This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
PGvector
This section walks you through setting up the PGvector VectorStore to store document embeddings and perform similarity searches.spring-doc.cn
PGvector is an open-source extension for PostgreSQL that enables storing and searching over machine learning-generated embeddings. It provides different capabilities that let users identify both exact and approximate nearest neighbors. It is designed to work seamlessly with other PostgreSQL features, including indexing and querying.spring-doc.cn
Prerequisites
First you need access to PostgreSQL instance with enabled vector, hstore and uuid-ossp extensions.spring-doc.cn
You can run a PGvector database as a Spring Boot dev service via Docker Compose or Testcontainers. In alternative, the setup local Postgres/PGVector appendix shows how to set up a DB locally with a Docker container.
On startup, the PgVectorStore will attempt to install the required database extensions and create the required vector_store table with an index if not existing.spring-doc.cn
Optionally, you can do this manually like so:spring-doc.cn
CREATE EXTENSION IF NOT EXISTS vector;
CREATE EXTENSION IF NOT EXISTS hstore;
CREATE EXTENSION IF NOT EXISTS "uuid-ossp";
CREATE TABLE IF NOT EXISTS vector_store (
	id uuid DEFAULT uuid_generate_v4() PRIMARY KEY,
	content text,
	metadata json,
	embedding vector(1536) // 1536 is the default embedding dimension
CREATE INDEX ON vector_store USING HNSW (embedding vector_cosine_ops);
replace the 1536 with the actual embedding dimension if you are using a different dimension. PGvector supports at most 2000 dimensions for HNSW indexes.
Next, if required, an API key for the EmbeddingModel to generate the embeddings stored by the PgVectorStore.spring-doc.cn
Auto-Configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information.spring-doc.cn
Then add the PgVectorStore boot starter dependency to your project:spring-doc.cn
<dependency>
	<artifactId>spring-ai-starter-vector-store-pgvector</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-starter-vector-store-pgvector'
The vector store implementation can initialize the required schema for you, but you must opt-in by specifying the initializeSchema boolean in the appropriate constructor or by setting …​initialize-schema=true in the application.properties file.spring-doc.cn
This is a breaking change! In earlier versions of Spring AI, this schema initialization happened by default.
The Vector Store also requires an EmbeddingModel instance to calculate embeddings for the documents. You can pick one of the available EmbeddingModel Implementations.spring-doc.cn
For example, to use the OpenAI EmbeddingModel, add the following dependency to your project:spring-doc.cn
<dependency>
	<artifactId>spring-ai-starter-model-openai</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-starter-model-openai'
Refer to the Dependency Management section to add the Spring AI BOM to your build file. Refer to the Repositories section to add Maven Central and/or Snapshot Repositories to your build file.
To connect to and configure the PgVectorStore, you need to provide access details for your instance. A simple configuration can be provided via Spring Boot’s application.yml.spring-doc.cn
spring:
  datasource:
    url: jdbc:postgresql://localhost:5432/postgres
    username: postgres
    password: postgres
  ai:
	vectorstore:
	  pgvector:
		index-type: HNSW
		distance-type: COSINE_DISTANCE
		dimensions: 1536
		max-document-batch-size: 10000 # Optional: Maximum number of documents per batch
If you run PGvector as a Spring Boot dev service via Docker Compose or Testcontainers, you don’t need to configure URL, username and password since they are autoconfigured by Spring Boot.
Check the list of configuration parameters to learn about the default values and configuration options.
