Saml 2.0 Metadata
Spring Security can parse asserting party metadata to produce an AssertingPartyMetadata instance as well as publish relying party metadata from a RelyingPartyRegistration instance.spring-doc.cn
Parsing <saml2:IDPSSODescriptor> metadata
You can parse an asserting party’s metadata using RelyingPartyRegistrations.spring-doc.cn
When using the OpenSAML vendor support, the resulting AssertingPartyMetadata will be of type OpenSamlAssertingPartyDetails. This means you’ll be able to do get the underlying OpenSAML XMLObject by doing the following:spring-doc.cn
OpenSamlAssertingPartyDetails details = (OpenSamlAssertingPartyDetails)
        registration.getAssertingPartyMetadata();
EntityDescriptor openSamlEntityDescriptor = details.getEntityDescriptor();
val details: OpenSamlAssertingPartyDetails =
        registration.getAssertingPartyMetadata() as OpenSamlAssertingPartyDetails
val openSamlEntityDescriptor: EntityDescriptor = details.getEntityDescriptor()
Using AssertingPartyMetadataRepository
You can also be more targeted than RelyingPartyRegistrations by using AssertingPartyMetadataRepository, an interface that allows for only retrieving the asserting party metadata.spring-doc.cn
This allows three valuable features:spring-doc.cn
  • Implementations can refresh asserting party metadata in an expiry-aware fashionspring-doc.cn
  • Implementations of RelyingPartyRegistrationRepository can more easily articulate a relationship between a relying party and its one or many corresponding asserting partiesspring-doc.cn
  • Implementations can verify metadata signaturesspring-doc.cn
For example, OpenSaml4AssertingPartyMetadataRepository uses OpenSAML’s MetadataResolver, and API whose implementations regularly refresh the underlying metadata in an expiry-aware fashion.spring-doc.cn
This means that you can now create a refreshable RelyingPartyRegistrationRepository in just a few lines of code:spring-doc.cn
@Component
public class RefreshableRelyingPartyRegistrationRepository
        implements IterableRelyingPartyRegistrationRepository {
	private final AssertingPartyMetadataRepository metadata =
            OpenSamlAssertingPartyMetadataRepository
                .fromTrustedMetadataLocation("https://idp.example.org/metadata").build();
    public RelyingPartyRegistration findByRegistrationId(String registrationId) {
		AssertingPartyMetadata metadata = this.metadata.findByEntityId(registrationId);
        if (metadata == null) {
            return null;
		return applyRelyingParty(metadata);
    public Iterator<RelyingPartyRegistration> iterator() {
		return StreamSupport.stream(this.metadata.spliterator(), false)
            .map(this::applyRelyingParty).iterator();
	private RelyingPartyRegistration applyRelyingParty(AssertingPartyMetadata metadata) {
		return RelyingPartyRegistration.withAssertingPartyMetadata(metadata)
            // apply any relying party configuration
@Component
class RefreshableRelyingPartyRegistrationRepository : IterableRelyingPartyRegistrationRepository {
    private val metadata: AssertingPartyMetadataRepository =
        OpenSamlAssertingPartyMetadataRepository.fromTrustedMetadataLocation(
    fun findByRegistrationId(registrationId:String?): RelyingPartyRegistration {
        val metadata = this.metadata.findByEntityId(registrationId)
            return null
    fun iterator(): Iterator<RelyingPartyRegistration> {
    private fun applyRelyingParty(metadata: AssertingPartyMetadata): RelyingPartyRegistration {
        val details: AssertingPartyMetadata = metadata as AssertingPartyMetadata
        return RelyingPartyRegistration.withAssertingPartyMetadata(details)
            .build()
OpenSaml4AssertingPartyMetadataRepository also ships with a constructor so you can provide a custom MetadataResolver. Since the underlying MetadataResolver is doing the expiring and refreshing, if you use the constructor directly, you will only get these features by providing an implementation that does so.
Verifying Metadata Signatures
You can also verify metadata signatures using OpenSaml4AssertingPartyMetadataRepository by providing the appropriate set of Saml2X509Credentials as follows:spring-doc.cn
OpenSamlAssertingPartyMetadataRepository.withMetadataLocation("https://idp.example.org/metadata")
    .verificationCredentials((c) -> c.add(myVerificationCredential))
    .verificationCredentials({ c : Collection<Saml2X509Credential> ->
        c.add(myVerificationCredential) })
    .build()
If no credentials are provided, the component will not perform signature validation.
Producing <saml2:SPSSODescriptor> Metadata
You can publish a metadata endpoint using the saml2Metadata DSL method, as you’ll see below:spring-doc.cn
http
    .saml2Login(withDefaults())
    .saml2Metadata(withDefaults());
http {
    saml2Login { }
    saml2Metadata { }
You can use this metadata endpoint to register your relying party with your asserting party. This is often as simple as finding the correct form field to supply the metadata endpoint.spring-doc.cn
By default, the metadata endpoint is /saml2/metadata, though it also responds to /saml2/metadata/{registrationId} and /saml2/service-provider-metadata/{registrationId}.spring-doc.cn
You can change this by calling the metadataUrl method in the DSL:spring-doc.cn
.saml2Metadata((saml2) -> saml2.metadataUrl("/saml/metadata"))
saml2Metadata {
	metadataUrl = "/saml/metadata"
Changing the Way a RelyingPartyRegistration Is Looked Up
If you have a different strategy for identifying which RelyingPartyRegistration to use, you can configure your own Saml2MetadataResponseResolver like the one below:spring-doc.cn
Saml2MetadataResponseResolver metadataResponseResolver(RelyingPartyRegistrationRepository registrations) {
	RequestMatcherMetadataResponseResolver metadata = new RequestMatcherMetadataResponseResolver(
			(id) -> registrations.findByRegistrationId("relying-party"));
	metadata.setMetadataFilename("metadata.xml");
	return metadata;
fun metadataResponseResolver(val registrations: RelyingPartyRegistrationRepository): Saml2MetadataResponseResolver {
    val metadata = new RequestMatcherMetadataResponseResolver(
			id: String -> registrations.findByRegistrationId("relying-party"))
	return metadata
