Authentication Events
For each authentication that succeeds or fails, a AuthenticationSuccessEvent or AuthenticationFailureEvent, respectively, is fired.spring-doc.cn
To listen for these events, you must first publish an AuthenticationEventPublisher. Spring Security’s DefaultAuthenticationEventPublisher works fine for this purpose:spring-doc.cn
public AuthenticationEventPublisher authenticationEventPublisher
        (ApplicationEventPublisher applicationEventPublisher) {
    return new DefaultAuthenticationEventPublisher(applicationEventPublisher);
fun authenticationEventPublisher
        (applicationEventPublisher: ApplicationEventPublisher?): AuthenticationEventPublisher {
    return DefaultAuthenticationEventPublisher(applicationEventPublisher)
Then you can use Spring’s @EventListener support:spring-doc.cn
@Component
public class AuthenticationEvents {
	@EventListener
    public void onSuccess(AuthenticationSuccessEvent success) {
    @EventListener
    public void onFailure(AbstractAuthenticationFailureEvent failures) {
@Component
    @EventListener
    fun onSuccess(success: AuthenticationSuccessEvent?) {
    @EventListener
    fun onFailure(failures: AbstractAuthenticationFailureEvent?) {
While similar to AuthenticationSuccessHandler and AuthenticationFailureHandler, these are nice in that they can be used independently from the servlet API.spring-doc.cn
Adding Exception Mappings
By default, DefaultAuthenticationEventPublisher publishes an AuthenticationFailureEvent for the following events:spring-doc.cn
Exceptionspring-doc.cn
Eventspring-doc.cn
BadCredentialsExceptionspring-doc.cn
AuthenticationFailureBadCredentialsEventspring-doc.cn
UsernameNotFoundExceptionspring-doc.cn
AccountExpiredExceptionspring-doc.cn
AuthenticationFailureExpiredEventspring-doc.cn
ProviderNotFoundExceptionspring-doc.cn
AuthenticationFailureProviderNotFoundEventspring-doc.cn
DisabledExceptionspring-doc.cn
AuthenticationFailureDisabledEventspring-doc.cn
LockedExceptionspring-doc.cn
AuthenticationFailureLockedEventspring-doc.cn
AuthenticationServiceExceptionspring-doc.cn
AuthenticationFailureServiceExceptionEventspring-doc.cn
CredentialsExpiredExceptionspring-doc.cn
AuthenticationFailureCredentialsExpiredEventspring-doc.cn
InvalidBearerTokenExceptionspring-doc.cn
The publisher does an exact Exception match, which means that sub-classes of these exceptions do not also produce events.spring-doc.cn
To that end, you may want to supply additional mappings to the publisher through the setAdditionalExceptionMappings method:spring-doc.cn
    Map<Class<? extends AuthenticationException>,
        Class<? extends AbstractAuthenticationFailureEvent>> mapping =
            Collections.singletonMap(FooException.class, FooEvent.class);
    DefaultAuthenticationEventPublisher authenticationEventPublisher =
    authenticationEventPublisher.setAdditionalExceptionMappings(mapping);
    return authenticationEventPublisher;
    val mapping: Map<Class<out AuthenticationException>, Class<out AbstractAuthenticationFailureEvent>> =
            mapOf(Pair(FooException::class.java, FooEvent::class.java))
    val authenticationEventPublisher = DefaultAuthenticationEventPublisher(applicationEventPublisher)
Default Event
You can also supply a catch-all event to fire in the case of any AuthenticationException:spring-doc.cn
    authenticationEventPublisher.setDefaultAuthenticationFailureEvent
        (AbstractAuthenticationFailureEvent.class);
    authenticationEventPublisher.setDefaultAuthenticationFailureEvent(AbstractAuthenticationFailureEvent::class.java)
