OAuth 2.0 Resource Server Opaque Token
Minimal Dependencies for Introspection
As described in Minimal Dependencies for JWT, most Resource Server support is collected in spring-security-oauth2-resource-server. However, unless you provide a custom ReactiveOpaqueTokenIntrospector, the Resource Server falls back to ReactiveOpaqueTokenIntrospector. This means that both spring-security-oauth2-resource-server and oauth2-oidc-sdk are necessary to have a working minimal Resource Server that supports opaque Bearer Tokens. See spring-security-oauth2-resource-server in order to determine the correct version for oauth2-oidc-sdk.spring-doc.cn
Minimal Configuration for Introspection
Typically, you can verify an opaque token with an OAuth 2.0 Introspection Endpoint, hosted by the authorization server. This can be handy when revocation is a requirement.spring-doc.cn
When using Spring Boot, configuring an application as a resource server that uses introspection consists of two steps:spring-doc.cn
  1. Include the needed dependencies.spring-doc.cn
  2. Indicate the introspection endpoint details.spring-doc.cn
Specifying the Authorization Server
You can specify where the introspection endpoint is:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        opaque-token:
          introspection-uri: https://idp.example.com/introspect
          client-id: client
          client-secret: secret
Where idp.example.com/introspect is the introspection endpoint hosted by your authorization server and client-id and client-secret are the credentials needed to hit that endpoint.spring-doc.cn
Resource Server uses these properties to further self-configure and subsequently validate incoming JWTs.spring-doc.cn
If the authorization server responses that the token is valid, then it is.spring-doc.cn
Startup Expectations
When this property and these dependencies are used, Resource Server automatically configures itself to validate Opaque Bearer Tokens.spring-doc.cn
This startup process is quite a bit simpler than for JWTs, since no endpoints need to be discovered and no additional validation rules get added.spring-doc.cn
Runtime Expectations
Once the application has started, Resource Server tries to process any request containing an Authorization: Bearer header:spring-doc.cn
GET / HTTP/1.1
Authorization: Bearer some-token-value # Resource Server will process this
So long as this scheme is indicated, Resource Server tries to process the request according to the Bearer Token specification.spring-doc.cn
Given an Opaque Token, Resource Server:spring-doc.cn
  1. Queries the provided introspection endpoint by using the provided credentials and the token.spring-doc.cn
  2. Inspects the response for an { 'active' : true } attribute.spring-doc.cn
  3. Maps each scope to an authority with a prefix of SCOPE_.spring-doc.cn
By default, the resulting Authentication#getPrincipal is a Spring Security OAuth2AuthenticatedPrincipal object, and Authentication#getName maps to the token’s sub property, if one is present.spring-doc.cn
From here, you may want to jump to:spring-doc.cn
Looking Up Attributes After Authentication
Once a token is authenticated, an instance of BearerTokenAuthentication is set in the SecurityContext.spring-doc.cn
This means that it is available in @Controller methods when you use @EnableWebFlux in your configuration:spring-doc.cn
@GetMapping("/foo")
public Mono<String> foo(BearerTokenAuthentication authentication) {
    return Mono.just(authentication.getTokenAttributes().get("sub") + " is the subject");
@GetMapping("/foo")
fun foo(authentication: BearerTokenAuthentication): Mono<String> {
    return Mono.just(authentication.tokenAttributes["sub"].toString() + " is the subject")
Since BearerTokenAuthentication holds an OAuth2AuthenticatedPrincipal, that also means that it’s available to controller methods, too:spring-doc.cn
@GetMapping("/foo")
public Mono<String> foo(@AuthenticationPrincipal OAuth2AuthenticatedPrincipal principal) {
    return Mono.just(principal.getAttribute("sub") + " is the subject");
@GetMapping("/foo")
fun foo(@AuthenticationPrincipal principal: OAuth2AuthenticatedPrincipal): Mono<String> {
    return Mono.just(principal.getAttribute<Any>("sub").toString() + " is the subject")
Looking Up Attributes with SpEL
You can access attributes with the Spring Expression Language (SpEL).spring-doc.cn
For example, if you use @EnableReactiveMethodSecurity so that you can use @PreAuthorize annotations, you can do:spring-doc.cn
@PreAuthorize("principal?.attributes['sub'] = 'foo'")
public Mono<String> forFoosEyesOnly() {
    return Mono.just("foo");