Now you can auto-wire the VectorStore in your application and use itspring-doc.cn
@Autowired VectorStore vectorStore;
List<Document> documents = List.of(
    new Document("Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!!", Map.of("meta1", "meta1")),
    new Document("The World is Big and Salvation Lurks Around the Corner"),
    new Document("You walk forward facing the past and you turn back toward the future.", Map.of("meta2", "meta2")));
// Add the documents to PGVector
vectorStore.add(documents);
// Retrieve documents similar to a query
List<Document> results = this.vectorStore.similaritySearch(SearchRequest.builder().query("Spring").topK(5).build());
Configuration properties
You can use the following properties in your Spring Boot configuration to customize the PGVector vector store.spring-doc.cn
Property Description Default value
spring.ai.vectorstore.pgvector.index-typespring-doc.cn
Nearest neighbor search index type. Options are NONE - exact nearest neighbor search, IVFFlat - index divides vectors into lists, and then searches a subset of those lists that are closest to the query vector. It has faster build times and uses less memory than HNSW, but has lower query performance (in terms of speed-recall tradeoff). HNSW - creates a multilayer graph. It has slower build times and uses more memory than IVFFlat, but has better query performance (in terms of speed-recall tradeoff). There’s no training step like IVFFlat, so the index can be created without any data in the table.spring-doc.cn
HNSWspring-doc.cn
spring.ai.vectorstore.pgvector.distance-typespring-doc.cn
Search distance type. Defaults to COSINE_DISTANCE. But if vectors are normalized to length 1, you can use EUCLIDEAN_DISTANCE or NEGATIVE_INNER_PRODUCT for best performance.spring-doc.cn
COSINE_DISTANCEspring-doc.cn
spring.ai.vectorstore.pgvector.dimensionsspring-doc.cn
Embeddings dimension. If not specified explicitly the PgVectorStore will retrieve the dimensions form the provided EmbeddingModel. Dimensions are set to the embedding column the on table creation. If you change the dimensions your would have to re-create the vector_store table as well.spring-doc.cn
-spring-doc.cn
spring.ai.vectorstore.pgvector.remove-existing-vector-store-tablespring-doc.cn
Deletes the existing vector_store table on start up.spring-doc.cn
falsespring-doc.cn
spring.ai.vectorstore.pgvector.initialize-schemaspring-doc.cn
Whether to initialize the required schemaspring-doc.cn
falsespring-doc.cn
spring.ai.vectorstore.pgvector.schema-namespring-doc.cn
Vector store schema namespring-doc.cn
publicspring-doc.cn
spring.ai.vectorstore.pgvector.table-namespring-doc.cn
Vector store table namespring-doc.cn
vector_storespring-doc.cn
spring.ai.vectorstore.pgvector.schema-validationspring-doc.cn
Enables schema and table name validation to ensure they are valid and existing objects.spring-doc.cn
falsespring-doc.cn
spring.ai.vectorstore.pgvector.max-document-batch-sizespring-doc.cn
Maximum number of documents to process in a single batch.spring-doc.cn
10000spring-doc.cn
If you configure a custom schema and/or table name, consider enabling schema validation by setting spring.ai.vectorstore.pgvector.schema-validation=true. This ensures the correctness of the names and reduces the risk of SQL injection attacks.
Metadata filtering
You can leverage the generic, portable metadata filters with the PgVector store.spring-doc.cn
For example, you can use either the text expression language:spring-doc.cn
    .query("The World")
    .topK(TOP_K)
    .similarityThreshold(SIMILARITY_THRESHOLD)
    .filterExpression("author in ['john', 'jill'] && article_type == 'blog'").build());
or programmatically using the Filter.Expression DSL:spring-doc.cn
FilterExpressionBuilder b = new FilterExpressionBuilder();
    .query("The World")
    .topK(TOP_K)
    .filterExpression(b.and(
        b.in("author","john", "jill"),
        b.eq("article_type", "blog")).build()).build());
These filter expressions are converted into PostgreSQL JSON path expressions for efficient metadata filtering.
Manual Configuration
Instead of using the Spring Boot auto-configuration, you can manually configure the PgVectorStore. For this you need to add the PostgreSQL connection and JdbcTemplate auto-configuration dependencies to your project:spring-doc.cn
<dependency>
	<artifactId>spring-boot-starter-jdbc</artifactId>
</dependency>
<dependency>
	<groupId>org.postgresql</groupId>
	<artifactId>postgresql</artifactId>
	<scope>runtime</scope>
</dependency>
<dependency>
	<artifactId>spring-ai-pgvector-store</artifactId>
</dependency>
To configure PgVector in your application, you can use the following setup:spring-doc.cn
public VectorStore vectorStore(JdbcTemplate jdbcTemplate, EmbeddingModel embeddingModel) {
    return PgVectorStore.builder(jdbcTemplate, embeddingModel)
        .dimensions(1536)                    // Optional: defaults to model dimensions or 1536
        .distanceType(COSINE_DISTANCE)       // Optional: defaults to COSINE_DISTANCE
        .indexType(HNSW)                     // Optional: defaults to HNSW
        .initializeSchema(true)              // Optional: defaults to false
        .schemaName("public")                // Optional: defaults to "public"
        .vectorTableName("vector_store")     // Optional: defaults to "vector_store"
        .maxDocumentBatchSize(10000)         // Optional: defaults to 10000
Run Postgres & PGVector DB locally
docker run -it --rm --name postgres -p 5432:5432 -e POSTGRES_USER=postgres -e POSTGRES_PASSWORD=postgres pgvector/pgvector
You can connect to this server like this:spring-doc.cn
psql -U postgres -h localhost -p 5432
Accessing the Native Client
The PGVector Store implementation provides access to the underlying native JDBC client (JdbcTemplate) through the getNativeClient() method:spring-doc.cn
PgVectorStore vectorStore = context.getBean(PgVectorStore.class);
Optional<JdbcTemplate> nativeClient = vectorStore.getNativeClient();
if (nativeClient.isPresent()) {
    JdbcTemplate jdbc = nativeClient.get();
    // Use the native client for PostgreSQL-specific operations
The native client gives you access to PostgreSQL-specific features and operations that might not be exposed through the VectorStore interface.spring-doc.cn
