This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
VertexAI Gemini Chat
The Vertex AI Gemini API allows developers to build generative AI applications using the Gemini model. The Vertex AI Gemini API supports multimodal prompts as input and output text or code. A multimodal model is a model that is capable of processing information from multiple modalities, including images, videos, and text. For example, you can send the model a photo of a plate of cookies and ask it to give you a recipe for those cookies.spring-doc.cn
Gemini is a family of generative AI models developed by Google DeepMind that is designed for multimodal use cases. The Gemini API gives you access to the Gemini 1.0 Pro Vision and Gemini 1.0 Pro models. For specifications of the Vertex AI Gemini API models, see Model information.spring-doc.cn
Prerequisites
  • Install the gcloud CLI, appropriate for you OS.spring-doc.cn
  • Authenticate by running the following command. Replace PROJECT_ID with your Google Cloud project ID and ACCOUNT with your Google Cloud username.spring-doc.cn
gcloud config set project <PROJECT_ID> &&
gcloud auth application-default login <ACCOUNT>
Auto-configuration
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information.spring-doc.cn
Spring AI provides Spring Boot auto-configuration for the VertexAI Gemini Chat Client. To enable it add the following dependency to your project’s Maven pom.xml or Gradle build.gradle build files:spring-doc.cn
<dependency>
    <artifactId>spring-ai-starter-model-vertex-ai-gemini</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-starter-model-vertex-ai-gemini'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Chat Properties
Enabling and disabling of the chat auto-configurations are now configured via top level properties with the prefix spring.ai.model.chat.spring-doc.cn
To enable, spring.ai.model.chat=vertexai (It is enabled by default)spring-doc.cn
To disable, spring.ai.model.chat=none (or any value which doesn’t match vertexai)spring-doc.cn
This change is done to allow configuration of multiple models.spring-doc.cn
The prefix spring.ai.vertex.ai.gemini is used as the property prefix that lets you connect to VertexAI.spring-doc.cn
Property Description Default
spring.ai.model.chatspring-doc.cn
Enable Chat Model clientspring-doc.cn
vertexaispring-doc.cn
spring.ai.vertex.ai.gemini.projectIdspring-doc.cn
Google Cloud Platform project IDspring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.locationspring-doc.cn
Regionspring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.credentialsUrispring-doc.cn
URI to Vertex AI Gemini credentials. When provided it is used to create an a GoogleCredentials instance to authenticate the VertexAI.spring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.apiEndpointspring-doc.cn
Vertex AI Gemini API endpoint.spring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.scopesspring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.transportspring-doc.cn
API transport. GRPC or REST.spring-doc.cn
GRPCspring-doc.cn
The prefix spring.ai.vertex.ai.gemini.chat is the property prefix that lets you configure the chat model implementation for VertexAI Gemini Chat.spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.modelspring-doc.cn
Supported Vertex AI Gemini Chat model to use include the (1.0 ) gemini-pro, gemini-pro-vision (deprecated) and the new gemini-1.5-pro-001, gemini-1.5-flash-001 models.spring-doc.cn
gemini-1.5-pro-001spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.responseMimeTypespring-doc.cn
Output response mimetype of the generated candidate text.spring-doc.cn
text/plain: (default) Text output or application/json: JSON response.spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.googleSearchRetrievalspring-doc.cn
Use Google search Grounding featurespring-doc.cn
true or false, default false.spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.temperaturespring-doc.cn
Controls the randomness of the output. Values can range over [0.0,1.0], inclusive. A value closer to 1.0 will produce responses that are more varied, while a value closer to 0.0 will typically result in less surprising responses from the generative. This value specifies default to be used by the backend while making the call to the generative.spring-doc.cn
0.8spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.topKspring-doc.cn
The maximum number of tokens to consider when sampling. The generative uses combined Top-k and nucleus sampling. Top-k sampling considers the set of topK most probable tokens.spring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.topPspring-doc.cn
The maximum cumulative probability of tokens to consider when sampling. The generative uses combined Top-k and nucleus sampling. Nucleus sampling considers the smallest set of tokens whose probability sum is at least topP.spring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.candidateCountspring-doc.cn
The number of generated response messages to return. This value must be between [1, 8], inclusive. Defaults to 1.spring-doc.cn
-spring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.maxOutputTokensspring-doc.cn
The maximum number of tokens to generate.spring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.frequencyPenaltyspring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.presencePenaltyspring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.toolNamesspring-doc.cn
List of tools, identified by their names, to enable for function calling in a single prompt requests. Tools with those names must exist in the ToolCallback registry.spring-doc.cn
-spring-doc.cn
(deprecated by toolNames) spring.ai.vertex.ai.gemini.chat.options.functionsspring-doc.cn
List of functions, identified by their names, to enable for function calling in a single prompt requests. Functions with those names must exist in the functionCallbacks registry.spring-doc.cn
-spring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.proxy-tool-callsspring-doc.cn
If true, the Spring AI will not handle the function calls internally, but will proxy them to the client. Then is the client’s responsibility to handle the function calls, dispatch them to the appropriate function, and return the results. If false (the default), the Spring AI will handle the function calls internally. Applicable only for chat models with function calling supportspring-doc.cn
falsespring-doc.cn
spring.ai.vertex.ai.gemini.chat.options.safetySettingsspring-doc.cn
List of safety settings to control safety filters, as defined by Vertex AI Safety Filters. Each safety setting can have a method, threshold, and category.spring-doc.cn
-spring-doc.cn
All properties prefixed with spring.ai.vertex.ai.gemini.chat.options can be overridden at runtime by adding a request specific Runtime options to the Prompt call.
