This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.3! |
Authorization Architecture
This section describes the Spring Security architecture that applies to authorization.
Authorities
Authentication
discusses how all Authentication
implementations store a list of GrantedAuthority
objects.
These represent the authorities that have been granted to the principal.
The GrantedAuthority
objects are inserted into the Authentication
object by the AuthenticationManager
and are later read by AccessDecisionManager
instances when making authorization decisions.
interface has only one method:
String getAuthority();
This method is used by an
AuthorizationManager
instance to obtain a precise String
representation of the GrantedAuthority
By returning a representation as a String
, a GrantedAuthority
can be easily "read" by most AuthorizationManager
implementations.
If a GrantedAuthority
cannot be precisely represented as a String
, the GrantedAuthority
is considered "complex" and getAuthority()
must return null
An example of a complex GrantedAuthority
would be an implementation that stores a list of operations and authority thresholds that apply to different customer account numbers.
Representing this complex GrantedAuthority
as a String
would be quite difficult. As a result, the getAuthority()
method should return null
This indicates to any AuthorizationManager
that it needs to support the specific GrantedAuthority
implementation to understand its contents.
Spring Security includes one concrete GrantedAuthority
implementation: SimpleGrantedAuthority
This implementation lets any user-specified String
be converted into a GrantedAuthority
All AuthenticationProvider
instances included with the security architecture use SimpleGrantedAuthority
to populate the Authentication
object.
You can customize this with GrantedAuthorityDefaults
exists to allow customizing the prefix to use for role-based authorization rules.
You can configure the authorization rules to use a different prefix by exposing a GrantedAuthorityDefaults
bean, like so:
Java
Kotlin
Xml
static GrantedAuthorityDefaults grantedAuthorityDefaults() {
return new GrantedAuthorityDefaults("MYPREFIX_");
companion object {
fun grantedAuthorityDefaults() : GrantedAuthorityDefaults {
return GrantedAuthorityDefaults("MYPREFIX_");
<bean id="grantedAuthorityDefaults" class="org.springframework.security.config.core.GrantedAuthorityDefaults">
<constructor-arg value="MYPREFIX_"/>
</bean>
You expose |
Invocation Handling
Spring Security provides interceptors that control access to secure objects, such as method invocations or web requests.
A pre-invocation decision on whether the invocation is allowed to proceed is made by AuthorizationManager
instances.
Also post-invocation decisions on whether a given value may be returned is made by AuthorizationManager
instances.
The AuthorizationManager
supersedes both AccessDecisionManager
and AccessDecisionVoter
Applications that customize an AccessDecisionManager
or AccessDecisionVoter
are encouraged to change to using AuthorizationManager
s are called by Spring Security’s request-based, method-based, and message-based authorization components and are responsible for making final access control decisions.
interface contains two methods:
AuthorizationDecision check(Supplier<Authentication> authentication, Object secureObject);
default void verify(Supplier<Authentication> authentication, Object secureObject)
throws AccessDeniedException {
's check
method is passed all the relevant information it needs in order to make an authorization decision.
In particular, passing the secure Object
enables those arguments contained in the actual secure object invocation to be inspected.
For example, let’s assume the secure object was a MethodInvocation
It would be easy to query the MethodInvocation
for any Customer
argument, and then implement some sort of security logic in the AuthorizationManager
to ensure the principal is permitted to operate on that customer.
Implementations are expected to return a positive AuthorizationDecision
if access is granted, negative AuthorizationDecision
if access is denied, and a null AuthorizationDecision
when abstaining from making a decision.
verify
calls check
and subsequently throws an AccessDeniedException
in the case of a negative AuthorizationDecision
Delegate-based AuthorizationManager Implementations
Whilst users can implement their own AuthorizationManager
to control all aspects of authorization, Spring Security ships with a delegating AuthorizationManager
that can collaborate with individual AuthorizationManager
s.
RequestMatcherDelegatingAuthorizationManager
will match the request with the most appropriate delegate AuthorizationManager
For method security, you can use AuthorizationManagerBeforeMethodInterceptor
and AuthorizationManagerAfterMethodInterceptor
Authorization Manager Implementations illustrates the relevant classes.
Using this approach, a composition of AuthorizationManager
implementations can be polled on an authorization decision.
AuthorityAuthorizationManager
The most common AuthorizationManager
provided with Spring Security is AuthorityAuthorizationManager
It is configured with a given set of authorities to look for on the current Authentication
It will return positive AuthorizationDecision
should the Authentication
contain any of the configured authorities.
It will return a negative AuthorizationDecision
otherwise.
AuthenticatedAuthorizationManager
Another manager is the AuthenticatedAuthorizationManager
It can be used to differentiate between anonymous, fully-authenticated and remember-me authenticated users.
Many sites allow certain limited access under remember-me authentication, but require a user to confirm their identity by logging in for full access.
AuthorizationManagers
There are also helpful static factories in AuthorizationManagers
for composing individual AuthorizationManager
s into more sophisticated expressions.
Custom Authorization Managers
Obviously, you can also implement a custom AuthorizationManager
and you can put just about any access-control logic you want in it.
