This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
DeepSeek Chat
DeepSeek AI provides the open-source DeepSeek V3 model, renowned for its cutting-edge reasoning and problem-solving capabilities.
Spring AI integrates with DeepSeek AI by reusing the existing OpenAI client. To get started, you’ll need to obtain a DeepSeek API Key, configure the base URL, and select one of the supported models.
The current version of the deepseek-chat model’s Function Calling capability is unstable, which may result in looped calls or empty responses. |
Check the DeepSeekWithOpenAiChatModelIT.java tests for examples of using DeepSeek with Spring AI.
Prerequisites
Create an API Key: Visit here to create an API Key. Configure it using the
spring.ai.openai.api-key
property in your Spring AI project. -
Set the DeepSeek Base URL: Set the
spring.ai.openai.base-url
property toapi.deepseek.com
Select a DeepSeek Model: Use the
spring.ai.openai.chat.options.model=<model name>
property to specify the model. Refer to Supported Models for available options.
Example environment variables configuration:
export SPRING_AI_OPENAI_API_KEY=<INSERT DEEPSEEK API KEY HERE>
export SPRING_AI_OPENAI_BASE_URL=https://api.deepseek.com
export SPRING_AI_OPENAI_CHAT_MODEL=deepseek-chat
Add Repositories and BOM
Spring AI artifacts are published in Maven Central and Spring Snapshot repositories. Refer to the Repositories section to add these repositories to your build system.
To help with dependency management, Spring AI provides a BOM (bill of materials) to ensure that a consistent version of Spring AI is used throughout the entire project. Refer to the Dependency Management section to add the Spring AI BOM to your build system.
Auto-configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information. |
Spring AI provides Spring Boot auto-configuration for the OpenAI Chat Client.
To enable it add the following dependency to your project’s Maven pom.xml
or Gradle build.gradle
build files:
Maven
Gradle
<dependency>
<artifactId>spring-ai-starter-model-openai</artifactId>
</dependency>
dependencies {
implementation 'org.springframework.ai:spring-ai-starter-model-openai'
Refer to the Dependency Management section to add the Spring AI BOM to your build file. |
Chat Properties
Retry Properties
The prefix spring.ai.retry
is used as the property prefix that lets you configure the retry mechanism for the OpenAI chat model.
Property | Description | Default |
spring.ai.retry.max-attempts |
Maximum number of retry attempts. |
10 |
spring.ai.retry.backoff.initial-interval |
Initial sleep duration for the exponential backoff policy. |
2 sec. |
spring.ai.retry.backoff.multiplier |
Backoff interval multiplier. |
5 |
spring.ai.retry.backoff.max-interval |
Maximum backoff duration. |
3 min. |
spring.ai.retry.on-client-errors |
If false, throw a NonTransientAiException, and do not attempt retry for |
false |
spring.ai.retry.exclude-on-http-codes |
List of HTTP status codes that should not trigger a retry (e.g. to throw NonTransientAiException). |
empty |
spring.ai.retry.on-http-codes |
List of HTTP status codes that should trigger a retry (e.g. to throw TransientAiException). |
empty |
Connection Properties
The prefix spring.ai.openai
is used as the property prefix that lets you connect to OpenAI.
spring.ai.openai.base-url |
The URL to connect to. Must be set to |
spring.ai.openai.api-key |
Your DeepSeek API Key |
Configuration Properties
Enabling and disabling of the chat auto-configurations are now configured via top level properties with the prefix To enable, spring.ai.model.chat=openai (It is enabled by default) To disable, spring.ai.model.chat=none (or any value which doesn’t match openai) This change is done to allow configuration of multiple models. |
The prefix spring.ai.openai.chat
is the property prefix that lets you configure the chat model implementation for OpenAI.
