This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
Observability
Spring AI builds upon the observability features in the Spring ecosystem to provide insights into AI-related operations.
Spring AI provides metrics and tracing capabilities for its core components: ChatClient
(including Advisor
ChatModel
, EmbeddingModel
, ImageModel
, and VectorStore
Low cardinality keys will be added to metrics and traces, while high cardinality keys will only be added to traces. |
Chat Client
The spring.ai.chat.client
observations are recorded when a ChatClient call()
or stream()
operations are invoked.
They measure the time spent performing the invocation and propagate the related tracing information.
Name | Description |
Always |
Always |
Is the chat model response a stream - |
The kind of framework API in Spring AI: |
The content of the prompt sent via the chat client. Optional. |
Map of advisor parameters. The conversation ID is now included in |
List of configured chat client advisors. |
Identifier of the conversation when using the chat memory. |
Chat client system parameters. Optional. Superseded by |
Chat client system text. Optional. Superseded by |
Enabled tool function names. Superseded by |
List of configured chat client function callbacks. Superseded by |
Names of the tools passed to the chat client. |
Chat client user parameters. Optional. Superseded by |
Chat client user text. Optional. Superseded by |
Prompt Content
The ChatClient
prompt content is typically big and possibly containing sensitive information.
For those reasons, it is not exported by default.
Spring AI supports exporting the prompt content as span attributes/events across all tracing backends.
Property | Description | Default |
Whether to include the chat client prompt content in the observations. |
If you enable the inclusion of the chat client prompt content in the observations, there’s a risk of exposing sensitive or private information. Please, be careful! |
Input Data (Deprecated)
The spring.ai.chat.client.observations.include-input property is deprecated, replaced by spring.ai.chat.client.observations.include-prompt . See Prompt Content.
The ChatClient
input data is typically big and possibly containing sensitive information.
Spring AI supports exporting input data as span attributes/events across all tracing backends.
Whether to include the input content in the observations. |
If you enable the inclusion of the input content in the observations, there’s a risk of exposing sensitive or private information. Please, be careful! |
Chat Client Advisors
The spring.ai.advisor
observations are recorded when an advisor is executed.
They measure the time spent in the advisor (including the time spend on the inner advisors) and propagate the related tracing information.
Always |
Always |
Where the advisor applies it’s logic in the request processing, one of |
Name of the advisor. |
Advisor order in the advisor chain. |
Chat Model
Observability features are currently supported only for ChatModel implementations from the following AI model
providers: Anthropic, Azure OpenAI, Mistral AI, Ollama, OpenAI, Vertex AI, MiniMax, Moonshot, QianFan, Zhiu AI.
Additional AI model providers will be supported in a future release.
The gen_ai.client.operation
observations are recorded when calling the ChatModel call
or stream
methods.
They measure the time spent on method completion and propagate the related tracing information.
The gen_ai.client.token.usage metrics measures number of input and output tokens used by a single model call.
The name of the operation being performed. |
The model provider as identified by the client instrumentation. |
The name of the model a request is being made to. |
The name of the model that generated the response. |
The frequency penalty setting for the model request. |
The maximum number of tokens the model generates for a request. |
The presence penalty setting for the model request. |
List of sequences that the model will use to stop generating further tokens. |
The temperature setting for the model request. |
The top_k sampling setting for the model request. |
The top_p sampling setting for the model request. |
Reasons the model stopped generating tokens, corresponding to each generation received. |
The unique identifier for the AI response. |
The number of tokens used in the model input (prompt). |
The number of tokens used in the model output (completion). |
The total number of tokens used in the model exchange. |
The full prompt sent to the model. Optional. |
The full response received from the model. Optional. |
For measuring user tokens, the previous table lists the values present in an observation trace.
Use the metric name gen_ai.client.token.usage that is provided by the ChatModel .
Event including the content of the chat prompt. Optional. |
Event including the content of the chat completion. Optional. |
Chat Prompt and Completion Data
The chat prompt and completion data is typically big and possibly containing sensitive information. For those reasons, it is not exported by default.
Spring AI supports exporting chat prompt and completion data as span events if you use an OpenTelemetry tracing backend, whereas data is exported as span attributes if you use an OpenZipkin tracing backend.
Furthermore, Spring AI supports logging chat prompt and completion data, useful for troubleshooting scenarios.
Include the prompt content in observations. |
Include the completion content in observations. |
Include error logging in observations. |
If you enable the inclusion of the chat prompt and completion data in the observations, there’s a risk of exposing sensitive or private information. Please, be careful! |
EmbeddingModel
Observability features are currently supported only for EmbeddingModel implementations from the following
AI model providers: Azure OpenAI, Mistral AI, Ollama, and OpenAI.
observations are recorded on embedding model method calls.
The number of dimensions the resulting output embeddings have. |
The number of tokens used in the model input. |
Use the metric name gen_ai.client.token.usage that is provided by the EmbeddingModel .
Image Model
Observability features are currently supported only for ImageModel implementations from the following AI model
providers: OpenAI.
observations are recorded on image model method calls.
The format in which the generated image is returned. |
The size of the image to generate. |
The style of the image to generate. |
The number of tokens used in the model output (generation). |
Use the metric name gen_ai.client.token.usage that is provided by the ImageModel .
Event including the content of the image prompt. Optional. |
Image Prompt Data
The image prompt data is typically big and possibly containing sensitive information. For those reasons, it is not exported by default.
Spring AI supports exporting image prompt data as span events if you use an OpenTelemetry tracing backend, whereas data is exported as span attributes if you use an OpenZipkin tracing backend.
If you enable the inclusion of the image prompt data in the observations, there’s a risk of exposing sensitive or private information. Please, be careful! |
Vector Stores
All vector store implementations in Spring AI are instrumented to provide metrics and distributed tracing data through Micrometer.
The db.vector.client.operation
observations are recorded when interacting with the Vector Store.
They measure the time spent on the query
, add
and remove
operations and propagate the related tracing information.
The name of the operation or command being executed. One of |
The database management system (DBMS) product as identified by the client instrumentation. One of |
The name of a collection (table, container) within the database. |
The name of the database, fully qualified within the server address and port. |
The record identifier if present. |
The metric used in similarity search. |
The dimension of the vector. |
The name field as of the vector (e.g. a field name). |
The content of the search query being executed. |
The metadata filters used in the search query. |
Returned documents from a similarity search query. Optional. |
Similarity threshold that accepts all search scores. A threshold value of 0.0 means any similarity is accepted or disable the similarity threshold filtering. A threshold value of 1.0 means an exact match is required. |
The top-k most similar vectors returned by a query. |
Event including the vector search response data. Optional. |
Response Data
The vector search response data is typically big and possibly containing sensitive information. For those reasons, it is not exported by default.
Spring AI supports exporting vector search response data as span events if you use an OpenTelemetry tracing backend, whereas data is exported as span attributes if you use an OpenZipkin tracing backend.
If you enable the inclusion of the vector search response data in the observations, there’s a risk of exposing sensitive or private information. Please, be careful! |
