This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
MCP Server Boot Starter
The Spring AI MCP (Model Context Protocol) Server Boot Starter provides auto-configuration for setting up an MCP server in Spring Boot applications. It enables seamless integration of MCP server capabilities with Spring Boot’s auto-configuration system.
The MCP Server Boot Starter offers:
Automatic configuration of MCP server components
Support for both synchronous and asynchronous operation modes
Multiple transport layer options
Flexible tool, resource, and prompt specification
Change notification capabilities
Starters
There has been a significant change in the Spring AI auto-configuration, starter modules' artifact names. Please refer to the upgrade notes for more information. |
Choose one of the following starters based on your transport requirements:
Standard MCP Server
Full MCP Server features support with STDIO
server transport.
<dependency>
<artifactId>spring-ai-starter-mcp-server</artifactId>
</dependency>
Suitable for command-line and desktop tools
No additional web dependencies required
The starter activates the McpServerAutoConfiguration
auto-configuration responsible for:
Configuring the basic server components
Handling tool, resource, and prompt specifications
Managing server capabilities and change notifications
Providing both sync and async server implementations
WebMVC Server Transport
Full MCP Server features support with SSE
(Server-Sent Events) server transport based on Spring MVC and an optional STDIO
transport.
<dependency>
<artifactId>spring-ai-starter-mcp-server-webmvc</artifactId>
</dependency>
The starter activates the McpWebMvcServerAutoConfiguration
and McpServerAutoConfiguration
auto-configurations to provide:
HTTP-based transport using Spring MVC (
WebMvcSseServerTransportProvider
Automatically configured SSE endpoints
Optional
STDIO
transport (enabled by settingspring.ai.mcp.server.stdio=true
Included
spring-boot-starter-web
andmcp-spring-webmvc
dependencies
WebFlux Server Transport
(Server-Sent Events) server transport based on Spring WebFlux and an optional STDIO
transport.
<dependency>
<artifactId>spring-ai-starter-mcp-server-webflux</artifactId>
</dependency>
The starter activates the McpWebFluxServerAutoConfiguration
Reactive transport using Spring WebFlux (
WebFluxSseServerTransportProvider
Automatically configured reactive SSE endpoints
Optional
STDIO
Included
spring-boot-starter-webflux
andmcp-spring-webflux
dependencies
Configuration Properties
All properties are prefixed with spring.ai.mcp.server
Property | Description | Default |
Enable/disable the MCP server |
Enable/disable stdio transport |
Server name for identification |
Server version |
Server type (SYNC/ASYNC) |
Enable resource change notifications |
Enable prompt change notifications |
Enable tool change notifications |
(optional) response MIME type per tool name. For example |
Custom SSE Message endpoint path for web transport to be used by the client to send messages |
Custom SSE endpoint path for web transport |
Optional URL prefix. For example |
Sync/Async Server Types
Synchronous Server - The default server type implemented using
McpSyncServer
. It is designed for straightforward request-response patterns in your applications. To enable this server type, setspring.ai.mcp.server.type=SYNC
in your configuration. When activated, it automatically handles the configuration of synchronous tool specifications. -
Asynchronous Server - The asynchronous server implementation uses
McpAsyncServer
and is optimized for non-blocking operations. To enable this server type, configure your application withspring.ai.mcp.server.type=ASYNC
. This server type automatically sets up asynchronous tool specifications with built-in Project Reactor support.
Transport Options
The MCP Server supports three transport mechanisms, each with its dedicated starter:
Standard Input/Output (STDIO) -
Spring MVC (Server-Sent Events) -
Spring WebFlux (Reactive SSE) -
Features and Capabilities
The MCP Server Boot Starter allows servers to expose tools, resources, and prompts to clients. It automatically converts custom capability handlers registered as Spring beans to sync/async specifications based on server type:
Tools
Allows servers to expose tools that can be invoked by language models. The MCP Server Boot Starter provides:
Change notification support
Tools are automatically converted to sync/async specifications based on server type
Automatic tool specification through Spring beans:
public ToolCallbackProvider myTools(...) {
List<ToolCallback> tools = ...
return ToolCallbackProvider.from(tools);
or using the low-level API:
public List<McpServerFeatures.SyncToolSpecification> myTools(...) {
List<McpServerFeatures.SyncToolSpecification> tools = ...
return tools;
Resource Management
Provides a standardized way for servers to expose resources to clients.
