This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4! |
Reply ContentType
If you are using a sophisticated message converter, such as the ContentTypeDelegatingMessageConverter
, you can control the content type of the reply by setting the replyContentType
property on the listener.
This allows the converter to select the appropriate delegate converter for the reply.
@RabbitListener(queues = "q1", messageConverter = "delegating",
replyContentType = "application/json")
public Thing2 listen(Thing1 in) {
By default, for backwards compatibility, any content type property set by the converter will be overwritten by this value after conversion.
Converters such as the SimpleMessageConverter
use the reply type rather than the content type to determine the conversion needed and sets the content type in the reply message appropriately.
This may not be the desired action and can be overridden by setting the converterWinsContentType
property to false
For example, if you return a String
containing JSON, the SimpleMessageConverter
will set the content type in the reply to text/plain
The following configuration will ensure the content type is set properly, even if the SimpleMessageConverter
is used.
@RabbitListener(queues = "q1", replyContentType = "application/json",
converterWinsContentType = "false")
public String listen(Thing in) {
return someJsonString;
These properties (replyContentType
and converterWinsContentType
) do not apply when the return type is a Spring AMQP Message
or a Spring Messaging Message<?>
In the first case, there is no conversion involved; simply set the contentType
message property.
In the second case, the behavior is controlled using message headers:
@RabbitListener(queues = "q1", messageConverter = "delegating")
@SendTo("q2")
public Message<String> listen(String in) {
return MessageBuilder.withPayload(in.toUpperCase())
.setHeader(MessageHeaders.CONTENT_TYPE, "application/xml")
This content type will be passed in the MessageProperties
to the converter.
If you wish to override that behavior, also set the AmqpHeaders.CONTENT_TYPE_CONVERTER_WINS
to true
and any value set by the converter will be retained.