@PreAuthorize("principal.attributes['sub'] = 'foo'")
fun forFoosEyesOnly(): Mono<String> {
Overriding or Replacing Boot Auto Configuration
Spring Boot generates two @Bean instances for Resource Server.spring-doc.cn
The first is a SecurityWebFilterChain that configures the application as a resource server. When you use an Opaque Token, this SecurityWebFilterChain looks like:spring-doc.cn
SecurityWebFilterChain springSecurityFilterChain(ServerHttpSecurity http) {
	http
		.authorizeExchange(exchanges -> exchanges
		.oauth2ResourceServer(ServerHttpSecurity.OAuth2ResourceServerSpec::opaqueToken)
	return http.build();
fun springSecurityFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
    return http {
        authorizeExchange {
        oauth2ResourceServer {
            opaqueToken { }
If the application does not expose a SecurityWebFilterChain bean, Spring Boot exposes the default bean (shown in the preceding listing).spring-doc.cn
You can replace it by exposing the bean within the application:spring-doc.cn
Replacing SecurityWebFilterChain
import static org.springframework.security.oauth2.core.authorization.OAuth2ReactiveAuthorizationManagers.hasScope;
@EnableWebFluxSecurity
public class MyCustomSecurityConfiguration {
        http
                .pathMatchers("/messages/**").access(hasScope("message:read"))
            .oauth2ResourceServer(oauth2 -> oauth2
                .opaqueToken(opaqueToken -> opaqueToken
                    .introspector(myIntrospector())
import org.springframework.security.oauth2.core.authorization.OAuth2ReactiveAuthorizationManagers.hasScope
    return http {
        authorizeExchange {
            authorize("/messages/**", hasScope("message:read"))
            opaqueToken {
                introspector = myIntrospector()
The preceding example requires the scope of message:read for any URL that starts with /messages/.spring-doc.cn
Methods on the oauth2ResourceServer DSL also override or replace auto configuration.spring-doc.cn
For example, the second @Bean Spring Boot creates is a ReactiveOpaqueTokenIntrospector, which decodes String tokens into validated instances of OAuth2AuthenticatedPrincipal:spring-doc.cn
public ReactiveOpaqueTokenIntrospector introspector() {
    return SpringReactiveOpaqueTokenIntrospector.withIntrospectionUri(introspectionUri)
        .clientId(clientId).clientSecret(clientSecret).build();
fun introspector(): ReactiveOpaqueTokenIntrospector {
If the application does not expose a ReactiveOpaqueTokenIntrospector bean, Spring Boot exposes the default one (shown in the preceding listing).spring-doc.cn
You can override its configuration by using introspectionUri() and introspectionClientCredentials() or replace it by using introspector().spring-doc.cn
Using introspectionUri()
You can configure an authorization server’s Introspection URI as a configuration property, or you can supply in the DSL:spring-doc.cn
public class DirectlyConfiguredIntrospectionUri {
        http
                    .introspectionUri("https://idp.example.com/introspect")
                    .introspectionClientCredentials("client", "secret")
    return http {
        authorizeExchange {
            opaqueToken {
                introspectionUri = "https://idp.example.com/introspect"
Using introspectionUri() takes precedence over any configuration property.spring-doc.cn
Using introspector()
introspector() is more powerful than introspectionUri(). It completely replaces any Boot auto-configuration of ReactiveOpaqueTokenIntrospector:spring-doc.cn
public class DirectlyConfiguredIntrospector {
        http
                    .introspector(myCustomIntrospector())
    return http {
        authorizeExchange {
            opaqueToken {
                introspector = myCustomIntrospector()
This is handy when deeper configuration, such as authority mappingor JWT revocation, is necessary.spring-doc.cn
Exposing a ReactiveOpaqueTokenIntrospector @Bean
Or, exposing a ReactiveOpaqueTokenIntrospector @Bean has the same effect as introspector():spring-doc.cn
Configuring Authorization
An OAuth 2.0 Introspection endpoint typically returns a scope attribute, indicating the scopes (or authorities) it has been granted — for example:spring-doc.cn
{ ..., "scope" : "messages contacts"}
When this is the case, Resource Server tries to coerce these scopes into a list of granted authorities, prefixing each scope with a string: SCOPE_.spring-doc.cn
This means that, to protect an endpoint or method with a scope derived from an Opaque Token, the corresponding expressions should include this prefix:spring-doc.cn
public class MappedAuthorities {
        http
