This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
Advisors API
The Spring AI Advisors API provides a flexible and powerful way to intercept, modify, and enhance AI-driven interactions in your Spring applications. By leveraging the Advisors API, developers can create more sophisticated, reusable, and maintainable AI components.spring-doc.cn
The key benefits include encapsulating recurring Generative AI patterns, transforming data sent to and from Large Language Models (LLMs), and providing portability across various models and use cases.spring-doc.cn
You can configure existing advisors using the ChatClient API as shown in the following example:spring-doc.cn
var chatClient = ChatClient.builder(chatModel)
    .defaultAdvisors(
        new MessageChatMemoryAdvisor(chatMemory), // chat-memory advisor
        new QuestionAnswerAdvisor(vectorStore)    // RAG advisor
String response = this.chatClient.prompt()
    // Set advisor parameters at runtime
    .advisors(advisor -> advisor.param("chat_memory_conversation_id", "678")
            .param("chat_memory_response_size", 100))
    .user(userText)
    .call()
	.content();
It is recommend to register the advisors at build time using builder’s defaultAdvisors() method.spring-doc.cn
Advisors also participate in the Observability stack, so you can view metrics and traces related to their execution.spring-doc.cn
Core Components
The API consists of CallAroundAdvisor and CallAroundAdvisorChain for non-streaming scenarios, and StreamAroundAdvisor and StreamAroundAdvisorChain for streaming scenarios. It also includes AdvisedRequest to represent the unsealed Prompt request, AdvisedResponse for the Chat Completion response. Both hold an advise-context to share state across the advisor chain.spring-doc.cn
Advisors API Classes
The nextAroundCall() and the nextAroundStream() are the key advisor methods, typically performing actions such as examining the unsealed Prompt data, customizing and augmenting the Prompt data, invoking the next entity in the advisor chain, optionally blocking the request, examining the chat completion response, and throwing exceptions to indicate processing errors.spring-doc.cn
In addition the getOrder() method determines advisor order in the chain, while getName() provides a unique advisor name.spring-doc.cn
The Advisor Chain, created by the Spring AI framework, allows sequential invocation of multiple advisors ordered by their getOrder() values. The lower values are executed first. The last advisor, added automatically, sends the request to the LLM.spring-doc.cn
Following flow diagram illustrates the interaction between the advisor chain and the Chat Model:spring-doc.cn
Advisors API Flow
  1. The Spring AI framework creates an AdvisedRequest from user’s Prompt along with an empty AdvisorContext object.spring-doc.cn
  2. Each advisor in the chain processes the request, potentially modifying it. Alternatively, it can choose to block the request by not making the call to invoke the next entity. In the latter case, the advisor is responsible for filling out the response.spring-doc.cn
  3. The final advisor, provided by the framework, sends the request to the Chat Model.spring-doc.cn
  4. The Chat Model’s response is then passed back through the advisor chain and converted into AdvisedResponse. Later includes the shared AdvisorContext instance.spring-doc.cn
  5. Each advisor can process or modify the response.spring-doc.cn
  6. The final AdvisedResponse is returned to the client by extracting the ChatCompletion.spring-doc.cn
Advisor Order
The execution order of advisors in the chain is determined by the getOrder() method. Key points to understand:spring-doc.cn
  • Advisors with lower order values are executed first.spring-doc.cn
  • The advisor chain operates as a stack:spring-doc.cn
    • The first advisor in the chain is the first to process the request.spring-doc.cn
    • It is also the last to process the response.spring-doc.cn
  • To control execution order:spring-doc.cn
    • Set the order close to Ordered.HIGHEST_PRECEDENCE to ensure an advisor is executed first in the chain (first for request processing, last for response processing).spring-doc.cn
    • Set the order close to Ordered.LOWEST_PRECEDENCE to ensure an advisor is executed last in the chain (last for request processing, first for response processing).spring-doc.cn
  • Higher values are interpreted as lower priority.spring-doc.cn
  • If multiple advisors have the same order value, their execution order is not guaranteed.spring-doc.cn
The seeming contradiction between order and execution sequence is due to the stack-like nature of the advisor chain:spring-doc.cn
  • An advisor with the highest precedence (lowest order value) is added to the top of the stack.spring-doc.cn
  • It will be the first to process the request as the stack unwinds.spring-doc.cn
  • It will be the last to process the response as the stack rewinds.spring-doc.cn
As a reminder, here are the semantics of the Spring Ordered interface:spring-doc.cn
public interface Ordered {
     * Constant for the highest precedence value.
     * @see java.lang.Integer#MIN_VALUE
    int HIGHEST_PRECEDENCE = Integer.MIN_VALUE;
     * Constant for the lowest precedence value.
