This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
Tool Calling
Tool calling (also known as function calling) is a common pattern in AI applications allowing a model to interact with a set of APIs, or tools, augmenting its capabilities.spring-doc.cn
Tools are mainly used for:spring-doc.cn
  • Information Retrieval. Tools in this category can be used to retrieve information from external sources, such as a database, a web service, a file system, or a web search engine. The goal is to augment the knowledge of the model, allowing it to answer questions that it would not be able to answer otherwise. As such, they can be used in Retrieval Augmented Generation (RAG) scenarios. For example, a tool can be used to retrieve the current weather for a given location, to retrieve the latest news articles, or to query a database for a specific record.spring-doc.cn
  • Taking Action. Tools in this category can be used to take action in a software system, such as sending an email, creating a new record in a database, submitting a form, or triggering a workflow. The goal is to automate tasks that would otherwise require human intervention or explicit programming. For example, a tool can be used to book a flight for a customer interacting with a chatbot, to fill out a form on a web page, or to implement a Java class based on an automated test (TDD) in a code generation scenario.spring-doc.cn
Even though we typically refer to tool calling as a model capability, it is actually up to the client application to provide the tool calling logic. The model can only request a tool call and provide the input arguments, whereas the application is responsible for executing the tool call from the input arguments and returning the result. The model never gets access to any of the APIs provided as tools, which is a critical security consideration.spring-doc.cn
Spring AI provides convenient APIs to define tools, resolve tool call requests from a model, and execute the tool calls. The following sections provide an overview of the tool calling capabilities in Spring AI.spring-doc.cn
Check the Chat Model Comparisons to see which AI models support tool calling invocation.
Quick Start
Let’s see how to start using tool calling in Spring AI. We’ll implement two simple tools: one for information retrieval and one for taking action. The information retrieval tool will be used to get the current date and time in the user’s time zone. The action tool will be used to set an alarm for a specified time.spring-doc.cn
AI models don’t have access to real-time information. Any question that assumes awareness of information such as the current date or weather forecast cannot be answered by the model. However, we can provide a tool that can retrieve this information, and let the model call this tool when access to real-time information is needed.spring-doc.cn
Let’s implement a tool to get the current date and time in the user’s time zone in a DateTimeTools class. The tool will take no argument. The LocaleContextHolder from Spring Framework can provide the user’s time zone. The tool will be defined as a method annotated with @Tool. To help the model understand if and when to call this tool, we’ll provide a detailed description of what the tools does.spring-doc.cn
import java.time.LocalDateTime;
import org.springframework.ai.tool.annotation.Tool;
import org.springframework.context.i18n.LocaleContextHolder;
class DateTimeTools {
    @Tool(description = "Get the current date and time in the user's timezone")
    String getCurrentDateTime() {
        return LocalDateTime.now().atZone(LocaleContextHolder.getTimeZone().toZoneId()).toString();
Next, let’s make the tool available to the model. In this example, we’ll use the ChatClient to interact with the model. We’ll provide the tool to the model by passing an instance of DateTimeTools via the tools() method. When the model needs to know the current date and time, it will request the tool to be called. Internally, the ChatClient will call the tool and return the result to the model, which will then use the tool call result to generate the final response to the original question.spring-doc.cn
ChatModel chatModel = ...
String response = ChatClient.create(chatModel)
        .prompt("What day is tomorrow?")
        .tools(new DateTimeTools())
        .call()
        .content();
System.out.println(response);
The output will be something like:spring-doc.cn
Tomorrow is 2015-10-21.
You can retry asking the same question again. This time, don’t provide the tool to the model. The output will be something like:spring-doc.cn
I am an AI and do not have access to real-time information. Please provide the current date so I can accurately determine what day tomorrow will be.
Without the tool, the model doesn’t know how to answer the question because it doesn’t have the ability to determine the current date and time.spring-doc.cn
Taking Actions
AI models can be used to generate plans for accomplishing certain goals. For example, a model can generate a plan for booking a trip to Denmark. However, the model doesn’t have the ability to execute the plan. That’s where tools come in: they can be used to execute the plan that a model generates.spring-doc.cn
In the previous example, we used a tool to determine the current date and time. In this example, we’ll define a second tool for setting an alarm at a specific time. The goal is to set an alarm for 10 minutes from now, so we need to provide both tools to the model to accomplish this task.spring-doc.cn
We’ll add the new tool to the same DateTimeTools class as before. The new tool will take a single parameter, which is the time in ISO-8601 format. The tool will then print a message to the console indicating that the alarm has been set for the given time. Like before, the tool is defined as a method annotated with @Tool, which we also use to provide a detailed description to help the model understand when and how to use the tool.spring-doc.cn
import java.time.format.DateTimeFormatter;
    @Tool(description = "Set a user alarm for the given time, provided in ISO-8601 format")
    void setAlarm(String time) {
        LocalDateTime alarmTime = LocalDateTime.parse(time, DateTimeFormatter.ISO_DATE_TIME);
        System.out.println("Alarm set for " + alarmTime);
Next, let’s make both tools available to the model. We’ll use the ChatClient to interact with the model. We’ll provide the tools to the model by passing an instance of DateTimeTools via the tools() method. When we ask to set up an alarm 10 minutes from now, the model will first need to know the current date and time. Then, it will use the current date and time to calculate the alarm time. Finally, it will use the alarm tool to set up the alarm. Internally, the ChatClient will handle any tool call request from the model and send back to it any tool call execution result, so that the model can generate the final response.spring-doc.cn
        .prompt("Can you set an alarm 10 minutes from now?")
