EnableReactiveMethodSecurity
Spring Security supports method security by using Reactor’s Context, which is set up by ReactiveSecurityContextHolder. The following example shows how to retrieve the currently logged in user’s message:spring-doc.cn
For this example to work, the return type of the method must be a org.reactivestreams.Publisher (that is, a Mono or a Flux). This is necessary to integrate with Reactor’s Context.spring-doc.cn
EnableReactiveMethodSecurity with AuthorizationManager
In Spring Security 5.8, we can enable annotation-based security using the @EnableReactiveMethodSecurity(useAuthorizationManager=true) annotation on any @Configuration instance.spring-doc.cn
This improves upon @EnableReactiveMethodSecurity in a number of ways. @EnableReactiveMethodSecurity(useAuthorizationManager=true):spring-doc.cn
  1. Uses the simplified AuthorizationManager API instead of metadata sources, config attributes, decision managers, and voters. This simplifies reuse and customization.spring-doc.cn
  2. Supports reactive return types including Kotlin coroutines.spring-doc.cn
  3. Is built using native Spring AOP, removing abstractions and allowing you to use Spring AOP building blocks to customizespring-doc.cn
  4. Checks for conflicting annotations to ensure an unambiguous security configurationspring-doc.cn
  5. Complies with JSR-250spring-doc.cn
For earlier versions, please read about similar support with @EnableReactiveMethodSecurity.spring-doc.cn
For example, the following would enable Spring Security’s @PreAuthorize annotation:spring-doc.cn
Method Security Configuration
public class MethodSecurityConfig {
Adding an annotation to a method (on a class or interface) would then limit the access to that method accordingly. Spring Security’s native annotation support defines a set of attributes for the method. These will be passed to the various method interceptors, like AuthorizationManagerBeforeReactiveMethodInterceptor, for it to make the actual decision:spring-doc.cn
Method Security Annotation Usage
public interface BankService {
	@PreAuthorize("hasRole('USER')")
	Mono<Account> readAccount(Long id);
	Flux<Account> findAccounts();
	@PreAuthorize("@func.apply(#account)")
	Mono<Account> post(Account account, Double amount);
In this case hasRole refers to the method found in SecurityExpressionRoot that gets invoked by the SpEL evaluation engine.spring-doc.cn
@bean refers to a custom component you have defined, where apply can return Boolean or Mono<Boolean> to indicate the authorization decision. A bean like that might look something like this:spring-doc.cn
Method Security Reactive Boolean Expression
public Function<Account, Mono<Boolean>> func() {
    return (account) -> Mono.defer(() -> Mono.just(account.getId().equals(12)));
Method authorization is a combination of before- and after-method authorization.spring-doc.cn
Before-method authorization is performed before the method is invoked. If that authorization denies access, the method is not invoked, and an AccessDeniedException is thrown. After-method authorization is performed after the method is invoked, but before the method returns to the caller. If that authorization denies access, the value is not returned, and an AccessDeniedException is thrownspring-doc.cn
To recreate what adding @EnableReactiveMethodSecurity(useAuthorizationManager=true) does by default, you would publish the following configuration:spring-doc.cn
Full Pre-post Method Security Configuration
	BeanDefinitionRegistryPostProcessor aopConfig() {
		return AopConfigUtils::registerAutoProxyCreatorIfNecessary;
	@Role(BeanDefinition.ROLE_INFRASTRUCTURE)
	PreFilterAuthorizationReactiveMethodInterceptor preFilterInterceptor() {
		return new PreFilterAuthorizationReactiveMethodInterceptor();
	AuthorizationManagerBeforeReactiveMethodInterceptor preAuthorizeInterceptor() {
		return AuthorizationManagerBeforeReactiveMethodInterceptor.preAuthorize();
	AuthorizationManagerAfterReactiveMethodInterceptor postAuthorizeInterceptor() {
		return AuthorizationManagerAfterReactiveMethodInterceptor.postAuthorize();
	PostFilterAuthorizationReactiveMethodInterceptor postFilterInterceptor() {
		return new PostFilterAuthorizationReactiveMethodInterceptor();
Notice that Spring Security’s method security is built using Spring AOP.spring-doc.cn
Customizing Authorization
Spring Security’s @PreAuthorize, @PostAuthorize, @PreFilter, and @PostFilter ship with rich expression-based support.spring-doc.cn
Also, for role-based authorization, Spring Security adds a default ROLE_ prefix, which is uses when evaluating expressions like hasRole. You can configure the authorization rules to use a different prefix by exposing a GrantedAuthorityDefaults bean, like so:spring-doc.cn