spring.ai.openai.chat.enabled (Removed and no longer valid) |
Enable OpenAI chat model. |
true |
spring.ai.model.chat |
openai |
spring.ai.openai.chat.base-url |
Optional overrides the spring.ai.openai.base-url to provide chat specific url. Must be set to |
spring.ai.openai.chat.api-key |
Optional overrides the spring.ai.openai.api-key to provide chat specific api-key |
spring.ai.openai.chat.options.model |
The DeepSeek LLM model to use |
spring.ai.openai.chat.options.temperature |
The sampling temperature to use that controls the apparent creativity of generated completions. Higher values will make output more random while lower values will make results more focused and deterministic. It is not recommended to modify temperature and top_p for the same completions request as the interaction of these two settings is difficult to predict. |
0.8 |
spring.ai.openai.chat.options.frequencyPenalty |
Number between -2.0 and 2.0. Positive values penalize new tokens based on their existing frequency in the text so far, decreasing the model’s likelihood to repeat the same line verbatim. |
0.0f |
spring.ai.openai.chat.options.maxTokens |
The maximum number of tokens to generate in the chat completion. The total length of input tokens and generated tokens is limited by the model’s context length. |
spring.ai.openai.chat.options.n |
How many chat completion choices to generate for each input message. Note that you will be charged based on the number of generated tokens across all of the choices. Keep n as 1 to minimize costs. |
1 |
spring.ai.openai.chat.options.presencePenalty |
Number between -2.0 and 2.0. Positive values penalize new tokens based on whether they appear in the text so far, increasing the model’s likelihood to talk about new topics. |
spring.ai.openai.chat.options.responseFormat |
An object specifying the format that the model must output. Setting to |
spring.ai.openai.chat.options.seed |
This feature is in Beta. If specified, our system will make a best effort to sample deterministically, such that repeated requests with the same seed and parameters should return the same result. |
spring.ai.openai.chat.options.stop |
Up to 4 sequences where the API will stop generating further tokens. |
spring.ai.openai.chat.options.topP |
An alternative to sampling with temperature, called nucleus sampling, where the model considers the results of the tokens with top_p probability mass. So 0.1 means only the tokens comprising the top 10% probability mass are considered. We generally recommend altering this or temperature but not both. |
spring.ai.openai.chat.options.tools |
A list of tools the model may call. Currently, only functions are supported as a tool. Use this to provide a list of functions the model may generate JSON inputs for. |
spring.ai.openai.chat.options.toolChoice |
Controls which (if any) function is called by the model. none means the model will not call a function and instead generates a message. auto means the model can pick between generating a message or calling a function. Specifying a particular function via {"type: "function", "function": {"name": "my_function"}} forces the model to call that function. none is the default when no functions are present. auto is the default if functions are present. |
spring.ai.openai.chat.options.user |
A unique identifier representing your end-user, which can help OpenAI to monitor and detect abuse. |
spring.ai.openai.chat.options.functions |
List of functions, identified by their names, to enable for function calling in a single prompt requests. Functions with those names must exist in the functionCallbacks registry. |
spring.ai.openai.chat.options.stream-usage |
(For streaming only) Set to add an additional chunk with token usage statistics for the entire request. The |
false |
spring.ai.openai.chat.options.proxy-tool-calls |
If true, the Spring AI will not handle the function calls internally, but will proxy them to the client. Then is the client’s responsibility to handle the function calls, dispatch them to the appropriate function, and return the results. If false (the default), the Spring AI will handle the function calls internally. Applicable only for chat models with function calling support |
false |
All properties prefixed with spring.ai.openai.chat.options can be overridden at runtime by adding a request specific Runtime Options to the Prompt call.
Runtime Options
The OpenAiChatOptions.java provides model configurations, such as the model to use, the temperature, the frequency penalty, etc.
On start-up, the default options can be configured with the OpenAiChatModel(api, options)
constructor or the spring.ai.openai.chat.options.*
properties.
At run-time you can override the default options by adding new, request specific, options to the Prompt
call.
For example to override the default model and temperature for a specific request:
ChatResponse response = chatModel.call(
new Prompt(
"Generate the names of 5 famous pirates.",
OpenAiChatOptions.builder()
.model("deepseek-chat")
.temperature(0.4)
.build()
In addition to the model specific OpenAiChatOptions you can use a portable ChatOptions instance, created with the ChatOptions#builder(). |
Function Calling
Sample Controller
Create a new Spring Boot project and add the spring-ai-starter-model-openai
to your pom (or gradle) dependencies.
Add a application.properties
file, under the src/main/resources
directory, to enable and configure the OpenAi chat model:
spring.ai.openai.api-key=<DEEPSEEK_API_KEY>
spring.ai.openai.base-url=https://api.deepseek.com
spring.ai.openai.chat.options.model=deepseek-chat
spring.ai.openai.chat.options.temperature=0.7
# The DeepSeek API doesn't support embeddings, so we need to disable it.
spring.ai.openai.embedding.enabled=false
replace the api-key with your DeepSeek Api key.
This will create a OpenAiChatModel
implementation that you can inject into your class.
Here is an example of a simple @Controller
class that uses the chat model for text generations.
@RestController
public class ChatController {
private final OpenAiChatModel chatModel;
@Autowired
public ChatController(OpenAiChatModel chatModel) {
this.chatModel = chatModel;
@GetMapping("/ai/generate")
public Map generate(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
return Map.of("generation", this.chatModel.call(message));
@GetMapping("/ai/generateStream")
public Flux<ChatResponse> generateStream(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
Prompt prompt = new Prompt(new UserMessage(message));
return this.chatModel.stream(prompt);