            .authorizeExchange(exchange -> exchange
                .pathMatchers("/contacts/**").access(hasScope("contacts"))
                .pathMatchers("/messages/**").access(hasScope("messages"))
            .oauth2ResourceServer(ServerHttpSecurity.OAuth2ResourceServerSpec::opaqueToken);
    return http {
        authorizeExchange {
            authorize("/contacts/**", hasScope("contacts"))
            authorize("/messages/**", hasScope("messages"))
            opaqueToken { }
You can do something similar with method security:spring-doc.cn
@PreAuthorize("hasAuthority('SCOPE_messages')")
public Flux<Message> getMessages(...) {}
fun getMessages(): Flux<Message> { }
Extracting Authorities Manually
By default, Opaque Token support extracts the scope claim from an introspection response and parses it into individual GrantedAuthority instances.spring-doc.cn
Consider the following example:spring-doc.cn
    "active" : true,
    "scope" : "message:read message:write"
If the introspection response were as the preceding example shows, Resource Server would generate an Authentication with two authorities, one for message:read and the other for message:write.spring-doc.cn
You can customize behavior by using a custom ReactiveOpaqueTokenIntrospector that looks at the attribute set and converts in its own way:spring-doc.cn
public class CustomAuthoritiesOpaqueTokenIntrospector implements ReactiveOpaqueTokenIntrospector {
    private ReactiveOpaqueTokenIntrospector delegate = SpringReactiveOpaqueTokenIntrospector
            .withIntrospectionUri("https://idp.example.org/introspect")
            .clientId("client").clientSecret("secret").build();
    public Mono<OAuth2AuthenticatedPrincipal> introspect(String token) {
        return this.delegate.introspect(token)
                .map(principal -> new DefaultOAuth2AuthenticatedPrincipal(
                        principal.getName(), principal.getAttributes(), extractAuthorities(principal)));
    private Collection<GrantedAuthority> extractAuthorities(OAuth2AuthenticatedPrincipal principal) {
        List<String> scopes = principal.getAttribute(OAuth2IntrospectionClaimNames.SCOPE);
        return scopes.stream()
                .map(SimpleGrantedAuthority::new)
                .collect(Collectors.toList());
class CustomAuthoritiesOpaqueTokenIntrospector : ReactiveOpaqueTokenIntrospector {
    private val delegate: ReactiveOpaqueTokenIntrospector = SpringReactiveOpaqueTokenIntrospector
    override fun introspect(token: String): Mono<OAuth2AuthenticatedPrincipal> {
        return delegate.introspect(token)
                .map { principal: OAuth2AuthenticatedPrincipal ->
                            principal.name, principal.attributes, extractAuthorities(principal))
    private fun extractAuthorities(principal: OAuth2AuthenticatedPrincipal): Collection<GrantedAuthority> {
        val scopes = principal.getAttribute<List<String>>(OAuth2IntrospectionClaimNames.SCOPE)
        return scopes
                .map { SimpleGrantedAuthority(it) }
Thereafter, you can configure this custom introspector by exposing it as a @Bean:spring-doc.cn
    return new CustomAuthoritiesOpaqueTokenIntrospector();
    return CustomAuthoritiesOpaqueTokenIntrospector()
Using Introspection with JWTs
A common question is whether or not introspection is compatible with JWTs. Spring Security’s Opaque Token support has been designed to not care about the format of the token. It gladly passes any token to the provided introspection endpoint.spring-doc.cn
So, suppose you need to check with the authorization server on each request, in case the JWT has been revoked.spring-doc.cn
Even though you are using the JWT format for the token, your validation method is introspection, meaning you would want to do:spring-doc.cn
spring:
  security:
    oauth2:
      resourceserver:
        opaque-token:
          introspection-uri: https://idp.example.org/introspection
          client-id: client
In this case, the resulting Authentication would be BearerTokenAuthentication. Any attributes in the corresponding OAuth2AuthenticatedPrincipal would be whatever was returned by the introspection endpoint.spring-doc.cn
However, suppose that, for whatever reason, the introspection endpoint returns only whether or not the token is active. Now what?spring-doc.cn
In this case, you can create a custom ReactiveOpaqueTokenIntrospector that still hits the endpoint but then updates the returned principal to have the JWTs claims as the attributes:spring-doc.cn
public class JwtOpaqueTokenIntrospector implements ReactiveOpaqueTokenIntrospector {