It might be specific to your application (business-logic related) or it might implement some security administration logic.
For example, you can create an implementation that can query Open Policy Agent or your own authorization database.
You’ll find a blog article on the Spring web site which describes how to use the legacy AccessDecisionVoter to deny access in real-time to users whose accounts have been suspended.
You can achieve the same outcome by implementing AuthorizationManager instead.
Adapting AccessDecisionManager and AccessDecisionVoters
Previous to AuthorizationManager
, Spring Security published AccessDecisionManager
In some cases, like migrating an older application, it may be desirable to introduce an AuthorizationManager
that invokes an AccessDecisionManager
To call an existing AccessDecisionManager
, you can do:
Java
@Component
public class AccessDecisionManagerAuthorizationManagerAdapter implements AuthorizationManager {
private final AccessDecisionManager accessDecisionManager;
private final SecurityMetadataSource securityMetadataSource;
public AuthorizationDecision check(Supplier<Authentication> authentication, Object object) {
try {
Collection<ConfigAttribute> attributes = this.securityMetadataSource.getAttributes(object);
this.accessDecisionManager.decide(authentication.get(), object, attributes);
return new AuthorizationDecision(true);
} catch (AccessDeniedException ex) {
return new AuthorizationDecision(false);
public void verify(Supplier<Authentication> authentication, Object object) {
And then wire it into your SecurityFilterChain
Or to only call an AccessDecisionVoter
, you can do:
Java
@Component
public class AccessDecisionVoterAuthorizationManagerAdapter implements AuthorizationManager {
private final AccessDecisionVoter accessDecisionVoter;
int decision = this.accessDecisionVoter.vote(authentication.get(), object, attributes);
switch (decision) {
case ACCESS_GRANTED:
case ACCESS_DENIED:
return null;
Hierarchical Roles
It is a common requirement that a particular role in an application should automatically "include" other roles. For example, in an application which has the concept of an "admin" and a "user" role, you may want an admin to be able to do everything a normal user can. To achieve this, you can either make sure that all admin users are also assigned the "user" role. Alternatively, you can modify every access constraint which requires the "user" role to also include the "admin" role. This can get quite complicated if you have a lot of different roles in your application.
The use of a role-hierarchy allows you to configure which roles (or authorities) should include others.
This is supported for filter-based authorization in HttpSecurity#authorizeHttpRequests
and for method-based authorization through DefaultMethodSecurityExpressionHandler
for pre-post annotations, SecuredAuthorizationManager
for @Secured
, and Jsr250AuthorizationManager
for JSR-250 annotations.
You can configure the behavior for all of them at once in the following way:
Java
Xml
static RoleHierarchy roleHierarchy() {
return RoleHierarchyImpl.withDefaultRolePrefix()
.role("ADMIN").implies("STAFF")
.role("STAFF").implies("USER")
.role("USER").implies("GUEST")
// and, if using pre-post method security also add
static MethodSecurityExpressionHandler methodSecurityExpressionHandler(RoleHierarchy roleHierarchy) {
DefaultMethodSecurityExpressionHandler expressionHandler = new DefaultMethodSecurityExpressionHandler();
expressionHandler.setRoleHierarchy(roleHierarchy);
return expressionHandler;
<bean id="roleHierarchy"
class="org.springframework.security.access.hierarchicalroles.RoleHierarchyImpl" factory-method="fromHierarchy">
<constructor-arg>
<value>
ROLE_ADMIN > ROLE_STAFF
ROLE_STAFF > ROLE_USER
ROLE_USER > ROLE_GUEST
</value>
</constructor-arg>
</bean>
<!-- and, if using method security also add -->
<bean id="methodSecurityExpressionHandler"
class="org.springframework.security.access.expression.method.MethodSecurityExpressionHandler">
<property ref="roleHierarchy"/>
</bean>
Here we have four roles in a hierarchy ROLE_ADMIN ⇒ ROLE_STAFF ⇒ ROLE_USER ⇒ ROLE_GUEST
A user who is authenticated with ROLE_ADMIN
, will behave as if they have all four roles when security constraints are evaluated against any filter- or method-based rules.
The > symbol can be thought of as meaning "includes".
Role hierarchies offer a convenient means of simplifying the access-control configuration data for your application and/or reducing the number of authorities which you need to assign to a user. For more complex requirements you may wish to define a logical mapping between the specific access-rights your application requires and the roles that are assigned to users, translating between the two when loading the user information.
Legacy Authorization Components
Spring Security contains some legacy components. Since they are not yet removed, documentation is included for historical purposes. Their recommended replacements are above. |
The AccessDecisionManager
is called by the AbstractSecurityInterceptor
and is responsible for making final access control decisions.
interface contains three methods:
void decide(Authentication authentication, Object secureObject,
Collection<ConfigAttribute> attrs) throws AccessDeniedException;
boolean supports(ConfigAttribute attribute);
boolean supports(Class clazz);
The decide
method of the AccessDecisionManager
is passed all the relevant information it needs to make an authorization decision.
lets those arguments contained in the actual secure object invocation be inspected.
