This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.0! |
@TestExecutionListeners
is used to register listeners for a particular test class, its
subclasses, and its nested classes. If you wish to register a listener globally, you
should register it via the automatic discovery mechanism described in
Configuration.
The following example shows how to register two TestExecutionListener
implementations:
Java
Kotlin
@ContextConfiguration
@TestExecutionListeners({CustomTestExecutionListener.class, AnotherTestExecutionListener.class}) (1)
class CustomTestExecutionListenerTests {
// class body...
1 | Register two TestExecutionListener implementations. |
@TestExecutionListeners(CustomTestExecutionListener::class, AnotherTestExecutionListener::class) (1)
// class body...
By default, @TestExecutionListeners
provides support for inheriting listeners from
superclasses or enclosing classes. See
@Nested
test class configuration and the
javadoc for an example and further details. If you discover that you need to switch
back to using the default TestExecutionListener
implementations, see the note
in Registering TestExecutionListener
Implementations.
