This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.3! |
OAuth 2.0 Resource Server JWT
Minimal Dependencies for JWT
Most Resource Server support is collected into spring-security-oauth2-resource-server
However, the support for decoding and verifying JWTs is in spring-security-oauth2-jose
, meaning that both are necessary in order to have a working resource server that supports JWT-encoded Bearer Tokens.
Minimal Configuration for JWTs
When using Spring Boot, configuring an application as a resource server consists of two basic steps. First, include the needed dependencies and second, indicate the location of the authorization server.
Specifying the Authorization Server
In a Spring Boot application, to specify which authorization server to use, simply do:
spring:
security:
oauth2:
resourceserver:
jwt:
issuer-uri: https://idp.example.com/issuer
Where idp.example.com/issuer
is the value contained in the iss
claim for JWT tokens that the authorization server will issue.
Resource Server will use this property to further self-configure, discover the authorization server’s public keys, and subsequently validate incoming JWTs.
To use the issuer-uri property, it must also be true that one of idp.example.com/issuer/.well-known/openid-configuration , idp.example.com/.well-known/openid-configuration/issuer , or idp.example.com/.well-known/oauth-authorization-server/issuer is a supported endpoint for the authorization server.
This endpoint is referred to as a Provider Configuration endpoint or a Authorization Server Metadata endpoint.
And that’s it!
Startup Expectations
When this property and these dependencies are used, Resource Server will automatically configure itself to validate JWT-encoded Bearer Tokens.
It achieves this through a deterministic startup process:
Query the Provider Configuration or Authorization Server Metadata endpoint for the
jwks_url
property -
Query the
jwks_url
endpoint for supported algorithms -
Configure the validation strategy to query
jwks_url
for valid public keys of the algorithms found -
Configure the validation strategy to validate each JWTs
iss
claim againstidp.example.com
A consequence of this process is that the authorization server must be up and receiving requests in order for Resource Server to successfully start up.
If the authorization server is down when Resource Server queries it (given appropriate timeouts), then startup will fail. |
Runtime Expectations
Once the application is started up, Resource Server will attempt to process any request containing an Authorization: Bearer
header:
GET / HTTP/1.1
Authorization: Bearer some-token-value # Resource Server will process this
So long as this scheme is indicated, Resource Server will attempt to process the request according to the Bearer Token specification.
Given a well-formed JWT, Resource Server will:
Validate its signature against a public key obtained from the
jwks_url
endpoint during startup and matched against the JWT -
Validate the JWT’s
exp
andnbf
timestamps and the JWT’siss
claim, and -
Map each scope to an authority with the prefix
SCOPE_
As the authorization server makes available new keys, Spring Security will automatically rotate the keys used to validate JWTs. |
The resulting Authentication#getPrincipal
, by default, is a Spring Security Jwt
object, and Authentication#getName
maps to the JWT’s sub
property, if one is present.
From here, consider jumping to:
How JWT Authentication Works
Next, let’s see the architectural components that Spring Security uses to support JWT Authentication in servlet-based applications, like the one we just saw.
JwtAuthenticationProvider
is an AuthenticationProvider
implementation that leverages a JwtDecoder
and JwtAuthenticationConverter
to authenticate a JWT.
Let’s take a look at how JwtAuthenticationProvider
works within Spring Security.
The figure explains details of how the AuthenticationManager
in figures from Reading the Bearer Token works.
Usage The authentication
Filter
from Reading the Bearer Token passes a BearerTokenAuthenticationToken
to the AuthenticationManager
which is implemented by ProviderManager
The
ProviderManager
is configured to use an AuthenticationProvider of type JwtAuthenticationProvider
decodes, verifies, and validates the Jwt
using a JwtDecoder
then uses the JwtAuthenticationConverter
to convert the Jwt
into a Collection
of granted authorities.
When authentication is successful, the
Authentication
that is returned is of type JwtAuthenticationToken
and has a principal that is the Jwt
returned by the configured JwtDecoder
Ultimately, the returned JwtAuthenticationToken
will be set on the SecurityContextHolder
by the authentication Filter
Specifying the Authorization Server JWK Set Uri Directly
If the authorization server doesn’t support any configuration endpoints, or if Resource Server must be able to start up independently from the authorization server, then the jwk-set-uri
can be supplied as well:
spring:
security:
oauth2:
resourceserver:
jwt:
jwk-set-uri: https://idp.example.com/.well-known/jwks.json
The JWK Set uri is not standardized, but can typically be found in the authorization server’s documentation |
Consequently, Resource Server will not ping the authorization server at startup.