        .call()
        .content();
In the application logs, you can check the alarm has been set at the correct time.spring-doc.cn
Overview
Spring AI supports tool calling through a set of flexible abstractions that allow you to define, resolve, and execute tools in a consistent way. This section provides an overview of the main concepts and components of tool calling in Spring AI.spring-doc.cn
The main sequence of actions for tool calling
  1. When we want to make a tool available to the model, we include its definition in the chat request. Each tool definition comprises of a name, a description, and the schema of the input parameters.spring-doc.cn
  2. When the model decides to call a tool, it sends a response with the tool name and the input parameters modeled after the defined schema.spring-doc.cn
  3. The application is responsible for using the tool name to identify and execute the tool with the provided input parameters.spring-doc.cn
  4. The result of the tool call is processed by the application.spring-doc.cn
  5. The application sends the tool call result back to the model.spring-doc.cn
  6. The model generates the final response using the tool call result as additional context.spring-doc.cn
Tools are the building blocks of tool calling and they are modeled by the ToolCallback interface. Spring AI provides built-in support for specifying ToolCallback(s) from methods and functions, but you can always define your own ToolCallback implementations to support more use cases.spring-doc.cn
ChatModel implementations transparently dispatch tool call requests to the corresponding ToolCallback implementations and will send the tool call results back to the model, which will ultimately generate the final response. They do so using the ToolCallingManager interface, which is responsible for managing the tool execution lifecycle.spring-doc.cn
Both ChatClient and ChatModel accept a list of ToolCallback objects to make the tools available to the model and the ToolCallingManager that will eventually execute them.spring-doc.cn
Besides passing the ToolCallback objects directly, you can also pass a list of tool names, that will be resolved dynamically using the ToolCallbackResolver interface.spring-doc.cn
The following sections will go into more details about all these concepts and APIs, including how to customize and extend them to support more use cases.spring-doc.cn
Methods as Tools
Spring AI provides built-in support for specifying tools (i.e. ToolCallback(s)) from methods in two ways:spring-doc.cn
  • declaratively, using the @Tool annotationspring-doc.cn
  • programmatically, using the low-level MethodToolCallback implementation.spring-doc.cn
Declarative Specification: @Tool
You can turn a method into a tool by annotating it with @Tool.spring-doc.cn
The @Tool annotation allows you to provide key information about the tool:spring-doc.cn
  • name: The name of the tool. If not provided, the method name will be used. AI models use this name to identify the tool when calling it. Therefore, it’s not allowed to have two tools with the same name in the same class. The name must be unique across all the tools available to the model for a specific chat request.spring-doc.cn
  • description: The description for the tool, which can be used by the model to understand when and how to call the tool. If not provided, the method name will be used as the tool description. However, it’s strongly recommended to provide a detailed description because that’s paramount for the model to understand the tool’s purpose and how to use it. Failing in providing a good description can lead to the model not using the tool when it should or using it incorrectly.spring-doc.cn
  • returnDirect: Whether the tool result should be returned directly to the client or passed back to the model. See Return Direct for more details.spring-doc.cn
  • resultConverter: The ToolCallResultConverter implementation to use for converting the result of a tool call to a String object to send back to the AI model. See Result Conversion for more details.spring-doc.cn
The method can be either static or instance, and it can have any visibility (public, protected, package-private, or private). The class that contains the method can be either a top-level class or a nested class, and it can also have any visibility (as long as it’s accessible where you’re planning to instantiate it).spring-doc.cn
Spring AI provides built-in support for AOT compilation of the @Tool-annotated methods as long as the class containing the methods is a Spring bean (e.g. @Component). Otherwise, you’ll need to provide the necessary configuration to the GraalVM compiler. For example, by annotating the class with @RegisterReflection(memberCategories = MemberCategory.INVOKE_DECLARED_METHODS).
You can define any number of arguments for the method (including no argument) with most types (primitives, POJOs, enums, lists, arrays, maps, and so on). Similarly, the method can return most types, including void. If the method returns a value, the return type must be a serializable type, as the result will be serialized and sent back to the model.spring-doc.cn
Some types are not supported. See Method Tool Limitations for more details.