Custom GrantedAuthorityDefaults
static GrantedAuthorityDefaults grantedAuthorityDefaults() {
	return new GrantedAuthorityDefaults("MYPREFIX_");
We expose GrantedAuthorityDefaults using a static method to ensure that Spring publishes it before it initializes Spring Security’s method security @Configuration classes. Since the GrantedAuthorityDefaults bean is part of internal workings of Spring Security, we should also expose it as an infrastructural bean effectively avoiding some warnings related to bean post-processing (see gh-14751).spring-doc.cn
Authorizing Methods Programmatically
As you’ve already seen, there are several ways that you can specify non-trivial authorization rules using Method Security SpEL expressions.spring-doc.cn
There are a number of ways that you can instead allow your logic to be Java-based instead of SpEL-based. This gives use access the entire Java language for increased testability and flow control.spring-doc.cn
Using a Custom Bean in SpEL
The first way to authorize a method programmatically is a two-step process.spring-doc.cn
First, declare a bean that has a method that takes a MethodSecurityExpressionOperations instance like the following:spring-doc.cn
@Component("authz")
public class AuthorizationLogic {
    public decide(MethodSecurityExpressionOperations operations): Mono<Boolean> {
        // ... authorization logic
@Component("authz")
open class AuthorizationLogic {
    fun decide(val operations: MethodSecurityExpressionOperations): Mono<Boolean> {
Then, reference that bean in your annotations in the following way:spring-doc.cn
@Controller
public class MyController {
    @PreAuthorize("@authz.decide(#root)")
    @GetMapping("/endpoint")
    public Mono<String> endpoint() {
@Controller
open class MyController {
    fun endpoint(): Mono<String> {
Spring Security will invoke the given method on that bean for each method invocation.spring-doc.cn
What’s nice about this is all your authorization logic is in a separate class that can be independently unit tested and verified for correctness. It also has access to the full Java language.spring-doc.cn
In addition to returning a Mono<Boolean>, you can also return Mono.empty() to indicate that the code abstains from making a decision.
If you want to include more information about the nature of the decision, you can instead return a custom AuthorizationDecision like this:spring-doc.cn
@Component("authz")
    public Mono<AuthorizationDecision> decide(MethodSecurityExpressionOperations operations) {
        return Mono.just(new MyAuthorizationDecision(false, details));
@Component("authz")
    fun decide(val operations: MethodSecurityExpressionOperations): Mono<AuthorizationDecision> {
        return Mono.just(MyAuthorizationDecision(false, details))
Or throw a custom AuthorizationDeniedException instance. Note, though, that returning an object is preferred as this doesn’t incur the expense of generating a stacktrace.spring-doc.cn
Then, you can access the custom details when you customize how the authorization result is handled.spring-doc.cn
Using a Custom Authorization Manager
The second way to authorize a method programmatically is to create a custom AuthorizationManager.spring-doc.cn
First, declare an authorization manager instance, perhaps like this one:spring-doc.cn
@Component
public class MyPreAuthorizeAuthorizationManager implements ReactiveAuthorizationManager<MethodInvocation> {
    public Mono<AuthorizationDecision> check(Supplier<Authentication> authentication, MethodInvocation invocation) {
@Component
class MyPreAuthorizeAuthorizationManager : ReactiveAuthorizationManager<MethodInvocation> {
    override fun check(authentication: Supplier<Authentication>, invocation: MethodInvocation): Mono<AuthorizationDecision> {
Then, publish the method interceptor with a pointcut that corresponds to when you want that ReactiveAuthorizationManager to run. For example, you could replace how @PreAuthorize and @PostAuthorize work like so:spring-doc.cn
Only @PreAuthorize and @PostAuthorize Configuration
@EnableMethodSecurity(prePostEnabled = false)
	Advisor preAuthorize(MyPreAuthorizeAuthorizationManager manager) {
		return AuthorizationManagerBeforeReactiveMethodInterceptor.preAuthorize(manager);
	Advisor postAuthorize(MyPostAuthorizeAuthorizationManager manager) {
		return AuthorizationManagerAfterReactiveMethodInterceptor.postAuthorize(manager);
	fun preAuthorize(val manager: MyPreAuthorizeAuthorizationManager) : Advisor {
	fun postAuthorize(val manager: MyPostAuthorizeAuthorizationManager) : Advisor {
You can place your interceptor in between Spring Security method interceptors using the order constants specified in AuthorizationInterceptorsOrder.spring-doc.cn