We still specify the issuer-uri
so that Resource Server still validates the iss
claim on incoming JWTs.
This property can also be supplied directly on the DSL. |
Supplying Audiences
As already seen, the issuer-uri
property validates the iss
claim; this is who sent the JWT.
Boot also has the audiences
property for validating the aud
claim; this is who the JWT was sent to.
A resource server’s audience can be indicated like so:
spring:
security:
oauth2:
resourceserver:
jwt:
audiences: https://my-resource-server.example.com
You can also add the aud validation programmatically, if needed.
The result will be that if the JWT’s iss
claim is not idp.example.com
, and its aud
claim does not contain my-resource-server.example.com
in its list, then validation will fail.
Overriding or Replacing Boot Auto Configuration
There are two @Bean
s that Spring Boot generates on Resource Server’s behalf.
The first is a SecurityFilterChain
that configures the app as a resource server. When including spring-security-oauth2-jose
, this SecurityFilterChain
looks like:
Java
Kotlin
http
.anyRequest().authenticated()
.oauth2ResourceServer((oauth2) -> oauth2.jwt(Customizer.withDefaults()));
return http.build();
http {
authorizeRequests {
oauth2ResourceServer {
jwt { }
return http.build()
If the application doesn’t expose a SecurityFilterChain
bean, then Spring Boot will expose the above default one.
Replacing this is as simple as exposing the bean within the application:
Java
Kotlin
import static org.springframework.security.oauth2.core.authorization.OAuth2AuthorizationManagers.hasScope;
@EnableWebSecurity
public class MyCustomSecurityConfiguration {
http
.requestMatchers("/messages/**").access(hasScope("message:read"))
.oauth2ResourceServer(oauth2 -> oauth2
.jwt(jwt -> jwt
.jwtAuthenticationConverter(myConverter())
import org.springframework.security.oauth2.core.authorization.OAuth2AuthorizationManagers.hasScope
@EnableWebSecurity
http {
authorizeRequests {
authorize("/messages/**", hasScope("message:read"))
jwt {
jwtAuthenticationConverter = myConverter()
return http.build()
The above requires the scope of message:read
for any URL that starts with /messages/
Methods on the oauth2ResourceServer
DSL will also override or replace auto configuration.
For example, the second @Bean
Spring Boot creates is a JwtDecoder
, which decodes String
tokens into validated instances of Jwt
Java
Kotlin
public JwtDecoder jwtDecoder() {
return JwtDecoders.fromIssuerLocation(issuerUri);
fun jwtDecoder(): JwtDecoder {
Calling JwtDecoders#fromIssuerLocation is what invokes the Provider Configuration or Authorization Server Metadata endpoint in order to derive the JWK Set Uri. |
If the application doesn’t expose a JwtDecoder
And its configuration can be overridden using jwkSetUri()
or replaced using decoder()
Or, if you’re not using Spring Boot at all, then both of these components - the filter chain and a JwtDecoder
can be specified in XML.
The filter chain is specified like so:
Xml
<http>
<intercept-uri pattern="/**" access="authenticated"/>
<oauth2-resource-server>
<jwt decoder-ref="jwtDecoder"/>
</oauth2-resource-server>
</http>
And the JwtDecoder
like so:
Xml
<bean id="jwtDecoder"
class="org.springframework.security.oauth2.jwt.JwtDecoders"
factory-method="fromIssuerLocation">
<constructor-arg value="${spring.security.oauth2.resourceserver.jwt.jwk-set-uri}"/>
</bean>
Using jwkSetUri()
An authorization server’s JWK Set Uri can be configured as a configuration property or it can be supplied in the DSL:
Java
Kotlin
Xml
@EnableWebSecurity
public class DirectlyConfiguredJwkSetUri {
http
.jwt(jwt -> jwt
.jwkSetUri("https://idp.example.com/.well-known/jwks.json")
@EnableWebSecurity
http {
authorizeRequests {
jwt {
jwkSetUri = "https://idp.example.com/.well-known/jwks.json"
return http.build()
<http>
<jwt jwk-set-uri="https://idp.example.com/.well-known/jwks.json"/>
</http>
Using jwkSetUri()
takes precedence over any configuration property.