Spring AI will generate the JSON schema for the input parameters of the @Tool-annotated method automatically. The schema is used by the model to understand how to call the tool and prepare the tool request. The @ToolParam annotation can be used to provide additional information about the input parameters, such as a description or whether the parameter is required or optional. By default, all input parameters are considered required.spring-doc.cn
import org.springframework.ai.tool.annotation.ToolParam;
    @Tool(description = "Set a user alarm for the given time")
    void setAlarm(@ToolParam(description = "Time in ISO-8601 format") String time) {
The @ToolParam annotation allows you to provide key information about a tool parameter:spring-doc.cn
  • description: The description for the parameter, which can be used by the model to understand better how to use it. For example, what format the parameter should be in, what values are allowed, and so on.spring-doc.cn
  • required: Whether the parameter is required or optional. By default, all parameters are considered required.spring-doc.cn
If a parameter is annotated as @Nullable, it will be considered optional unless explicitly marked as required using the @ToolParam annotation.spring-doc.cn
Besides the @ToolParam annotation, you can also use the @Schema annotation from Swagger or @JsonProperty from Jackson. See JSON Schema for more details.spring-doc.cn
Adding Tools to ChatClient
When using the declarative specification approach, you can pass the tool class instance to the tools() method when invoking a ChatClient. Such tools will only be available for the specific chat request they are added to.spring-doc.cn
    .call()
    .content();
Under the hood, the ChatClient will generate a ToolCallback from each @Tool-annotated method in the tool class instance and pass them to the model. In case you prefer to generate the ToolCallback(s) yourself, you can use the ToolCallbacks utility class.spring-doc.cn
ToolCallback[] dateTimeTools = ToolCallbacks.from(new DateTimeTools());
Adding Default Tools to ChatClient
When using the declarative specification approach, you can add default tools to a ChatClient.Builder by passing the tool class instance to the defaultTools() method. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
Default tools are shared across all the chat requests performed by all the ChatClient instances built from the same ChatClient.Builder. They are useful for tools that are commonly used across different chat requests, but they can also be dangerous if not used carefully, risking to make them available when they shouldn’t.
ChatClient chatClient = ChatClient.builder(chatModel)
    .defaultTools(new DateTimeTools())
Adding Tools to ChatModel
When using the declarative specification approach, you can pass the tool class instance to the toolCallbacks() method of the ToolCallingChatOptions you use to call a ChatModel. Such tools will only be available for the specific chat request they are added to.spring-doc.cn
ChatOptions chatOptions = ToolCallingChatOptions.builder()
    .toolCallbacks(dateTimeTools)
Prompt prompt = new Prompt("What day is tomorrow?", chatOptions);
chatModel.call(prompt);
Adding Default Tools to ChatModel
When using the declarative specification approach, you can add default tools to ChatModel at construction time by passing the tool class instance to the toolCallbacks() method of the ToolCallingChatOptions instance used to create the ChatModel. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
Default tools are shared across all the chat requests performed by that ChatModel instance. They are useful for tools that are commonly used across different chat requests, but they can also be dangerous if not used carefully, risking to make them available when they shouldn’t.
ChatModel chatModel = OllamaChatModel.builder()
    .ollamaApi(OllamaApi.builder().build())
    .defaultOptions(ToolCallingChatOptions.builder()
            .build())
Programmatic Specification: MethodToolCallback
You can turn a method into a tool by building a MethodToolCallback programmatically.spring-doc.cn
The MethodToolCallback.Builder allows you to build a MethodToolCallback instance and provide key information about the tool:spring-doc.cn
  • toolDefinition: The ToolDefinition instance that defines the tool name, description, and input schema. You can build it using the ToolDefinition.Builder class. Required.spring-doc.cn
  • toolMetadata: The ToolMetadata instance that defines additional settings such as whether the result should be returned directly to the client, and the result converter to use. You can build it using the ToolMetadata.Builder class.spring-doc.cn
  • toolMethod: The Method instance that represents the tool method. Required.spring-doc.cn
  • toolObject: The object instance that contains the tool method. If the method is static, you can omit this parameter.spring-doc.cn
  • toolCallResultConverter: The ToolCallResultConverter instance to use for converting the result of a tool call to a String object to send back to the AI model. If not provided, the default converter will be used (DefaultToolCallResultConverter).spring-doc.cn
The ToolDefinition.Builder allows you to build a ToolDefinition instance and define the tool name, description, and input schema:spring-doc.cn
  • inputSchema: The JSON schema for the input parameters of the tool. If not provided, the schema will be generated automatically based on the method parameters. You can use the @ToolParam annotation to provide additional information about the input parameters, such as a description or whether the parameter is required or optional. By default, all input parameters are considered required. See JSON Schema for more details.spring-doc.cn
The ToolMetadata.Builder allows you to build a ToolMetadata instance and define additional settings for the tool:spring-doc.cn
Method method = ReflectionUtils.findMethod(DateTimeTools.class, "getCurrentDateTime");
ToolCallback toolCallback = MethodToolCallback.builder()
    .toolDefinition(ToolDefinition.builder(method)
            .description("Get the current date and time in the user's timezone")
            .build())
    .toolMethod(method)
    .toolObject(new DateTimeTools())
Spring AI provides built-in support for AOT compilation of the tool methods as long as the class containing the methods is a Spring bean (e.g. @Component). Otherwise, you’ll need to provide the necessary configuration to the GraalVM compiler. For example, by annotating the class with @RegisterReflection(memberCategories = MemberCategory.INVOKE_DECLARED_METHODS).
If the method is static, you can omit the toolObject() method, as it’s not needed.spring-doc.cn
    static String getCurrentDateTime() {
            .build())
    .toolMethod(method)
Spring AI will generate the JSON schema for the input parameters of the method automatically. The schema is used by the model to understand how to call the tool and prepare the tool request. The @ToolParam annotation can be used to provide additional information about the input parameters, such as a description or whether the parameter is required or optional. By default, all input parameters are considered required.spring-doc.cn
Adding Tools to ChatClient and ChatModel
When using the programmatic specification approach, you can pass the MethodToolCallback instance to the tools() method of ChatClient. The tool will only be available for the specific chat request it’s added to.spring-doc.cn
ToolCallback toolCallback = ...