	private ReactiveJwtDecoder jwtDecoder = new NimbusReactiveJwtDecoder(new ParseOnlyJWTProcessor());
				.flatMap(principal -> this.jwtDecoder.decode(token))
				.map(jwt -> new DefaultOAuth2AuthenticatedPrincipal(jwt.getClaims(), NO_AUTHORITIES));
	private static class ParseOnlyJWTProcessor implements Converter<JWT, Mono<JWTClaimsSet>> {
		public Mono<JWTClaimsSet> convert(JWT jwt) {
			try {
				return Mono.just(jwt.getJWTClaimsSet());
			} catch (Exception ex) {
				return Mono.error(ex);
class JwtOpaqueTokenIntrospector : ReactiveOpaqueTokenIntrospector {
    private val jwtDecoder: ReactiveJwtDecoder = NimbusReactiveJwtDecoder(ParseOnlyJWTProcessor())
                .flatMap { jwtDecoder.decode(token) }
                .map { jwt: Jwt -> DefaultOAuth2AuthenticatedPrincipal(jwt.claims, NO_AUTHORITIES) }
    private class ParseOnlyJWTProcessor : Converter<JWT, Mono<JWTClaimsSet>> {
        override fun convert(jwt: JWT): Mono<JWTClaimsSet> {
            return try {
                Mono.just(jwt.jwtClaimsSet)
            } catch (e: Exception) {
                Mono.error(e)
    return new JwtOpaqueTokenIntropsector();
    return JwtOpaqueTokenIntrospector()
Calling a /userinfo Endpoint
Generally speaking, a Resource Server does not care about the underlying user but, instead, cares about the authorities that have been granted.spring-doc.cn
That said, at times it can be valuable to tie the authorization statement back to a user.spring-doc.cn
If an application also uses spring-security-oauth2-client, having set up the appropriate ClientRegistrationRepository, you can do so with a custom OpaqueTokenIntrospector. The implementation in the next listing does three things:spring-doc.cn
  • Delegates to the introspection endpoint, to affirm the token’s validity.spring-doc.cn
  • Looks up the appropriate client registration associated with the /userinfo endpoint.spring-doc.cn
  • Invokes and returns the response from the /userinfo endpoint.spring-doc.cn
public class UserInfoOpaqueTokenIntrospector implements ReactiveOpaqueTokenIntrospector {
	private final ReactiveOpaqueTokenIntrospector delegate = SpringReactiveOpaqueTokenIntrospector
	private final ReactiveOAuth2UserService<OAuth2UserRequest, OAuth2User> oauth2UserService =
			new DefaultReactiveOAuth2UserService();
	private final ReactiveClientRegistrationRepository repository;
	// ... constructor
		return Mono.zip(this.delegate.introspect(token), this.repository.findByRegistrationId("registration-id"))
				.map(t -> {
					OAuth2AuthenticatedPrincipal authorized = t.getT1();
					ClientRegistration clientRegistration = t.getT2();
					Instant issuedAt = authorized.getAttribute(ISSUED_AT);
					Instant expiresAt = authorized.getAttribute(OAuth2IntrospectionClaimNames.EXPIRES_AT);
					OAuth2AccessToken accessToken = new OAuth2AccessToken(BEARER, token, issuedAt, expiresAt);
					return new OAuth2UserRequest(clientRegistration, accessToken);
				.flatMap(this.oauth2UserService::loadUser);
class UserInfoOpaqueTokenIntrospector : ReactiveOpaqueTokenIntrospector {
    private val oauth2UserService: ReactiveOAuth2UserService<OAuth2UserRequest, OAuth2User> = DefaultReactiveOAuth2UserService()
    private val repository: ReactiveClientRegistrationRepository? = null
    // ... constructor
    override fun introspect(token: String?): Mono<OAuth2AuthenticatedPrincipal> {
        return Mono.zip<OAuth2AuthenticatedPrincipal, ClientRegistration>(delegate.introspect(token), repository!!.findByRegistrationId("registration-id"))
                .map<OAuth2UserRequest> { t: Tuple2<OAuth2AuthenticatedPrincipal, ClientRegistration> ->
                    val authorized = t.t1
                    val clientRegistration = t.t2
                    val issuedAt: Instant? = authorized.getAttribute(ISSUED_AT)
                    val expiresAt: Instant? = authorized.getAttribute(OAuth2IntrospectionClaimNames.EXPIRES_AT)
                    val accessToken = OAuth2AccessToken(BEARER, token, issuedAt, expiresAt)
                .flatMap { userRequest: OAuth2UserRequest -> oauth2UserService.loadUser(userRequest) }
If you aren’t using spring-security-oauth2-client, it’s still quite simple. You will simply need to invoke the /userinfo with your own instance of WebClient:spring-doc.cn
    private final WebClient rest = WebClient.create();
		        .map(this::makeUserInfoRequest);
    private val rest: WebClient = WebClient.create()
Either way, having created your ReactiveOpaqueTokenIntrospector, you should publish it as a @Bean to override the defaults:spring-doc.cn
    return new UserInfoOpaqueTokenIntrospector();
    return UserInfoOpaqueTokenIntrospector()