Using decoder()
More powerful than jwkSetUri()
is decoder()
, which will completely replace any Boot auto configuration of JwtDecoder
Java
Kotlin
Xml
@EnableWebSecurity
public class DirectlyConfiguredJwtDecoder {
http
.jwt(jwt -> jwt
.decoder(myCustomDecoder())
@EnableWebSecurity
http {
authorizeRequests {
jwt {
jwtDecoder = myCustomDecoder()
return http.build()
<http>
<jwt decoder-ref="myCustomDecoder"/>
</http>
This is handy when deeper configuration, like validation, mapping, or request timeouts, is necessary.
Exposing a JwtDecoder
Or, exposing a JwtDecoder
has the same effect as decoder()
You can construct one with a jwkSetUri
like so:
Java
Kotlin
return NimbusJwtDecoder.withJwkSetUri(jwkSetUri).build();
or you can use the issuer and have NimbusJwtDecoder
look up the jwkSetUri
when build()
is invoked, like the following:
Java
Kotlin
return NimbusJwtDecoder.withIssuerLocation(issuer).build();
Or, if the defaults work for you, you can also use JwtDecoders
, which does the above in addition to configuring the decoder’s validator:
Java
Kotlin
public JwtDecoders jwtDecoder() {
return JwtDecoders.fromIssuerLocation(issuer);
fun jwtDecoder(): JwtDecoders {
Configuring Trusted Algorithms
By default, NimbusJwtDecoder
, and hence Resource Server, will only trust and verify tokens using RS256
You can customize this via Spring Boot, the NimbusJwtDecoder builder, or from the JWK Set response.
Via Spring Boot
The simplest way to set the algorithm is as a property:
spring:
security:
oauth2:
resourceserver:
jwt:
jws-algorithms: RS512
jwk-set-uri: https://idp.example.org/.well-known/jwks.json
Using a Builder
For greater power, though, we can use a builder that ships with NimbusJwtDecoder
Java
Kotlin
return NimbusJwtDecoder.withIssuerLocation(this.issuer)
.jwsAlgorithm(RS512).build();
Calling jwsAlgorithm
more than once will configure NimbusJwtDecoder
to trust more than one algorithm, like so:
Java
Kotlin
.jwsAlgorithm(RS512).jwsAlgorithm(ES512).build();
Or, you can call jwsAlgorithms
Java
Kotlin
.jwsAlgorithms(algorithms -> {
algorithms.add(RS512);
algorithms.add(ES512);
}).build();
.jwsAlgorithms {
it.add(RS512)
it.add(ES512)
}.build()
From JWK Set response
Since Spring Security’s JWT support is based off of Nimbus, you can use all it’s great features as well.
For example, Nimbus has a JWSKeySelector
implementation that will select the set of algorithms based on the JWK Set URI response.
You can use it to generate a NimbusJwtDecoder
like so:
Java
Kotlin
// makes a request to the JWK Set endpoint
JWSKeySelector<SecurityContext> jwsKeySelector =
JWSAlgorithmFamilyJWSKeySelector.fromJWKSetURL(this.jwkSetUrl);
DefaultJWTProcessor<SecurityContext> jwtProcessor =
new DefaultJWTProcessor<>();
jwtProcessor.setJWSKeySelector(jwsKeySelector);
return new NimbusJwtDecoder(jwtProcessor);
val jwsKeySelector: JWSKeySelector<SecurityContext> = JWSAlgorithmFamilyJWSKeySelector.fromJWKSetURL<SecurityContext>(this.jwkSetUrl)
val jwtProcessor: DefaultJWTProcessor<SecurityContext> = DefaultJWTProcessor()
jwtProcessor.jwsKeySelector = jwsKeySelector
return NimbusJwtDecoder(jwtProcessor)
Trusting a Single Asymmetric Key
Simpler than backing a Resource Server with a JWK Set endpoint is to hard-code an RSA public key. The public key can be provided via Spring Boot or by Using a Builder.