    .tools(toolCallback)
    .call()
    .content();
When using the programmatic specification approach, you can add default tools to a ChatClient.Builder by passing the MethodToolCallback instance to the defaultTools() method. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
    .defaultTools(toolCallback)
When using the programmatic specification approach, you can pass the MethodToolCallback instance to the toolCallbacks() method of the ToolCallingChatOptions you use to call a ChatModel. The tool will only be available for the specific chat request it’s added to.spring-doc.cn
    .toolCallbacks(toolCallback)
    .build():
When using the programmatic specification approach, you can add default tools to a ChatModel at construction time by passing the MethodToolCallback instance to the toolCallbacks() method of the ToolCallingChatOptions instance used to create the ChatModel. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
            .build())
The following types are not currently supported as parameters or return types for methods used as tools:spring-doc.cn
Functional types are supported using the function-based tool specification approach. See Functions as Tools for more details.spring-doc.cn
Functions as Tools
Spring AI provides built-in support for specifying tools from functions, either programmatically using the low-level FunctionToolCallback implementation or dynamically as @Bean(s) resolved at runtime.spring-doc.cn
Programmatic Specification: FunctionToolCallback
You can turn a functional type (Function, Supplier, Consumer, or BiFunction) into a tool by building a FunctionToolCallback programmatically.spring-doc.cn
public class WeatherService implements Function<WeatherRequest, WeatherResponse> {
    public WeatherResponse apply(WeatherRequest request) {
        return new WeatherResponse(30.0, Unit.C);
public enum Unit { C, F }
public record WeatherRequest(String location, Unit unit) {}
public record WeatherResponse(double temp, Unit unit) {}
The FunctionToolCallback.Builder allows you to build a FunctionToolCallback instance and provide key information about the tool:spring-doc.cn
  • name: The name of the tool. AI models use this name to identify the tool when calling it. Therefore, it’s not allowed to have two tools with the same name in the same context. The name must be unique across all the tools available to the model for a specific chat request. Required.spring-doc.cn
  • toolFunction: The functional object that represents the tool method (Function, Supplier, Consumer, or BiFunction). Required.spring-doc.cn
  • inputType: The type of the function input. Required.spring-doc.cn
  • inputSchema: The JSON schema for the input parameters of the tool. If not provided, the schema will be generated automatically based on the inputType. You can use the @ToolParam annotation to provide additional information about the input parameters, such as a description or whether the parameter is required or optional. By default, all input parameters are considered required. See JSON Schema for more details.spring-doc.cn
ToolCallback toolCallback = FunctionToolCallback
    .builder("currentWeather", new WeatherService())
    .description("Get the weather in location")
    .inputType(WeatherRequest.class)
The function inputs and outputs can be either Void or POJOs. The input and output POJOs must be serializable, as the result will be serialized and sent back to the model. The function as well as the input and output types must be public.spring-doc.cn
Some types are not supported. See Function Tool Limitations for more details.
When using the programmatic specification approach, you can pass the FunctionToolCallback instance to the tools() method of ChatClient. The tool will only be available for the specific chat request it’s added to.spring-doc.cn
    .prompt("What's the weather like in Copenhagen?")
    .call()
    .content();
When using the programmatic specification approach, you can add default tools to a ChatClient.Builder by passing the FunctionToolCallback instance to the defaultTools() method. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
When using the programmatic specification approach, you can pass the FunctionToolCallback instance to the toolCallbacks() method of ToolCallingChatOptions. The tool will only be available for the specific chat request it’s added to.spring-doc.cn
    .build():
Prompt prompt = new Prompt("What's the weather like in Copenhagen?", chatOptions);
When using the programmatic specification approach, you can add default tools to a ChatModel at construction time by passing the FunctionToolCallback instance to the toolCallbacks() method of the ToolCallingChatOptions instance used to create the ChatModel. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
            .build())
Dynamic Specification: @Bean
Instead of specifying tools programmatically, you can define tools as Spring beans and let Spring AI resolve them dynamically at runtime using the ToolCallbackResolver interface (via the SpringBeanToolCallbackResolver implementation). This option gives you the possibility to use any Function, Supplier, Consumer, or BiFunction bean as a tool. The bean name will be used as the tool name, and the @Description annotation from Spring Framework can be used to provide a description for the tool, used by the model to understand when and how to call the tool. If you don’t provide a description, the method name will be used as the tool description. However, it’s strongly recommended to provide a detailed description because that’s paramount for the model to understand the tool’s purpose and how to use it. Failing in providing a good description can lead to the model not using the tool when it should or using it incorrectly.spring-doc.cn
class WeatherTools {
    WeatherService weatherService = new WeatherService();
	@Description("Get the weather in location")
	Function<WeatherRequest, WeatherResponse> currentWeather() {
		return weatherService;
The JSON schema for the input parameters of the tool will be generated automatically. You can use the @ToolParam annotation to provide additional information about the input parameters, such as a description or whether the parameter is required or optional. By default, all input parameters are considered required. See JSON Schema for more details.spring-doc.cn
record WeatherRequest(@ToolParam(description = "The name of a city or a country") String location, Unit unit) {}
