This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
watsonx.ai Embeddings
With Watsonx.ai you can run various Large Language Models (LLMs) and generate embeddings from them.
Spring AI supports the Watsonx.ai text embeddings with WatsonxAiEmbeddingModel
An embedding is a vector (list) of floating point numbers. The distance between two vectors measures their relatedness. Small distances suggest high relatedness and large distances suggest low relatedness.
Prerequisites
You first need to have a SaaS instance of watsonx.ai (as well as an IBM Cloud account).
Refer to free-trial to try watsonx.ai for free
More info can be found here |
Add Repositories and BOM
Spring AI artifacts are published in Maven Central and Spring Snapshot repositories. Refer to the Repositories section to add these repositories to your build system.
To help with dependency management, Spring AI provides a BOM (bill of materials) to ensure that a consistent version of Spring AI is used throughout the entire project. Refer to the Dependency Management section to add the Spring AI BOM to your build system.
Auto-configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information. |
Spring AI provides Spring Boot auto-configuration for the Watsonx.ai Embedding Model.
To enable it add the following dependency to your Maven pom.xml
file:
<dependency>
<artifactId>spring-ai-starter-model-watsonx-ai</artifactId>
</dependency>
or to your Gradle build.gradle
build file.
dependencies {
implementation 'org.springframework.ai:spring-ai-starter-model-watsonx-ai'
Refer to the Dependency Management section to add the Spring AI BOM to your build file. |
The spring.ai.watsonx.embedding.options.*
properties are used to configure the default options used for all embedding requests.
Embedding Properties
The prefix spring.ai.watsonx.ai
is used as the property prefix that lets you connect to watsonx.ai.
Property | Description | Default |
spring.ai.watsonx.ai.base-url |
The URL to connect to |
spring.ai.watsonx.ai.embedding-endpoint |
The text endpoint |
ml/v1/text/embeddings?version=2023-05-29 |
spring.ai.watsonx.ai.project-id |
The project ID |
spring.ai.watsonx.ai.iam-token |
The IBM Cloud account IAM token |
Enabling and disabling of the embedding auto-configurations are now configured via top level properties with the prefix To enable, spring.ai.model.embedding=watsonx (It is enabled by default) To disable, spring.ai.model.embedding=none (or any value which doesn’t match watsonx) This change is done to allow configuration of multiple models. |
The prefix spring.ai.watsonx.embedding.options
is the property prefix that configures the EmbeddingModel
implementation for Watsonx.ai.
spring.ai.watsonx.ai.embedding.enabled (Removed and no longer valid) |
Enable Watsonx.ai embedding model |
true |
spring.ai.model.embedding |
watsonx |
spring.ai.watsonx.ai.embedding.options.model |
The embedding model to be used |
ibm/slate-30m-english-rtrvr |
Runtime Options
The WatsonxAiEmbeddingOptions.java provides the Watsonx.ai configurations, such as the model to use.
The default options can be configured using the spring.ai.watsonx.embedding.options
properties as well.
EmbeddingResponse embeddingResponse = embeddingModel.call(
new EmbeddingRequest(List.of("Hello World", "World is big and salvation is near"),
WatsonxAiEmbeddingOptions.create()
.withModel("Different-Embedding-Model-Deployment-Name"))
Sample Controller
This will create an EmbeddingModel
implementation that you can inject into your class.
Here is an example of a simple @Controller
class that uses the EmbeddingModel
implementation.
@RestController
public class EmbeddingController {
private final EmbeddingModel embeddingModel;
@Autowired
public EmbeddingController(EmbeddingModel embeddingModel) {
this.embeddingModel = embeddingModel;
@GetMapping("/ai/embedding")
public ResponseEntity<Embedding> embedding(@RequestParam String text) {
EmbeddingResponse response = this.embeddingModel.embedForResponse(List.of(text));
return ResponseEntity.ok(response.getResult());