Via Spring Boot
Specifying a key via Spring Boot is quite simple. The key’s location can be specified like so:
spring:
security:
oauth2:
resourceserver:
jwt:
public-key-location: classpath:my-key.pub
Or, to allow for a more sophisticated lookup, you can post-process the RsaKeyConversionServicePostProcessor
Java
Kotlin
BeanFactoryPostProcessor conversionServiceCustomizer() {
return beanFactory ->
beanFactory.getBean(RsaKeyConversionServicePostProcessor.class)
.setResourceLoader(new CustomResourceLoader());
fun conversionServiceCustomizer(): BeanFactoryPostProcessor {
return BeanFactoryPostProcessor { beanFactory ->
beanFactory.getBean<RsaKeyConversionServicePostProcessor>()
.setResourceLoader(CustomResourceLoader())
Specify your key’s location:
key.location: hfds://my-key.pub
And then autowire the value:
Java
Kotlin
@Value("${key.location}")
RSAPublicKey key;
@Value("\${key.location}")
val key: RSAPublicKey? = null
Using a Builder
To wire an RSAPublicKey
directly, you can simply use the appropriate NimbusJwtDecoder
builder, like so:
Java
Kotlin
return NimbusJwtDecoder.withPublicKey(this.key).build();
Trusting a Single Symmetric Key
Using a single symmetric key is also simple.
You can simply load in your SecretKey
and use the appropriate NimbusJwtDecoder
builder, like so:
Java
Kotlin
return NimbusJwtDecoder.withSecretKey(this.key).build();
return NimbusJwtDecoder.withSecretKey(key).build()
Configuring Authorization
A JWT that is issued from an OAuth 2.0 Authorization Server will typically either have a scope
or scp
attribute, indicating the scopes (or authorities) it’s been granted, for example:
{ …, "scope" : "messages contacts"}
When this is the case, Resource Server will attempt to coerce these scopes into a list of granted authorities, prefixing each scope with the string "SCOPE_".
This means that to protect an endpoint or method with a scope derived from a JWT, the corresponding expressions should include this prefix:
Java
Kotlin
Xml
@EnableWebSecurity
http
.requestMatchers("/contacts/**").access(hasScope("contacts"))
.requestMatchers("/messages/**").access(hasScope("messages"))
import org.springframework.security.oauth2.core.authorization.OAuth2AuthorizationManagers.hasScope;
@EnableWebSecurity
http {
authorizeRequests {
authorize("/contacts/**", hasScope("contacts"))
authorize("/messages/**", hasScope("messages"))
jwt { }
return http.build()
<http>
<intercept-uri pattern="/contacts/**" access="hasAuthority('SCOPE_contacts')"/>
<intercept-uri pattern="/messages/**" access="hasAuthority('SCOPE_messages')"/>
<jwt jwk-set-uri="https://idp.example.org/.well-known/jwks.json"/>
</http>
Or similarly with method security:
Java
Kotlin
@PreAuthorize("hasAuthority('SCOPE_messages')")
public List<Message> getMessages(...) {}
fun getMessages(): List<Message> { }
Extracting Authorities Manually
However, there are a number of circumstances where this default is insufficient.
For example, some authorization servers don’t use the scope
attribute, but instead have their own custom attribute.
Or, at other times, the resource server may need to adapt the attribute or a composition of attributes into internalized authorities.