This tool specification approach has the drawback of not guaranteeing type safety, as the tool resolution is done at runtime. To mitigate this, you can specify the tool name explicitly using the @Bean annotation and storing the value in a constant, so that you can use it in a chat request instead of hard-coding the tool name.spring-doc.cn
    public static final String CURRENT_WEATHER_TOOL = "currentWeather";
	@Bean(CURRENT_WEATHER_TOOL)
When using the dynamic specification approach, you can pass the tool name (i.e. the function bean name) to the tools() method of ChatClient. The tool will only be available for the specific chat request it’s added to.spring-doc.cn
    .tools("currentWeather")
    .call()
    .content();
When using the dynamic specification approach, you can add default tools to a ChatClient.Builder by passing the tool name to the defaultTools() method. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
    .defaultTools("currentWeather")
When using the dynamic specification approach, you can pass the tool name to the toolNames() method of the ToolCallingChatOptions you use to call the ChatModel. The tool will only be available for the specific chat request it’s added to.spring-doc.cn
    .toolNames("currentWeather")
    .build():
When using the dynamic specification approach, you can add default tools to ChatModel at construction time by passing the tool name to the toolNames() method of the ToolCallingChatOptions instance used to create the ChatModel. If both default and runtime tools are provided, the runtime tools will completely override the default tools.spring-doc.cn
            .build())
The following types are not currently supported as input or output types for functions used as tools:spring-doc.cn
Primitive types and collections are supported using the method-based tool specification approach. See Methods as Tools for more details.spring-doc.cn
Tool Specification
In Spring AI, tools are modeled via the ToolCallback interface. In the previous sections, we’ve seen how to define tools from methods and functions using the built-in support provided by Spring AI (see Methods as Tools and Functions as Tools). This section will dive deeper into the tool specification and how to customize and extend it to support more use cases.spring-doc.cn
Tool Callback
The ToolCallback interface provides a way to define a tool that can be called by the AI model, including both definition and execution logic. It’s the main interface to implement when you want to define a tool from scratch. For example, you can define a ToolCallback from an MCP Client (using the Model Context Protocol) or a ChatClient (to build a modular agentic application).spring-doc.cn
The interface provides the following methods:spring-doc.cn
public interface ToolCallback {
	 * Definition used by the AI model to determine when and how to call the tool.
	ToolDefinition getToolDefinition();
	 * Metadata providing additional information on how to handle the tool.
	ToolMetadata getToolMetadata();
	 * Execute tool with the given input and return the result to send back to the AI model.
	String call(String toolInput);
	 * Execute tool with the given input and context, and return the result to send back to the AI model.
	String call(String toolInput, ToolContext tooContext);
Spring AI provides built-in implementations for tool methods (MethodToolCallback) and tool functions (FunctionToolCallback).spring-doc.cn
Tool Definition
The ToolDefinition interface provides the required information for the AI model to know about the availability of the tool, including the tool name, description, and input schema. Each ToolCallback implementation must provide a ToolDefinition instance to define the tool.spring-doc.cn
public interface ToolDefinition {
	 * The tool name. Unique within the tool set provided to a model.
	String name();
	 * The tool description, used by the AI model to determine what the tool does.
	String description();
	 * The schema of the parameters used to call the tool.
	String inputSchema();
See JSON Schema for more details on the input schema.
The ToolDefinition.Builder lets you build a ToolDefinition instance using the default implementation (DefaultToolDefinition).spring-doc.cn
ToolDefinition toolDefinition = ToolDefinition.builder()
    .name("currentWeather")
    .inputSchema("""
            "type": "object",
            "properties": {
                "location": {
                    "type": "string"
                "unit": {
                    "type": "string",
                    "enum": ["C", "F"]
            "required": ["location", "unit"]
Method Tool Definition
When building tools from a method, the ToolDefinition is automatically generated for you. In case you prefer to generate the ToolDefinition yourself, you can use this convenient builder.spring-doc.cn
ToolDefinition toolDefinition = ToolDefinition.from(method);
The ToolDefinition generated from a method includes the method name as the tool name, the method name as the tool description, and the JSON schema of the method input parameters. If the method is annotated with @Tool, the tool name and description will be taken from the annotation, if set.spring-doc.cn
If you’d rather provide some or all of the attributes explicitly, you can use the ToolDefinition.Builder to build a custom ToolDefinition instance.spring-doc.cn
ToolDefinition toolDefinition = ToolDefinition.builder(method)
    .name("currentDateTime")
    .inputSchema(JsonSchemaGenerator.generateForMethodInput(method))
Function Tool Definition
When building tools from a function, the ToolDefinition is automatically generated for you. When you use the FunctionToolCallback.Builder to build a FunctionToolCallback instance, you can provide the tool name, description, and input schema that will be used to generate the ToolDefinition. See Functions as Tools for more details.spring-doc.cn
JSON Schema
When providing a tool to the AI model, the model needs to know the schema of the input type for calling the tool. The schema is used to understand how to call the tool and prepare the tool request. Spring AI provides built-in support for generating the JSON Schema of the input type for a tool via the JsonSchemaGenerator class. The schema is provided as part of the ToolDefinition.spring-doc.cn
See Tool Definition for more details on the ToolDefinition and how to pass the input schema to it.