Static and dynamic resource specifications
Optional change notifications
Support for resource templates
Automatic conversion between sync/async resource specifications
Automatic resource specification through Spring beans:
public List<McpServerFeatures.SyncResourceSpecification> myResources(...) {
var systemInfoResource = new McpSchema.Resource(...);
var resourceSpecification = new McpServerFeatures.SyncResourceSpecification(systemInfoResource, (exchange, request) -> {
try {
var systemInfo = Map.of(...);
String jsonContent = new ObjectMapper().writeValueAsString(systemInfo);
return new McpSchema.ReadResourceResult(
List.of(new McpSchema.TextResourceContents(request.uri(), "application/json", jsonContent)));
catch (Exception e) {
throw new RuntimeException("Failed to generate system info", e);
return List.of(resourceSpecification);
Prompt Management
Provides a standardized way for servers to expose prompt templates to clients.
Template versioning
Automatic conversion between sync/async prompt specifications
Automatic prompt specification through Spring beans:
public List<McpServerFeatures.SyncPromptSpecification> myPrompts() {
var prompt = new McpSchema.Prompt("greeting", "A friendly greeting prompt",
List.of(new McpSchema.PromptArgument("name", "The name to greet", true)));
var promptSpecification = new McpServerFeatures.SyncPromptSpecification(prompt, (exchange, getPromptRequest) -> {
String nameArgument = (String) getPromptRequest.arguments().get("name");
if (nameArgument == null) { nameArgument = "friend"; }
var userMessage = new PromptMessage(Role.USER, new TextContent("Hello " + nameArgument + "! How can I assist you today?"));
return new GetPromptResult("A personalized greeting message", List.of(userMessage));
return List.of(promptSpecification);
Root Change Consumers
When roots change, clients that support listChanged
send a Root Change notification.
Support for monitoring root changes
Automatic conversion to async consumers for reactive applications
Optional registration through Spring beans
public BiConsumer<McpSyncServerExchange, List<McpSchema.Root>> rootsChangeHandler() {
return (exchange, roots) -> {
logger.info("Registering root resources: {}", roots);
Usage Examples
Standard STDIO Server Configuration
# Using spring-ai-starter-mcp-server
spring:
ai:
mcp:
server:
version: 1.0.0
type: SYNC
WebMVC Server Configuration
# Using spring-ai-starter-mcp-server-webmvc
spring:
ai:
mcp:
server:
version: 1.0.0
type: SYNC
sse-message-endpoint: /mcp/messages
WebFlux Server Configuration
# Using spring-ai-starter-mcp-server-webflux
spring:
ai:
mcp:
server:
version: 1.0.0
type: ASYNC # Recommended for reactive applications
Creating a Spring Boot Application with MCP Server
@Service
public class WeatherService {
@Tool(description = "Get weather information by city name")
public String getWeather(String cityName) {
// Implementation
@SpringBootApplication
public class McpServerApplication {
private static final Logger logger = LoggerFactory.getLogger(McpServerApplication.class);
SpringApplication.run(McpServerApplication.class, args);
public ToolCallbackProvider weatherTools(WeatherService weatherService) {
return MethodToolCallbackProvider.builder().toolObjects(weatherService).build();
The auto-configuration will automatically register the tool callbacks as MCP tools. You can have multiple beans producing ToolCallbacks. The auto-configuration will merge them.
Example Applications
Weather Server (WebFlux) - Spring AI MCP Server Boot Starter with WebFlux transport.
Weather Server (STDIO) - Spring AI MCP Server Boot Starter with STDIO transport.
Weather Server Manual Configuration - Spring AI MCP Server Boot Starter that doesn’t use auto-configuration but the Java SDK to configure the server manually.
