This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.4!spring-doc.cn
Container Management
Containers created for annotations are not registered with the application context. You can obtain a collection of all containers by invoking getListenerContainers() on the RabbitListenerEndpointRegistry bean. You can then iterate over this collection, for example, to stop or start all containers or invoke the Lifecycle methods on the registry itself, which will invoke the operations on each container.spring-doc.cn
You can also get a reference to an individual container by using its id, using getListenerContainer(String id) — for example, registry.getListenerContainer("multi") for the container created by the snippet above.spring-doc.cn
Starting with version 1.5.2, you can obtain the id values of the registered containers with getListenerContainerIds().spring-doc.cn
Starting with version 1.5, you can now assign a group to the container on the RabbitListener endpoint. This provides a mechanism to get a reference to a subset of containers. Adding a group attribute causes a bean of type Collection<MessageListenerContainer> to be registered with the context with the group name.spring-doc.cn
By default, stopping a container will cancel the consumer and process all prefetched messages before stopping. Starting with versions 2.4.14, 3.0.6, you can set the forceStop container property to true to stop immediately after the current message is processed, causing any prefetched messages to be requeued. This is useful, for example, if exclusive or single-active consumers are being used.spring-doc.cn