The JsonSchemaGenerator class is used under the hood to generate the JSON schema for the input parameters of a method or a function, using any of the strategies described in Methods as Tools and Functions as Tools. The JSON schema generation logic supports a series of annotations that you can use on the input parameters for methods and functions to customize the resulting schema.spring-doc.cn
This section describes two main options you can customize when generating the JSON schema for the input parameters of a tool: description and required status.spring-doc.cn
Description
Besides providing a description for the tool itself, you can also provide a description for the input parameters of a tool. The description can be used to provide key information about the input parameters, such as what format the parameter should be in, what values are allowed, and so on. This is useful to help the model understand the input schema and how to use it. Spring AI provides built-in support for generating the description for an input parameter using one of the following annotations:spring-doc.cn
  • @ToolParam(description = "…​") from Spring AIspring-doc.cn
  • @JsonClassDescription(description = "…​") from Jacksonspring-doc.cn
  • @JsonPropertyDescription(description = "…​") from Jacksonspring-doc.cn
  • @Schema(description = "…​") from Swagger.spring-doc.cn
This approach works for both methods and functions, and you can use it recursively for nested types.spring-doc.cn
Required/Optional
By default, each input parameter is considered required, which forces the AI model to provide a value for it when calling the tool. However, you can make an input parameter optional by using one of the following annotations, in this order of precedence:spring-doc.cn
class CustomerTools {
    @Tool(description = "Update customer information")
    void updateCustomerInfo(Long id, String name, @ToolParam(required = false) String email) {
        System.out.println("Updated info for customer with id: " + id);
Defining the correct required status for the input parameter is crucial to mitigate the risk of hallucinations and ensure the model provides the right input when calling the tool. In the previous example, the email parameter is optional, which means the model can call the tool without providing a value for it. If the parameter was required, the model would have to provide a value for it when calling the tool. And if no value existed, the model would probably make one up, leading to hallucinations.
Result Conversion
The result of a tool call is serialized using a ToolCallResultConverter and then sent back to the AI model. The ToolCallResultConverter interface provides a way to convert the result of a tool call to a String object.spring-doc.cn
The interface provides the following method:spring-doc.cn
@FunctionalInterface
public interface ToolCallResultConverter {
	 * Given an Object returned by a tool, convert it to a String compatible with the
	 * given class type.
	String convert(@Nullable Object result, @Nullable Type returnType);
The result must be a serializable type. By default, the result is serialized to JSON using Jackson (DefaultToolCallResultConverter), but you can customize the serialization process by providing your own ToolCallResultConverter implementation.spring-doc.cn
Spring AI relies on the ToolCallResultConverter in both method and function tools.spring-doc.cn
Method Tool Call Result Conversion
When building tools from a method with the declarative approach, you can provide a custom ToolCallResultConverter to use for the tool by setting the resultConverter() attribute of the @Tool annotation.spring-doc.cn
    @Tool(description = "Retrieve customer information", resultConverter = CustomToolCallResultConverter.class)
    Customer getCustomerInfo(Long id) {
        return customerRepository.findById(id);
If using the programmatic approach, you can provide a custom ToolCallResultConverter to use for the tool by setting the resultConverter() attribute of the MethodToolCallback.Builder.spring-doc.cn
Function Tool Call Result Conversion
When building tools from a function using the programmatic approach, you can provide a custom ToolCallResultConverter to use for the tool by setting the resultConverter() attribute of the FunctionToolCallback.Builder.spring-doc.cn
Tool Context
Spring AI supports passing additional contextual information to tools through the ToolContext API. This feature allows you to provide extra, user-provided data that can be used within the tool execution along with the tool arguments passed by the AI model.spring-doc.cn
Providing additional contextual info to tools
    @Tool(description = "Retrieve customer information")
    Customer getCustomerInfo(Long id, ToolContext toolContext) {
        return customerRepository.findById(id, toolContext.get("tenantId"));
The ToolContext is populated with the data provided by the user when invoking ChatClient.spring-doc.cn
        .prompt("Tell me more about the customer with ID 42")
        .tools(new CustomerTools())
        .toolContext(Map.of("tenantId", "acme"))
        .call()
        .content();
None of the data provided in the ToolContext is sent to the AI model.
Similarly, you can define tool context data when invoking the ChatModel directly.spring-doc.cn
ToolCallback[] customerTools = ToolCallbacks.from(new CustomerTools());
    .toolCallbacks(customerTools)
Prompt prompt = new Prompt("Tell me more about the customer with ID 42", chatOptions);
If the toolContext option is set both in the default options and in the runtime options, the resulting ToolContext will be the merge of the two, where the runtime options take precedence over the default options.spring-doc.cn
Return Direct
By default, the result of a tool call is sent back to the model as a response. Then, the model can use the result to continue the conversation.spring-doc.cn
There are cases where you’d rather return the result directly to the caller instead of sending it back to the model. For example, if you build an agent that relies on a RAG tool, you might want to return the result directly to the caller instead of sending it back to the model for unnecessary post-processing. Or perhaps you have certain tools that should end the reasoning loop of the agent.spring-doc.cn
Each ToolCallback implementation can define whether the result of a tool call should be returned directly to the caller or sent back to the model. By default, the result is sent back to the model. But you can change this behavior per tool.spring-doc.cn
The ToolCallingManager, responsible for managing the tool execution lifecycle, is in charge of handling the returnDirect attribute associated with the tool. If the attribute is set to true, the result of the tool call is returned directly to the caller. Otherwise, the result is sent back to the model.spring-doc.cn
If multiple tool calls are requested at once, the returnDirect attribute must be set to true for all the tools to return the results directly to the caller. Otherwise, the results will be sent back to the model.