     * @see java.lang.Integer#MAX_VALUE
    int LOWEST_PRECEDENCE = Integer.MAX_VALUE;
     * Get the order value of this object.
     * <p>Higher values are interpreted as lower priority. As a consequence,
     * the object with the lowest value has the highest priority (somewhat
     * analogous to Servlet {@code load-on-startup} values).
     * <p>Same order values will result in arbitrary sort positions for the
     * affected objects.
     * @return the order value
     * @see #HIGHEST_PRECEDENCE
     * @see #LOWEST_PRECEDENCE
    int getOrder();
For use cases that need to be first in the chain on both the input and output sides:spring-doc.cn
  1. Use separate advisors for each side.spring-doc.cn
  2. Configure them with different order values.spring-doc.cn
  3. Use the advisor context to share state between them.spring-doc.cn
API Overview
The main Advisor interfaces are located in the package org.springframework.ai.chat.client.advisor.api. Here are the key interfaces you’ll encounter when creating your own advisor:spring-doc.cn
public interface Advisor extends Ordered {
	String getName();
The two sub-interfaces for synchronous and reactive Advisors arespring-doc.cn
public interface CallAroundAdvisor extends Advisor {
	 * Around advice that wraps the ChatModel#call(Prompt) method.
	 * @param advisedRequest the advised request
	 * @param chain the advisor chain
	 * @return the response
	AdvisedResponse aroundCall(AdvisedRequest advisedRequest, CallAroundAdvisorChain chain);
public interface StreamAroundAdvisor extends Advisor {
	 * Around advice that wraps the invocation of the advised request.
	 * @param chain the chain of advisors to execute
	 * @return the result of the advised request
	Flux<AdvisedResponse> aroundStream(AdvisedRequest advisedRequest, StreamAroundAdvisorChain chain);
To continue the chain of Advice, use CallAroundAdvisorChain and StreamAroundAdvisorChain in your Advice implementation:spring-doc.cn
The interfaces arespring-doc.cn
public interface CallAroundAdvisorChain {
	AdvisedResponse nextAroundCall(AdvisedRequest advisedRequest);
public interface StreamAroundAdvisorChain {
	Flux<AdvisedResponse> nextAroundStream(AdvisedRequest advisedRequest);
Implementing an Advisor
To create an advisor, implement either CallAroundAdvisor or StreamAroundAdvisor (or both). The key method to implement is nextAroundCall() for non-streaming or nextAroundStream() for streaming advisors.spring-doc.cn
Examples
We will provide few hands-on examples to illustrate how to implement advisors for observing and augmenting use-cases.spring-doc.cn
Logging Advisor
We can implement a simple logging advisor that logs the AdvisedRequest before and the AdvisedResponse after the call to the next advisor in the chain. Note that the advisor only observes the request and response and does not modify them. This implementation support both non-streaming and streaming scenarios.spring-doc.cn
public class SimpleLoggerAdvisor implements CallAroundAdvisor, StreamAroundAdvisor {
	private static final Logger logger = LoggerFactory.getLogger(SimpleLoggerAdvisor.class);
	public String getName() { (1)
		return this.getClass().getSimpleName();
	public int getOrder() { (2)
		return 0;
	public AdvisedResponse aroundCall(AdvisedRequest advisedRequest, CallAroundAdvisorChain chain) {
		logger.debug("BEFORE: {}", advisedRequest);
		AdvisedResponse advisedResponse = chain.nextAroundCall(advisedRequest);
		logger.debug("AFTER: {}", advisedResponse);
		return advisedResponse;
	public Flux<AdvisedResponse> aroundStream(AdvisedRequest advisedRequest, StreamAroundAdvisorChain chain) {
		Flux<AdvisedResponse> advisedResponses = chain.nextAroundStream(advisedRequest);
        return new MessageAggregator().aggregateAdvisedResponse(advisedResponses,
                    advisedResponse -> logger.debug("AFTER: {}", advisedResponse)); (3)
1 Provides a unique name for the advisor.
2 You can control the order of execution by setting the order value. Lower values execute first.
3 The MessageAggregator is a utility class that aggregates the Flux responses into a single AdvisedResponse. This can be useful for logging or other processing that observe the entire response rather than individual items in the stream. Note that you can not alter the response in the MessageAggregator as it is a read-only operation.