Runtime options
The VertexAiGeminiChatOptions.java provides model configurations, such as the temperature, the topK, etc.spring-doc.cn
On start-up, the default options can be configured with the VertexAiGeminiChatModel(api, options) constructor or the spring.ai.vertex.ai.chat.options.* properties.spring-doc.cn
At runtime you can override the default options by adding new, request specific, options to the Prompt call. For example to override the default temperature for a specific request:spring-doc.cn
ChatResponse response = chatModel.call(
    new Prompt(
        "Generate the names of 5 famous pirates.",
        VertexAiGeminiChatOptions.builder()
            .temperature(0.4)
        .build()
In addition to the model specific VertexAiGeminiChatOptions you can use a portable ChatOptions instance, created with the ChatOptionsBuilder#builder().
Tool Calling
The Vertex AI Gemini model supports tool calling capabilities, allowing models to use tools during conversations. Here’s an example of how to define and use @Tool-based tools:spring-doc.cn
public class WeatherService {
    @Tool(description = "Get the weather in location")
    public String weatherByLocation(@ToolParam(description= "City or state name") String location) {
String response = ChatClient.create(this.chatModel)
        .prompt("What's the weather like in Boston?")
        .tools(new WeatherService())
        .call()
        .content();
You can use the java.util.function beans as tools as well:spring-doc.cn
@Description("Get the weather in location. Return temperature in 36°F or 36°C format.")
public Function<Request, Response> weatherFunction() {
    return new MockWeatherService();
        .tools("weatherFunction")
        .inputType(Request.class)
        .call()
        .content();
Find more in Tools documentation.spring-doc.cn
Multimodal
Multimodality refers to a model’s ability to simultaneously understand and process information from various sources, including text, pdf, images, audio, and other data formats.spring-doc.cn
Image, Audio, Video
Google’s Gemini AI models support this capability by comprehending and integrating text, code, audio, images, and video. For more details, refer to the blog post Introducing Gemini.spring-doc.cn
Spring AI’s Message interface supports multimodal AI models by introducing the Media type. This type contains data and information about media attachments in messages, using Spring’s org.springframework.util.MimeType and a java.lang.Object for the raw media data.spring-doc.cn
Below is a simple code example extracted from VertexAiGeminiChatModelIT.java, demonstrating the combination of user text with an image.spring-doc.cn
byte[] data = new ClassPathResource("/vertex-test.png").getContentAsByteArray();
var userMessage = new UserMessage("Explain what do you see on this picture?",
        List.of(new Media(MimeTypeUtils.IMAGE_PNG, this.data)));
ChatResponse response = chatModel.call(new Prompt(List.of(this.userMessage)));
PDF
Latest Vertex Gemini provides support for PDF input types.. Use the application/pdf media type to attach a PDF file to the message:spring-doc.cn
var pdfData = new ClassPathResource("/spring-ai-reference-overview.pdf");
        "You are a very professional document summarization specialist. Please summarize the given document.",
        List.of(new Media(new MimeType("application", "pdf"), pdfData)));
var response = this.chatModel.call(new Prompt(List.of(userMessage)));
Sample Controller
Create a new Spring Boot project and add the spring-ai-starter-model-vertex-ai-gemini to your pom (or gradle) dependencies.spring-doc.cn
Add a application.properties file, under the src/main/resources directory, to enable and configure the VertexAi chat model:spring-doc.cn
spring.ai.vertex.ai.gemini.project-id=PROJECT_ID
spring.ai.vertex.ai.gemini.location=LOCATION
spring.ai.vertex.ai.gemini.chat.options.model=vertex-pro-vision
spring.ai.vertex.ai.gemini.chat.options.temperature=0.5
replace the project-id with your Google Cloud Project ID and location with a Gemini location.
This will create a VertexAiGeminiChatModel implementation that you can inject into your class. Here is an example of a simple @Controller class that uses the chat model for text generations.spring-doc.cn
@RestController
public class ChatController {
    private final VertexAiGeminiChatModel chatModel;
    @Autowired
    public ChatController(VertexAiGeminiChatModel chatModel) {
        this.chatModel = chatModel;
    @GetMapping("/ai/generate")
    public Map generate(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
        return Map.of("generation", this.chatModel.call(message));
    @GetMapping("/ai/generateStream")
	public Flux<ChatResponse> generateStream(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
        Prompt prompt = new Prompt(new UserMessage(message));
        return this.chatModel.stream(prompt);
Manual Configuration
The VertexAiGeminiChatModel implements the ChatModel and uses the VertexAI to connect to the Vertex AI Gemini service.spring-doc.cn
Add the spring-ai-vertex-ai-gemini dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-vertex-ai-gemini</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-vertex-ai-gemini'
Next, create a VertexAiGeminiChatModel and use it for text generations:spring-doc.cn
VertexAI vertexApi =  new VertexAI(projectId, location);
var chatModel = new VertexAiGeminiChatModel(this.vertexApi,
        .model(ChatModel.GEMINI_PRO_1_5_PRO)
        .temperature(0.4)
    .build());
ChatResponse response = this.chatModel.call(
    new Prompt("Generate the names of 5 famous pirates."));
The VertexAiGeminiChatOptions provides the configuration information for the chat requests. The VertexAiGeminiChatOptions.Builder is fluent options builder.spring-doc.cn
Low-level Java Client
Following class diagram illustrates the Vertex AI Gemini native Java API:spring-doc.cn
vertex ai gemini native api