To this end, Spring Security ships with JwtAuthenticationConverter
, which is responsible for converting a Jwt
into an Authentication
By default, Spring Security will wire the JwtAuthenticationProvider
with a default instance of JwtAuthenticationConverter
As part of configuring a JwtAuthenticationConverter
, you can supply a subsidiary converter to go from Jwt
to a Collection
Let’s say that that your authorization server communicates authorities in a custom claim called authorities
In that case, you can configure the claim that JwtAuthenticationConverter
should inspect, like so:
Java
Kotlin
Xml
public JwtAuthenticationConverter jwtAuthenticationConverter() {
JwtGrantedAuthoritiesConverter grantedAuthoritiesConverter = new JwtGrantedAuthoritiesConverter();
grantedAuthoritiesConverter.setAuthoritiesClaimName("authorities");
JwtAuthenticationConverter jwtAuthenticationConverter = new JwtAuthenticationConverter();
jwtAuthenticationConverter.setJwtGrantedAuthoritiesConverter(grantedAuthoritiesConverter);
return jwtAuthenticationConverter;
fun jwtAuthenticationConverter(): JwtAuthenticationConverter {
val grantedAuthoritiesConverter = JwtGrantedAuthoritiesConverter()
val jwtAuthenticationConverter = JwtAuthenticationConverter()
<http>
jwt-authentication-converter-ref="jwtAuthenticationConverter"/>
</http>
<bean id="jwtAuthenticationConverter"
class="org.springframework.security.oauth2.server.resource.authentication.JwtAuthenticationConverter">
<property name="jwtGrantedAuthoritiesConverter" ref="jwtGrantedAuthoritiesConverter"/>
</bean>
<bean id="jwtGrantedAuthoritiesConverter"
class="org.springframework.security.oauth2.server.resource.authentication.JwtGrantedAuthoritiesConverter">
<property name="authoritiesClaimName" value="authorities"/>
</bean>
You can also configure the authority prefix to be different as well.
Instead of prefixing each authority with SCOPE_
, you can change it to ROLE_
like so:
Java
Kotlin
Xml
grantedAuthoritiesConverter.setAuthorityPrefix("ROLE_");
<http>
</http>
</bean>
<property name="authorityPrefix" value="ROLE_"/>
</bean>
Or, you can remove the prefix altogether by calling JwtGrantedAuthoritiesConverter#setAuthorityPrefix("")
For more flexibility, the DSL supports entirely replacing the converter with any class that implements Converter<Jwt, AbstractAuthenticationToken>
Java
Kotlin
static class CustomAuthenticationConverter implements Converter<Jwt, AbstractAuthenticationToken> {
public AbstractAuthenticationToken convert(Jwt jwt) {
return new CustomAuthenticationToken(jwt);
@EnableWebSecurity
public class CustomAuthenticationConverterConfig {
http
.jwt(jwt -> jwt
.jwtAuthenticationConverter(new CustomAuthenticationConverter())
internal class CustomAuthenticationConverter : Converter<Jwt, AbstractAuthenticationToken> {
override fun convert(jwt: Jwt): AbstractAuthenticationToken {
return CustomAuthenticationToken(jwt)
@EnableWebSecurity
http {
authorizeRequests {
jwt {
jwtAuthenticationConverter = CustomAuthenticationConverter()
return http.build()
Configuring Validation
Using minimal Spring Boot configuration, indicating the authorization server’s issuer uri, Resource Server will default to verifying the iss
claim as well as the exp
and nbf
timestamp claims.
In circumstances where validation needs to be customized, Resource Server ships with two standard validators and also accepts custom OAuth2TokenValidator
instances.
Customizing Timestamp Validation
JWT’s typically have a window of validity, with the start of the window indicated in the nbf
claim and the end indicated in the exp
claim.
However, every server can experience clock drift, which can cause tokens to appear expired to one server, but not to another. This can cause some implementation heartburn as the number of collaborating servers increases in a distributed system.
