This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.3! |
HTTP
All HTTP-based communication should be protected using TLS.
This section discusses the details of servlet-specific features that assist with HTTPS usage.
Redirect to HTTPS
If a client makes a request using HTTP rather than HTTPS, you can configure Spring Security to redirect to HTTPS.
For example, the following Java or Kotlin configuration redirects any HTTP requests to HTTPS:
Redirect to HTTPS
Java
Kotlin
@EnableWebSecurity
public class WebSecurityConfig {
http
.redirectToHttps(withDefaults());
return http.build();
@EnableWebSecurity
class SecurityConfig {
http {
redirectToHttps { }
return http.build()
The following XML configuration redirects all HTTP requests to HTTPS
Redirect to HTTPS with XML Configuration
<http>
<intercept-url pattern="/**" access="ROLE_USER" requires-channel="https"/>
</http>
Strict Transport Security
Spring Security provides support for Strict Transport Security and enables it by default.
Proxy Server Configuration
Spring Security integrates with proxy servers.