Returning tool call results directly to the caller
  1. When we want to make a tool available to the model, we include its definition in the chat request. If we want the result of the tool execution to be returned directly to the caller, we set the returnDirect attribute to true.spring-doc.cn
  5. The application sends the tool call result directly to the caller, instead of sending it back to the model.spring-doc.cn
Method Return Direct
When building tools from a method with the declarative approach, you can mark a tool to return the result directly to the caller by setting the returnDirect attribute of the @Tool annotation to true.spring-doc.cn
    @Tool(description = "Retrieve customer information", returnDirect = true)
If using the programmatic approach, you can set the returnDirect attribute via the ToolMetadata interface and pass it to the MethodToolCallback.Builder.spring-doc.cn
ToolMetadata toolMetadata = ToolMetadata.builder()
    .returnDirect(true)
Function Return Direct
When building tools from a function with the programmatic approach, you can set the returnDirect attribute via the ToolMetadata interface and pass it to the FunctionToolCallback.Builder.spring-doc.cn
    .returnDirect(true)
Tool Execution
The tool execution is the process of calling the tool with the provided input arguments and returning the result. The tool execution is handled by the ToolCallingManager interface, which is responsible for managing the tool execution lifecycle.spring-doc.cn
public interface ToolCallingManager {
	 * Resolve the tool definitions from the model's tool calling options.
	List<ToolDefinition> resolveToolDefinitions(ToolCallingChatOptions chatOptions);
	 * Execute the tool calls requested by the model.
	ToolExecutionResult executeToolCalls(Prompt prompt, ChatResponse chatResponse);
If you’re using any of the Spring AI Spring Boot Starters, DefaultToolCallingManager is the autoconfigured implementation of the ToolCallingManager interface. You can customize the tool execution behavior by providing your own ToolCallingManager bean.spring-doc.cn
ToolCallingManager toolCallingManager() {
    return ToolCallingManager.builder().build();
By default, Spring AI manages the tool execution lifecycle transparently for you from within each ChatModel implementation. But you have the possibility to opt-out of this behavior and control the tool execution yourself. This section describes these two scenarios.spring-doc.cn
Framework-Controlled Tool Execution
When using the default behavior, Spring AI will automatically intercept any tool call request from the model, call the tool and return the result to the model. All of this is done transparently for you by each ChatModel implementation using a ToolCallingManager.spring-doc.cn
Framework-controlled tool execution lifecycle
  1. When we want to make a tool available to the model, we include its definition in the chat request (Prompt) and invoke the ChatModel API which sends the request to the AI model.spring-doc.cn
  2. When the model decides to call a tool, it sends a response (ChatResponse) with the tool name and the input parameters modeled after the defined schema.spring-doc.cn
  3. The ChatModel sends the tool call request to the ToolCallingManager API.spring-doc.cn
  4. The ToolCallingManager is responsible for identifying the tool to call and executing it with the provided input parameters.spring-doc.cn
  5. The result of the tool call is returned to the ToolCallingManager.spring-doc.cn
  6. The ToolCallingManager returns the tool execution result back to the ChatModel.spring-doc.cn
  7. The ChatModel sends the tool execution result back to the AI model (ToolResponseMessage).spring-doc.cn
  8. The AI model generates the final response using the tool call result as additional context and sends it back to the caller (ChatResponse) via the ChatClient.spring-doc.cn
Currently, the internal messages exchanged with the model regarding the tool execution are not exposed to the user. If you need to access these messages, you should use the user-controlled tool execution approach.
The logic determining whether a tool call is eligible for execution is handled by the ToolExecutionEligibilityPredicate interface. By default, the tool execution eligibility is determined by checking if the internalToolExecutionEnabled attribute of ToolCallingChatOptions is set to true (the default value), and if the ChatResponse contains any tool calls.spring-doc.cn
public class DefaultToolExecutionEligibilityPredicate implements ToolExecutionEligibilityPredicate {
	public boolean test(ChatOptions promptOptions, ChatResponse chatResponse) {
		return ToolCallingChatOptions.isInternalToolExecutionEnabled(promptOptions) && chatResponse != null
				&& chatResponse.hasToolCalls();
You can provide your custom implementation of ToolExecutionEligibilityPredicate when creating the ChatModel bean.spring-doc.cn
User-Controlled Tool Execution
There are cases where you’d rather control the tool execution lifecycle yourself. You can do so by setting the internalToolExecutionEnabled attribute of ToolCallingChatOptions to false.spring-doc.cn
When you invoke a ChatModel with this option, the tool execution will be delegated to the caller, giving you full control over the tool execution lifecycle. It’s your responsibility checking for tool calls in the ChatResponse and executing them using the ToolCallingManager.spring-doc.cn
The following example demonstrates a minimal implementation of the user-controlled tool execution approach:spring-doc.cn
ToolCallingManager toolCallingManager = ToolCallingManager.builder().build();
    .toolCallbacks(new CustomerTools())
    .internalToolExecutionEnabled(false)
ChatResponse chatResponse = chatModel.call(prompt);
while (chatResponse.hasToolCalls()) {
    ToolExecutionResult toolExecutionResult = toolCallingManager.executeToolCalls(prompt, chatResponse);
    prompt = new Prompt(toolExecutionResult.conversationHistory(), chatOptions);
System.out.println(chatResponse.getResult().getOutput().getText());
When choosing the user-controlled tool execution approach, we recommend using a ToolCallingManager to manage the tool calling operations. This way, you can benefit from the built-in support provided by Spring AI for tool execution. However, nothing prevents you from implementing your own tool execution logic.
