This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
Typesense
This section walks you through setting up TypesenseVectorStore to store document embeddings and perform similarity searches.spring-doc.cn
Typesense is an open source typo tolerant search engine that is optimized for instant sub-50ms searches while providing an intuitive developer experience. It provides vector search capabilities that allow you to store and query high-dimensional vectors alongside your regular search data.spring-doc.cn
Prerequisites
Auto-configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information.spring-doc.cn
Spring AI provides Spring Boot auto-configuration for the Typesense Vector Store. To enable it add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-starter-vector-store-typesense</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-starter-vector-store-typesense'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Please have a look at the list of configuration parameters for the vector store to learn about the default values and configuration options.spring-doc.cn
Refer to the Repositories section to add Maven Central and/or Snapshot Repositories to your build file.
The vector store implementation can initialize the requisite schema for you but you must opt-in by setting …​initialize-schema=true in the application.properties file.spring-doc.cn
Additionally you will need a configured EmbeddingModel bean. Refer to the EmbeddingModel section for more information.spring-doc.cn
Now you can auto-wire the TypesenseVectorStore as a vector store in your application:spring-doc.cn
@Autowired VectorStore vectorStore;
List<Document> documents = List.of(
    new Document("Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!!", Map.of("meta1", "meta1")),
    new Document("The World is Big and Salvation Lurks Around the Corner"),
    new Document("You walk forward facing the past and you turn back toward the future.", Map.of("meta2", "meta2")));
// Add the documents to Typesense
vectorStore.add(documents);
// Retrieve documents similar to a query
List<Document> results = vectorStore.similaritySearch(SearchRequest.builder().query("Spring").topK(5).build());
Configuration Properties
To connect to Typesense and use the TypesenseVectorStore you need to provide access details for your instance. A simple configuration can be provided via Spring Boot’s application.yml:spring-doc.cn
spring:
  ai:
    vectorstore:
      typesense:
        initialize-schema: true
        collection-name: vector_store
        embedding-dimension: 1536
        client:
          protocol: http
          host: localhost
          port: 8108
          api-key: xyz
Properties starting with spring.ai.vectorstore.typesense.* are used to configure the TypesenseVectorStore:spring-doc.cn
Property Description Default Value
spring.ai.vectorstore.typesense.initialize-schemaspring-doc.cn
Whether to initialize the required schemaspring-doc.cn
falsespring-doc.cn
spring.ai.vectorstore.typesense.collection-namespring-doc.cn
The name of the collection to store vectorsspring-doc.cn
vector_storespring-doc.cn
spring.ai.vectorstore.typesense.embedding-dimensionspring-doc.cn
The number of dimensions in the vectorspring-doc.cn
1536spring-doc.cn
spring.ai.vectorstore.typesense.client.protocolspring-doc.cn
HTTP Protocolspring-doc.cn
httpspring-doc.cn
spring.ai.vectorstore.typesense.client.hostspring-doc.cn
Hostnamespring-doc.cn
localhostspring-doc.cn
spring.ai.vectorstore.typesense.client.portspring-doc.cn
Portspring-doc.cn
8108spring-doc.cn
spring.ai.vectorstore.typesense.client.api-keyspring-doc.cn
API Keyspring-doc.cn
xyzspring-doc.cn
Manual Configuration
Instead of using the Spring Boot auto-configuration you can manually configure the Typesense vector store. For this you need to add the spring-ai-typesense-store to your project:spring-doc.cn
<dependency>
    <artifactId>spring-ai-typesense-store</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-typesense-store'
Create a Typesense Client bean:spring-doc.cn
public Client typesenseClient() {
    List<Node> nodes = new ArrayList<>();
    nodes.add(new Node("http", "localhost", "8108"));
    Configuration configuration = new Configuration(nodes, Duration.ofSeconds(5), "xyz");
    return new Client(configuration);
Then create the TypesenseVectorStore bean using the builder pattern:spring-doc.cn
public VectorStore vectorStore(Client client, EmbeddingModel embeddingModel) {
    return TypesenseVectorStore.builder(client, embeddingModel)
        .collectionName("custom_vectors")     // Optional: defaults to "vector_store"
        .embeddingDimension(1536)            // Optional: defaults to 1536
        .initializeSchema(true)              // Optional: defaults to false
        .batchingStrategy(new TokenCountBatchingStrategy()) // Optional: defaults to TokenCountBatchingStrategy
// This can be any EmbeddingModel implementation
public EmbeddingModel embeddingModel() {
    return new OpenAiEmbeddingModel(new OpenAiApi(System.getenv("OPENAI_API_KEY")));
Metadata Filtering
You can leverage the generic portable metadata filters with Typesense store as well.spring-doc.cn
For example you can use either the text expression language:spring-doc.cn
        .query("The World")
        .topK(TOP_K)
        .similarityThreshold(SIMILARITY_THRESHOLD)
        .filterExpression("country in ['UK', 'NL'] && year >= 2020").build());
or programmatically using the Filter.Expression DSL:spring-doc.cn
FilterExpressionBuilder b = new FilterExpressionBuilder();
    .query("The World")
    .topK(TOP_K)
    .filterExpression(b.and(
        b.in("country", "UK", "NL"),
        b.gte("year", 2020)).build()).build());
Those (portable) filter expressions get automatically converted into Typesense Search Filters.
For example this portable filter expression:spring-doc.cn
is converted into the proprietary Typesense filter format:spring-doc.cn
country: ['UK', 'NL'] && year: >=2020
If you are not retrieving the documents in the expected order or the search results are not as expected, check the embedding model you are using.spring-doc.cn
Embedding models can have a significant impact on the search results (i.e. make sure if your data is in Spanish to use a Spanish or multilingual embedding model).spring-doc.cn
Accessing the Native Client
The Typesense Vector Store implementation provides access to the underlying native Typesense client (Client) through the getNativeClient() method:spring-doc.cn
TypesenseVectorStore vectorStore = context.getBean(TypesenseVectorStore.class);
Optional<Client> nativeClient = vectorStore.getNativeClient();
if (nativeClient.isPresent()) {
    Client client = nativeClient.get();
    // Use the native client for Typesense-specific operations
The native client gives you access to Typesense-specific features and operations that might not be exposed through the VectorStore interface.spring-doc.cn