Re-Reading (Re2) Advisor
The "Re-Reading Improves Reasoning in Large Language Models" article introduces a technique called Re-Reading (Re2) that improves the reasoning capabilities of Large Language Models. The Re2 technique requires augmenting the input prompt like this:spring-doc.cn
{Input_Query}
Read the question again: {Input_Query}
Implementing an advisor that applies the Re2 technique to the user’s input query can be done like this:spring-doc.cn
public class ReReadingAdvisor implements CallAroundAdvisor, StreamAroundAdvisor {
	private AdvisedRequest before(AdvisedRequest advisedRequest) { (1)
		Map<String, Object> advisedUserParams = new HashMap<>(advisedRequest.userParams());
		advisedUserParams.put("re2_input_query", advisedRequest.userText());
		return AdvisedRequest.from(advisedRequest)
			.userText("""
			    {re2_input_query}
			    Read the question again: {re2_input_query}
			.userParams(advisedUserParams)
	public AdvisedResponse aroundCall(AdvisedRequest advisedRequest, CallAroundAdvisorChain chain) { (2)
		return chain.nextAroundCall(this.before(advisedRequest));
	public Flux<AdvisedResponse> aroundStream(AdvisedRequest advisedRequest, StreamAroundAdvisorChain chain) { (3)
		return chain.nextAroundStream(this.before(advisedRequest));
	public int getOrder() { (4)
		return 0;
    public String getName() { (5)
1 The before method augments the user’s input query applying the Re-Reading technique.
2 The aroundCall method intercepts the non-streaming request and applies the Re-Reading technique.
3 The aroundStream method intercepts the streaming request and applies the Re-Reading technique.
4 You can control the order of execution by setting the order value. Lower values execute first.
5 Provides a unique name for the advisor.
Spring AI Built-in Advisors
Spring AI framework provides several built-in advisors to enhance your AI interactions. Here’s an overview of the available advisors:spring-doc.cn
Chat Memory Advisors
These advisors manage conversation history in a chat memory store:spring-doc.cn
  • MessageChatMemoryAdvisorspring-doc.cn
    Retrieves memory and adds it as a collection of messages to the prompt. This approach maintains the structure of the conversation history. Note, not all AI Models support this approach.spring-doc.cn
  • PromptChatMemoryAdvisorspring-doc.cn
    Retrieves memory and incorporates it into the prompt’s system text.spring-doc.cn
  • VectorStoreChatMemoryAdvisorspring-doc.cn
    Retrieves memory from a VectorStore and adds it into the prompt’s system text. This advisor is useful for efficiently searching and retrieving relevant information from large datasets.spring-doc.cn
Question Answering Advisor
  • QuestionAnswerAdvisorspring-doc.cn
    This advisor uses a vector store to provide question-answering capabilities, implementing the RAG (Retrieval-Augmented Generation) pattern.spring-doc.cn
Content Safety Advisor
  • SafeGuardAdvisorspring-doc.cn
    A simple advisor designed to prevent the model from generating harmful or inappropriate content.spring-doc.cn
Streaming vs Non-Streaming
Advisors Streaming vs Non-Streaming Flow
  • Non-streaming advisors work with complete requests and responses.spring-doc.cn
  • Streaming advisors handle requests and responses as continuous streams, using reactive programming concepts (e.g., Flux for responses).spring-doc.cn
    return  Mono.just(advisedRequest)
            .publishOn(Schedulers.boundedElastic())
            .map(request -> {
                // This can be executed by blocking and non-blocking Threads.
                // Advisor before next section
            .flatMapMany(request -> chain.nextAroundStream(request))
            .map(response -> {
                // Advisor after next section
Best Practices
  1. Keep advisors focused on specific tasks for better modularity.spring-doc.cn
  2. Use the adviseContext to share state between advisors when necessary.spring-doc.cn
  3. Implement both streaming and non-streaming versions of your advisor for maximum flexibility.spring-doc.cn
  4. Carefully consider the order of advisors in your chain to ensure proper data flow.spring-doc.cn
Backward Compatibility
The AdvisedRequest class is moved to a new package.
Breaking API Changes
The Spring AI Advisor Chain underwent significant changes from version 1.0 M2 to 1.0 M3. Here are the key modifications:spring-doc.cn
Advisor Interfaces
  • In 1.0 M2, there were separate RequestAdvisor and ResponseAdvisor interfaces.spring-doc.cn
    • RequestAdvisor was invoked before the ChatModel.call and ChatModel.stream methods.spring-doc.cn
    • ResponseAdvisor was called after these methods.spring-doc.cn
  • In 1.0 M3, these interfaces have been replaced with:spring-doc.cn
  • The StreamResponseMode, previously part of ResponseAdvisor, has been removed.spring-doc.cn
Context Map Handling
Example of updating the context in 1.0 M3:spring-doc.cn
    this.advisedRequest = advisedRequest.updateContext(context -> {
        context.put("aroundCallBefore" + getName(), "AROUND_CALL_BEFORE " + getName());  // Add multiple key-value pairs
        context.put("lastBefore", getName());  // Add a single key-value pair
        return context;
    // Method implementation continues...