Resource Server uses JwtTimestampValidator
to verify a token’s validity window, and it can be configured with a clockSkew
to alleviate the above problem:
Java
Kotlin
NimbusJwtDecoder jwtDecoder = (NimbusJwtDecoder)
OAuth2TokenValidator<Jwt> withClockSkew = new DelegatingOAuth2TokenValidator<>(
new JwtTimestampValidator(Duration.ofSeconds(60)),
new JwtIssuerValidator(issuerUri));
jwtDecoder.setJwtValidator(withClockSkew);
return jwtDecoder;
val jwtDecoder: NimbusJwtDecoder = JwtDecoders.fromIssuerLocation(issuerUri) as NimbusJwtDecoder
val withClockSkew: OAuth2TokenValidator<Jwt> = DelegatingOAuth2TokenValidator(
return jwtDecoder
By default, Resource Server configures a clock skew of 60 seconds. |
Configuring RFC 9068 Validation
If you need to require tokens that meet RFC 9068, you can configure validation in the following way:
Java
Kotlin
NimbusJwtDecoder jwtDecoder = NimbusJwtDecoder.withIssuerLocation(issuerUri)
.validateTypes(false).build();
jwtDecoder.setJwtValidator(JwtValidators.createAtJwtValidator()
.audience("https://audience.example.org")
.clientId("client-identifier")
.issuer("https://issuer.example.org").build());
return jwtDecoder;
val jwtDecoder = NimbusJwtDecoder.withIssuerLocation(issuerUri)
return jwtDecoder
Configuring a Custom Validator
Adding a check for the aud
claim is simple with the OAuth2TokenValidator
API:
Java
Kotlin
OAuth2TokenValidator<Jwt> audienceValidator() {
return new JwtClaimValidator<List<String>>(AUD, aud -> aud.contains("messaging"));
fun audienceValidator(): OAuth2TokenValidator<Jwt?> {
return JwtClaimValidator<List<String>>(AUD) { aud -> aud.contains("messaging") }
Or, for more control you can implement your own OAuth2TokenValidator
Java
Kotlin
static class AudienceValidator implements OAuth2TokenValidator<Jwt> {
OAuth2Error error = new OAuth2Error("custom_code", "Custom error message", null);
public OAuth2TokenValidatorResult validate(Jwt jwt) {
if (jwt.getAudience().contains("messaging")) {
return OAuth2TokenValidatorResult.success();
} else {
return OAuth2TokenValidatorResult.failure(error);
return new AudienceValidator();
internal class AudienceValidator : OAuth2TokenValidator<Jwt> {
var error: OAuth2Error = OAuth2Error("custom_code", "Custom error message", null)
override fun validate(jwt: Jwt): OAuth2TokenValidatorResult {
return if (jwt.audience.contains("messaging")) {
} else {
fun audienceValidator(): OAuth2TokenValidator<Jwt> {
return AudienceValidator()
Then, to add into a resource server, it’s a matter of specifying the JwtDecoder
instance:
Java
Kotlin
OAuth2TokenValidator<Jwt> audienceValidator = audienceValidator();
OAuth2TokenValidator<Jwt> withIssuer = JwtValidators.createDefaultWithIssuer(issuerUri);
OAuth2TokenValidator<Jwt> withAudience = new DelegatingOAuth2TokenValidator<>(withIssuer, audienceValidator);
jwtDecoder.setJwtValidator(withAudience);
return jwtDecoder;
val audienceValidator = audienceValidator()
val withIssuer: OAuth2TokenValidator<Jwt> = JwtValidators.createDefaultWithIssuer(issuerUri)
val withAudience: OAuth2TokenValidator<Jwt> = DelegatingOAuth2TokenValidator(withIssuer, audienceValidator)
return jwtDecoder
As stated earlier, you can instead configure aud validation in Boot.
Configuring Claim Set Mapping
Spring Security uses the Nimbus library for parsing JWTs and validating their signatures. Consequently, Spring Security is subject to Nimbus’s interpretation of each field value and how to coerce each into a Java type.
For example, because Nimbus remains Java 7 compatible, it doesn’t use Instant
to represent timestamp fields.
And it’s entirely possible to use a different library or for JWT processing, which may make its own coercion decisions that need adjustment.
Or, quite simply, a resource server may want to add or remove claims from a JWT for domain-specific reasons.