For example, assume the secure object is a MethodInvocation
You can query the MethodInvocation
for any Customer
argument and then implement some sort of security logic in the AccessDecisionManager
Implementations are expected to throw an AccessDeniedException
if access is denied.
The supports(ConfigAttribute)
method is called by the AbstractSecurityInterceptor
at startup time to determine if the AccessDecisionManager
can process the passed ConfigAttribute
The supports(Class)
method is called by a security interceptor implementation to ensure the configured AccessDecisionManager
supports the type of secure object that the security interceptor presents.
Voting-Based AccessDecisionManager Implementations
While users can implement their own AccessDecisionManager
to control all aspects of authorization, Spring Security includes several AccessDecisionManager
implementations that are based on voting.
Voting Decision Manager describes the relevant classes.
The following image shows the AccessDecisionManager
interface:
By using this approach, a series of AccessDecisionVoter
implementations are polled on an authorization decision.
then decides whether or not to throw an AccessDeniedException
based on its assessment of the votes.
The AccessDecisionVoter
interface has three methods:
int vote(Authentication authentication, Object object, Collection<ConfigAttribute> attrs);
Concrete implementations return an int
, with possible values being reflected in the AccessDecisionVoter
static fields named ACCESS_ABSTAIN
, ACCESS_DENIED
and ACCESS_GRANTED
A voting implementation returns ACCESS_ABSTAIN
if it has no opinion on an authorization decision.
If it does have an opinion, it must return either ACCESS_DENIED
or ACCESS_GRANTED
There are three concrete AccessDecisionManager
implementations provided with Spring Security to tally the votes.
The ConsensusBased
implementation grants or denies access based on the consensus of non-abstain votes.
Properties are provided to control behavior in the event of an equality of votes or if all votes are abstain.
The AffirmativeBased
implementation grants access if one or more ACCESS_GRANTED
votes were received (in other words, a deny vote will be ignored, provided there was at least one grant vote).
Like the ConsensusBased
implementation, there is a parameter that controls the behavior if all voters abstain.
The UnanimousBased
provider expects unanimous ACCESS_GRANTED
votes in order to grant access, ignoring abstains.
It denies access if there is any ACCESS_DENIED
vote.
Like the other implementations, there is a parameter that controls the behavior if all voters abstain.
You can implement a custom AccessDecisionManager
that tallies votes differently.
For example, votes from a particular AccessDecisionVoter
might receive additional weighting, while a deny vote from a particular voter may have a veto effect.
RoleVoter
The most commonly used AccessDecisionVoter
provided with Spring Security is the RoleVoter
, which treats configuration attributes as role names and votes to grant access if the user has been assigned that role.
It votes if any ConfigAttribute
begins with the ROLE_
prefix.
It votes to grant access if there is a GrantedAuthority
that returns a String
representation (from the getAuthority()
method) exactly equal to one or more ConfigAttributes
that start with the ROLE_
prefix.
If there is no exact match of any ConfigAttribute
starting with ROLE_
, RoleVoter
votes to deny access.
If no ConfigAttribute
begins with ROLE_
, the voter abstains.
AuthenticatedVoter
Another voter which we have implicitly seen is the AuthenticatedVoter
, which can be used to differentiate between anonymous, fully-authenticated, and remember-me authenticated users.
Many sites allow certain limited access under remember-me authentication but require a user to confirm their identity by logging in for full access.
When we have used the IS_AUTHENTICATED_ANONYMOUSLY
attribute to grant anonymous access, this attribute was being processed by the AuthenticatedVoter
For more information, see
AuthenticatedVoter
Custom Voters
You can also implement a custom AccessDecisionVoter
and put just about any access-control logic you want in it.
For example, on the Spring web site, you can find a blog article that describes how to use a voter to deny access in real-time to users whose accounts have been suspended.
Like many other parts of Spring Security, AfterInvocationManager
has a single concrete implementation, AfterInvocationProviderManager
, which polls a list of AfterInvocationProvider
s.
Each AfterInvocationProvider
is allowed to modify the return object or throw an AccessDeniedException
Indeed multiple providers can modify the object, as the result of the previous provider is passed to the next in the list.
Please be aware that if you’re using AfterInvocationManager
, you will still need configuration attributes that allow the MethodSecurityInterceptor
's AccessDecisionManager
to allow an operation.
If you’re using the typical Spring Security included AccessDecisionManager
implementations, having no configuration attributes defined for a particular secure method invocation will cause each AccessDecisionVoter
to abstain from voting.
In turn, if the AccessDecisionManager
property “allowIfAllAbstainDecisions” is false
, an AccessDeniedException
will be thrown.
You may avoid this potential issue by either (i) setting “allowIfAllAbstainDecisions” to true
(although this is generally not recommended) or (ii) simply ensure that there is at least one configuration attribute that an AccessDecisionVoter
will vote to grant access for.
This latter (recommended) approach is usually achieved through a ROLE_USER
or ROLE_AUTHENTICATED
configuration attribute.