Customizing Expression Handling
Or, third, you can customize how each SpEL expression is handled. To do that, you can expose a custom MethodSecurityExpressionHandler, like so:spring-doc.cn
Custom MethodSecurityExpressionHandler
static MethodSecurityExpressionHandler methodSecurityExpressionHandler(RoleHierarchy roleHierarchy) {
	DefaultMethodSecurityExpressionHandler handler = new DefaultMethodSecurityExpressionHandler();
	handler.setRoleHierarchy(roleHierarchy);
	return handler;
companion object {
	fun methodSecurityExpressionHandler(val roleHierarchy: RoleHierarchy) : MethodSecurityExpressionHandler {
		val handler = DefaultMethodSecurityExpressionHandler()
		return handler
We expose MethodSecurityExpressionHandler using a static method to ensure that Spring publishes it before it initializes Spring Security’s method security @Configuration classesspring-doc.cn
You can also subclass DefaultMessageSecurityExpressionHandler to add your own custom authorization expressions beyond the defaults.spring-doc.cn
Authentication authentication = new TestingAuthenticationToken("user", "password", "ROLE_USER");
Mono<String> messageByUsername = ReactiveSecurityContextHolder.getContext()
	.map(SecurityContext::getAuthentication)
	.map(Authentication::getName)
	.flatMap(this::findMessageByUsername)
	// In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
	.contextWrite(ReactiveSecurityContextHolder.withAuthentication(authentication));
StepVerifier.create(messageByUsername)
	.expectNext("Hi user")
	.verifyComplete();
val authentication: Authentication = TestingAuthenticationToken("user", "password", "ROLE_USER")
val messageByUsername: Mono<String> = ReactiveSecurityContextHolder.getContext()
	.flatMap(this::findMessageByUsername) // In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
	.verifyComplete()
Where this::findMessageByUsername is defined as:spring-doc.cn
Mono<String> findMessageByUsername(String username) {
	return Mono.just("Hi " + username);
fun findMessageByUsername(username: String): Mono<String> {
	return Mono.just("Hi $username")
The following minimal method security configures method security in reactive applications:spring-doc.cn
public class SecurityConfig {
	public MapReactiveUserDetailsService userDetailsService() {
		User.UserBuilder userBuilder = User.withDefaultPasswordEncoder();
		UserDetails rob = userBuilder.username("rob")
			.password("rob")
			.roles("USER")
		UserDetails admin = userBuilder.username("admin")
			.password("admin")
			.roles("USER","ADMIN")
		return new MapReactiveUserDetailsService(rob, admin);
	fun userDetailsService(): MapReactiveUserDetailsService {
		val userBuilder: User.UserBuilder = User.withDefaultPasswordEncoder()
		val rob = userBuilder.username("rob")
			.password("rob")
			.roles("USER")
			.build()
		val admin = userBuilder.username("admin")
			.password("admin")
			.roles("USER", "ADMIN")
			.build()
		return MapReactiveUserDetailsService(rob, admin)
Consider the following class:spring-doc.cn
@Component
public class HelloWorldMessageService {
	@PreAuthorize("hasRole('ADMIN')")
	public Mono<String> findMessage() {
		return Mono.just("Hello World!");
@Component
	fun findMessage(): Mono<String> {
Alternatively, the following class uses Kotlin coroutines:spring-doc.cn
@Component
    suspend fun findMessage(): String {
        delay(10)
        return "Hello World!"
Combined with our configuration above, @PreAuthorize("hasRole('ADMIN')") ensures that findByMessage is invoked only by a user with the ADMIN role. Note that any of the expressions in standard method security work for @EnableReactiveMethodSecurity. However, at this time, we support only a return type of Boolean or boolean of the expression. This means that the expression must not block.spring-doc.cn
When integrating with WebFlux Security, the Reactor Context is automatically established by Spring Security according to the authenticated user:spring-doc.cn
@EnableWebFluxSecurity
	SecurityWebFilterChain springWebFilterChain(ServerHttpSecurity http) throws Exception {
		return http
			// Demonstrate that method security works
			// Best practice to use both for defense in depth
			.authorizeExchange(exchanges -> exchanges
				.anyExchange().permitAll()
			.httpBasic(withDefaults())
			.password("rob")
			.roles("USER")
			.password("admin")
	open fun springWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
		return http {
			authorizeExchange {
				authorize(anyExchange, permitAll)
			httpBasic { }
			.password("rob")
			.roles("USER")
			.build()
			.password("admin")
			.build()
You can find a complete sample in hellowebflux-method.spring-doc.cn
