultTokenExchangeTokenResponseClient();
public RestTemplate restTemplate() {
fun refreshTokenAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2RefreshTokenGrantRequest> {
val accessTokenResponseClient = DefaultRefreshTokenTokenResponseClient()
fun passwordAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<OAuth2PasswordGrantRequest> {
val accessTokenResponseClient = DefaultPasswordTokenResponseClient()
fun jwtBearerAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<JwtBearerGrantRequest> {
val accessTokenResponseClient = DefaultJwtBearerTokenResponseClient()
fun tokenExchangeAccessTokenResponseClient(): OAuth2AccessTokenResponseClient<TokenExchangeGrantRequest> {
val accessTokenResponseClient = DefaultTokenExchangeTokenResponseClient()
fun restTemplate(): RestTemplate {
Prior to Spring Security 6.2, we had to ensure this customization was applied to both OAuth2 Login (if we are using this feature) and OAuth2 Client components.
We had to use both the Spring Security DSL (for the authorization_code
grant) and publish a bean of type OAuth2AuthorizedClientManager
for other grant types.
RestOperations
for OAuth2 Client (prior to 6.2)-
Java
Kotlin
@EnableWebSecurity
http
DefaultRefreshTokenTokenResponseClient refreshTokenAccessTokenResponseClient =
refreshTokenAccessTokenResponseClient.setRestOperations(restTemplate());
DefaultClientCredentialsTokenResponseClient clientCredentialsAccessTokenResponseClient =
clientCredentialsAccessTokenResponseClient.setRestOperations(restTemplate());
DefaultPasswordTokenResponseClient passwordAccessTokenResponseClient =
passwordAccessTokenResponseClient.setRestOperations(restTemplate());
DefaultJwtBearerTokenResponseClient jwtBearerAccessTokenResponseClient =
jwtBearerAccessTokenResponseClient.setRestOperations(restTemplate());
JwtBearerOAuth2AuthorizedClientProvider jwtBearerAuthorizedClientProvider =
jwtBearerAuthorizedClientProvider.setAccessTokenResponseClient(jwtBearerAccessTokenResponseClient);
DefaultTokenExchangeTokenResponseClient tokenExchangeAccessTokenResponseClient =
tokenExchangeAccessTokenResponseClient.setRestOperations(restTemplate());
TokenExchangeOAuth2AuthorizedClientProvider tokenExchangeAuthorizedClientProvider =
new TokenExchangeOAuth2AuthorizedClientProvider();
tokenExchangeAuthorizedClientProvider.setAccessTokenResponseClient(tokenExchangeAccessTokenResponseClient);
.refreshToken((refreshToken) -> refreshToken
.accessTokenResponseClient(refreshTokenAccessTokenResponseClient)
.clientCredentials((clientCredentials) -> clientCredentials
.accessTokenResponseClient(clientCredentialsAccessTokenResponseClient)
.password((password) -> password
.accessTokenResponseClient(passwordAccessTokenResponseClient)
.provider(jwtBearerAuthorizedClientProvider)
.provider(tokenExchangeAuthorizedClientProvider)
@EnableWebSecurity
tokenResponseClient.setRestOperations(restTemplate())
http {
oauth2Login {
tokenEndpoint {
oauth2Client {
return http.build()
clientRegistrationRepository: ClientRegistrationRepository?,
authorizedClientRepository: OAuth2AuthorizedClientRepository?
val refreshTokenAccessTokenResponseClient = DefaultRefreshTokenTokenResponseClient()
val clientCredentialsAccessTokenResponseClient = DefaultClientCredentialsTokenResponseClient()
val passwordAccessTokenResponseClient = DefaultPasswordTokenResponseClient()
val jwtBearerAccessTokenResponseClient = DefaultJwtBearerTokenResponseClient()
val jwtBearerAuthorizedClientProvider = JwtBearerOAuth2AuthorizedClientProvider()
val tokenExchangeAccessTokenResponseClient = DefaultTokenExchangeTokenResponseClient()
val tokenExchangeAuthorizedClientProvider = TokenExchangeOAuth2AuthorizedClientProvider()
.refreshToken { refreshToken ->
refreshToken.accessTokenResponseClient(refreshTokenAccessTokenResponseClient)
.clientCredentials { clientCredentials ->
clientCredentials.accessTokenResponseClient(clientCredentialsAccessTokenResponseClient)
.password { password ->
password.accessTokenResponseClient(passwordAccessTokenResponseClient)
.build()
Further Reading
The preceding sections introduced Spring Security’s support for OAuth2 with examples for common scenarios. You can read more about OAuth2 Client and Resource Server in the following sections of the reference documentation:
