对于最新的稳定版本,请使用 Spring Security 6.3.1! |
对于每个成功或失败的身份验证,将分别触发 或。AuthenticationSuccessEvent
AbstractAuthenticationFailureEvent
若要侦听这些事件,必须首先发布 .
Spring Security 可能会做得很好:AuthenticationEventPublisher
DefaultAuthenticationEventPublisher
Java
Kotlin
public AuthenticationEventPublisher authenticationEventPublisher
(ApplicationEventPublisher applicationEventPublisher) {
return new DefaultAuthenticationEventPublisher(applicationEventPublisher);
fun authenticationEventPublisher
(applicationEventPublisher: ApplicationEventPublisher?): AuthenticationEventPublisher {
return DefaultAuthenticationEventPublisher(applicationEventPublisher)
然后,您可以使用 Spring 的支持:@EventListener
Java
Kotlin
@Component
public class AuthenticationEvents {
@EventListener
public void onSuccess(AuthenticationSuccessEvent success) {
@EventListener
public void onFailure(AbstractAuthenticationFailureEvent failures) {
@Component
@EventListener
fun onSuccess(success: AuthenticationSuccessEvent?) {
@EventListener
fun onFailure(failures: AbstractAuthenticationFailureEvent?) {
虽然与 和 类似,但它们很好,因为它们可以独立于 servlet API 使用。AuthenticationSuccessHandler
AuthenticationFailureHandler
添加异常映射
默认情况下,将为以下事件发布一个:AbstractAuthenticationFailureEvent
例外 |
事件 |
发布者执行完全匹配,这意味着这些异常的子类也不会生成事件。Exception
为此,您可能希望通过以下方法向发布者提供其他映射:setAdditionalExceptionMappings
Java
Kotlin
Map<Class<? extends AuthenticationException>,
Class<? extends AbstractAuthenticationFailureEvent>> mapping =
Collections.singletonMap(FooException.class, FooEvent.class);
AuthenticationEventPublisher authenticationEventPublisher =
authenticationEventPublisher.setAdditionalExceptionMappings(mapping);
return authenticationEventPublisher;
val mapping: Map<Class<out AuthenticationException>, Class<out AbstractAuthenticationFailureEvent>> =
mapOf(Pair(FooException::class.java, FooEvent::class.java))
val authenticationEventPublisher = DefaultAuthenticationEventPublisher(applicationEventPublisher)
例外 |
事件 |
默认事件
而且,在以下情况下,您可以提供要触发的捕获所有事件:AuthenticationException
Java
Kotlin
authenticationEventPublisher.setDefaultAuthenticationFailureEvent
(GenericAuthenticationFailureEvent.class);
authenticationEventPublisher.setDefaultAuthenticationFailureEvent(GenericAuthenticationFailureEvent::class.java)