The next examples shows a minimal implementation of the user-controlled tool execution approach combined with the usage of the ChatMemory API:spring-doc.cn
ToolCallingManager toolCallingManager = DefaultToolCallingManager.builder().build();
ChatMemory chatMemory = MessageWindowChatMemory.builder().build();
String conversationId = UUID.randomUUID().toString();
    .toolCallbacks(ToolCallbacks.from(new MathTools()))
        List.of(new SystemMessage("You are a helpful assistant."), new UserMessage("What is 6 * 8?")),
        chatOptions);
chatMemory.add(conversationId, prompt.getInstructions());
Prompt promptWithMemory = new Prompt(chatMemory.get(conversationId), chatOptions);
ChatResponse chatResponse = chatModel.call(promptWithMemory);
chatMemory.add(conversationId, chatResponse.getResult().getOutput());
    ToolExecutionResult toolExecutionResult = toolCallingManager.executeToolCalls(promptWithMemory,
            chatResponse);
    chatMemory.add(conversationId, toolExecutionResult.conversationHistory()
        .get(toolExecutionResult.conversationHistory().size() - 1));
UserMessage newUserMessage = new UserMessage("What did I ask you earlier?");
chatMemory.add(conversationId, newUserMessage);
ChatResponse newResponse = chatModel.call(new Prompt(chatMemory.get(conversationId)));
Exception Handling
When a tool call fails, the exception is propagated as a ToolExecutionException which can be caught to handle the error. A ToolExecutionExceptionProcessor can be used to handle a ToolExecutionException with two outcomes: either producing an error message to be sent back to the AI model or throwing an exception to be handled by the caller.spring-doc.cn
public interface ToolExecutionExceptionProcessor {
	 * Convert an exception thrown by a tool to a String that can be sent back to the AI
	 * model or throw an exception to be handled by the caller.
	String process(ToolExecutionException exception);
If you’re using any of the Spring AI Spring Boot Starters, DefaultToolExecutionExceptionProcessor is the autoconfigured implementation of the ToolExecutionExceptionProcessor interface. By default, the error message is sent back to the model. The DefaultToolExecutionExceptionProcessor constructor lets you set the alwaysThrow attribute to true or false. If true, an exception will be thrown instead of sending an error message back to the model.spring-doc.cn
ToolExecutionExceptionProcessor toolExecutionExceptionProcessor() {
    return new DefaultToolExecutionExceptionProcessor(true);
If you defined your own ToolCallback implementation, make sure to throw a ToolExecutionException when an error occurs as part of the tool execution logic in the call() method.
The ToolExecutionExceptionProcessor is used internally by the default ToolCallingManager (DefaultToolCallingManager) to handle exceptions during tool execution. See Tool Execution for more details about the tool execution lifecycle.spring-doc.cn
Tool Resolution
The main approach for passing tools to a model is by providing the ToolCallback(s) when invoking the ChatClient or the ChatModel, using one of the strategies described in Methods as Tools and Functions as Tools.spring-doc.cn
However, Spring AI also supports resolving tools dynamically at runtime using the ToolCallbackResolver interface.spring-doc.cn
public interface ToolCallbackResolver {
	 * Resolve the {@link ToolCallback} for the given tool name.
	@Nullable
	ToolCallback resolve(String toolName);
When using this approach:spring-doc.cn
  • On the client-side, you provide the tool names to the ChatClient or the ChatModel instead of the ToolCallback(s).spring-doc.cn
  • On the server-side, a ToolCallbackResolver implementation is responsible for resolving the tool names to the corresponding ToolCallback instances.spring-doc.cn
By default, Spring AI relies on a DelegatingToolCallbackResolver that delegates the tool resolution to a list of ToolCallbackResolver instances:spring-doc.cn
  • The SpringBeanToolCallbackResolver resolves tools from Spring beans of type Function, Supplier, Consumer, or BiFunction. See Dynamic Specification: @Bean for more details.spring-doc.cn
  • The StaticToolCallbackResolver resolves tools from a static list of ToolCallback instances. When using the Spring Boot Autoconfiguration, this resolver is automatically configured with all the beans of type ToolCallback defined in the application context.spring-doc.cn
If you rely on the Spring Boot Autoconfiguration, you can customize the resolution logic by providing a custom ToolCallbackResolver bean.spring-doc.cn
ToolCallbackResolver toolCallbackResolver(List<FunctionCallback> toolCallbacks) {
    StaticToolCallbackResolver staticToolCallbackResolver = new StaticToolCallbackResolver(toolCallbacks);
    return new DelegatingToolCallbackResolver(List.of(staticToolCallbackResolver));
The ToolCallbackResolver is used internally by the ToolCallingManager to resolve tools dynamically at runtime, supporting both Framework-Controlled Tool Execution and User-Controlled Tool Execution.spring-doc.cn
Observability
Instrumentation for the tool calling is on its way. For now, you can use the logging feature to track the tool calling operations.spring-doc.cn
Logging
All the main operations of the tool calling features are logged at the DEBUG level. You can enable the logging by setting the log level to DEBUG for the org.springframework.ai package.spring-doc.cn
