@BeforeTransaction
@BeforeTransaction indicates that the annotated void method should be run before a transaction is started, for test methods that have been configured to run within a transaction by using Spring’s @Transactional annotation. @BeforeTransaction methods are not required to be public and may be declared on Java 8-based interface default methods.spring-doc.cn
The following example shows how to use the @BeforeTransaction annotation:spring-doc.cn
@BeforeTransaction (1)
void beforeTransaction() {
	// logic to be run before a transaction is started
1 Run this method before a transaction.
fun beforeTransaction() {