For these purposes, Resource Server supports mapping the JWT claim set with MappedJwtClaimSetConverter
Customizing the Conversion of a Single Claim
By default, MappedJwtClaimSetConverter
will attempt to coerce claims into the following types:
Claim |
Java Type |
An individual claim’s conversion strategy can be configured using MappedJwtClaimSetConverter.withDefaults
Java
Kotlin
NimbusJwtDecoder jwtDecoder = NimbusJwtDecoder.withIssuerLocation(issuer).build();
MappedJwtClaimSetConverter converter = MappedJwtClaimSetConverter
.withDefaults(Collections.singletonMap("sub", this::lookupUserIdBySub));
jwtDecoder.setClaimSetConverter(converter);
return jwtDecoder;
val jwtDecoder = NimbusJwtDecoder.withIssuerLocation(issuer).build()
val converter = MappedJwtClaimSetConverter
.withDefaults(mapOf("sub" to this::lookupUserIdBySub))
return jwtDecoder
This will keep all the defaults, except it will override the default claim converter for sub
Adding a Claim
can also be used to add a custom claim, for example, to adapt to an existing system:
Java
Kotlin
MappedJwtClaimSetConverter.withDefaults(Collections.singletonMap("custom", custom -> "value"));
MappedJwtClaimSetConverter.withDefaults(mapOf("custom" to Converter<Any, String> { "value" }))
Removing a Claim
And removing a claim is also simple, using the same API:
Java
Kotlin
MappedJwtClaimSetConverter.withDefaults(Collections.singletonMap("legacyclaim", legacy -> null));
MappedJwtClaimSetConverter.withDefaults(mapOf("legacyclaim" to Converter<Any, Any> { null }))
Renaming a Claim
In more sophisticated scenarios, like consulting multiple claims at once or renaming a claim, Resource Server accepts any class that implements Converter<Map<String, Object>, Map<String,Object>>
Java
Kotlin
public class UsernameSubClaimAdapter implements Converter<Map<String, Object>, Map<String, Object>> {
private final MappedJwtClaimSetConverter delegate =
MappedJwtClaimSetConverter.withDefaults(Collections.emptyMap());
public Map<String, Object> convert(Map<String, Object> claims) {
Map<String, Object> convertedClaims = this.delegate.convert(claims);
String username = (String) convertedClaims.get("user_name");
convertedClaims.put("sub", username);
return convertedClaims;
class UsernameSubClaimAdapter : Converter<Map<String, Any?>, Map<String, Any?>> {
private val delegate = MappedJwtClaimSetConverter.withDefaults(Collections.emptyMap())
override fun convert(claims: Map<String, Any?>): Map<String, Any?> {
val convertedClaims = delegate.convert(claims)
val username = convertedClaims["user_name"] as String
convertedClaims["sub"] = username
And then, the instance can be supplied like normal:
Java
Kotlin
jwtDecoder.setClaimSetConverter(new UsernameSubClaimAdapter());
return jwtDecoder;
val jwtDecoder: NimbusJwtDecoder = NimbusJwtDecoder.withIssuerLocation(issuer).build()
jwtDecoder.setClaimSetConverter(UsernameSubClaimAdapter())
return jwtDecoder
Configuring Timeouts
By default, Resource Server uses connection and socket timeouts of 30 seconds each for coordinating with the authorization server.
This may be too short in some scenarios. Further, it doesn’t take into account more sophisticated patterns like back-off and discovery.
To adjust the way in which Resource Server connects to the authorization server, NimbusJwtDecoder
accepts an instance of RestOperations
Java
Kotlin
public JwtDecoder jwtDecoder(RestTemplateBuilder builder) {
RestOperations rest = builder
.setConnectTimeout(Duration.ofSeconds(60))
.setReadTimeout(Duration.ofSeconds(60))
NimbusJwtDecoder jwtDecoder = NimbusJwtDecoder.withIssuerLocation(issuer).restOperations(rest).build();
return jwtDecoder;
fun jwtDecoder(builder: RestTemplateBuilder): JwtDecoder {
val rest: RestOperations = builder
.build()
return NimbusJwtDecoder.withIssuerLocation(issuer).restOperations(rest).build()
Also by default, Resource Server caches in-memory the authorization server’s JWK set for 5 minutes, which you may want to adjust. Further, it doesn’t take into account more sophisticated caching patterns like eviction or using a shared cache.
To adjust the way in which Resource Server caches the JWK set, NimbusJwtDecoder
accepts an instance of Cache
Java
Kotlin
public JwtDecoder jwtDecoder(CacheManager cacheManager) {
.cache(cacheManager.getCache("jwks"))
fun jwtDecoder(cacheManager: CacheManager): JwtDecoder {
.build()
When given a Cache
, Resource Server will use the JWK Set Uri as the key and the JWK Set JSON as the value.
Spring isn’t a cache provider, so you’ll need to make sure to include the appropriate dependencies, like spring-boot-starter-cache and your favorite caching provider.
Whether it’s socket or cache timeouts, you may instead want to work with Nimbus directly.
To do so, remember that NimbusJwtDecoder ships with a constructor that takes Nimbus’s JWTProcessor .
