This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
Retrieval Augmented Generation
Retrieval Augmented Generation (RAG) is a technique useful to overcome the limitations of large language models that struggle with long-form content, factual accuracy, and context-awareness.
Spring AI supports RAG by providing a modular architecture that allows you to build custom RAG flows yourself
or use out-of-the-box RAG flows using the Advisor
API.
Learn more about Retrieval Augmented Generation in the concepts section. |
Advisors
Spring AI provides out-of-the-box support for common RAG flows using the Advisor
API.
To use the QuestionAnswerAdvisor
or RetrievalAugmentationAdvisor
, you need to add the spring-ai-advisors-vector-store
dependency to your project:
<dependency>
<artifactId>spring-ai-advisors-vector-store</artifactId>
</dependency>
A vector database stores data that the AI model is unaware of. When a user question is sent to the AI model, a QuestionAnswerAdvisor
queries the vector database for documents related to the user question.
The response from the vector database is appended to the user text to provide context for the AI model to generate a response.
Assuming you have already loaded data into a VectorStore
, you can perform Retrieval Augmented Generation (RAG) by providing an instance of QuestionAnswerAdvisor
to the ChatClient
ChatResponse response = ChatClient.builder(chatModel)
.build().prompt()
.advisors(new QuestionAnswerAdvisor(vectorStore))
.user(userText)
.call()
.chatResponse();
In this example, the QuestionAnswerAdvisor
will perform a similarity search over all documents in the Vector Database. To restrict the types of documents that are searched, the SearchRequest
takes an SQL like filter expression that is portable across all VectorStores
This filter expression can be configured when creating the QuestionAnswerAdvisor
and hence will always apply to all ChatClient
requests, or it can be provided at runtime per request.
Here is how to create an instance of QuestionAnswerAdvisor
where the threshold is 0.8
and to return the top 6
results.
var qaAdvisor = QuestionAnswerAdvisor.builder(vectorStore)
.searchRequest(SearchRequest.builder().similarityThreshold(0.8d).topK(6).build())
Dynamic Filter Expressions
Update the SearchRequest
filter expression at runtime using the FILTER_EXPRESSION
advisor context parameter:
ChatClient chatClient = ChatClient.builder(chatModel)
.defaultAdvisors(QuestionAnswerAdvisor.builder(vectorStore)
.searchRequest(SearchRequest.builder().build())
.build())
// Update filter expression at runtime
String content = this.chatClient.prompt()
.user("Please answer my question XYZ")
.advisors(a -> a.param(QuestionAnswerAdvisor.FILTER_EXPRESSION, "type == 'Spring'"))
.call()
.content();
The FILTER_EXPRESSION
parameter allows you to dynamically filter the search results based on the provided expression.
Custom Template
The QuestionAnswerAdvisor
uses a default template to augment the user question with the retrieved documents. You can customize this behavior by providing your own PromptTemplate
object via the .promptTemplate()
builder method.
The PromptTemplate provided here customizes how the advisor merges retrieved context with the user query. This is distinct from configuring a TemplateRenderer on the ChatClient itself (using .templateRenderer() ), which affects the rendering of the initial user/system prompt content before the advisor runs. See ChatClient Prompt Templates for more details on client-level template rendering.
The custom PromptTemplate
can use any TemplateRenderer
implementation (by default, it uses StPromptTemplate
based on the StringTemplate engine). The important requirement is that the template must contain a placeholder to receive the retrieved context, which the advisor provides under the key question_answer_context
PromptTemplate customPromptTemplate = PromptTemplate.builder()
.renderer(StTemplateRenderer.builder().startDelimiterToken('<').endDelimiterToken('>').build())
.template("""
Context information is below.
<question_answer_context>
Given the context information and no prior knowledge, answer the query.
Follow these rules:
1. If the answer is not in the context, just say that you don't know.
2. Avoid statements like "Based on the context..." or "The provided information...".
String question = "Where does the adventure of Anacletus and Birba take place?";
QuestionAnswerAdvisor qaAdvisor = QuestionAnswerAdvisor.builder(vectorStore)
.promptTemplate(customPromptTemplate)
String response = ChatClient.builder(chatModel).build()
.prompt(question)
.advisors(qaAdvisor)
.call()
.content();
The QuestionAnswerAdvisor.Builder.userTextAdvise() method is deprecated in favor of using .promptTemplate() for more flexible customization.
RetrievalAugmentationAdvisor (Incubating)
Spring AI includes a library of RAG modules that you can use to build your own RAG flows.
The RetrievalAugmentationAdvisor
is an Advisor
providing an out-of-the-box implementation for the most common RAG flows,
based on a modular architecture.
Sequential RAG Flows
Naive RAG
Advisor retrievalAugmentationAdvisor = RetrievalAugmentationAdvisor.builder()
.documentRetriever(VectorStoreDocumentRetriever.builder()
.similarityThreshold(0.50)
.vectorStore(vectorStore)
.build())
String answer = chatClient.prompt()
.advisors(retrievalAugmentationAdvisor)
.user(question)
.call()
.content();
By default, the RetrievalAugmentationAdvisor
does not allow the retrieved context to be empty. When that happens,
it instructs the model not to answer the user query. You can allow empty context as follows.
.build())
.queryAugmenter(ContextualQueryAugmenter.builder()
.allowEmptyContext(true)
.build())
.user(question)
.call()
.content();
The VectorStoreDocumentRetriever
accepts a FilterExpression
to filter the search results based on metadata.
You can provide one when instantiating the VectorStoreDocumentRetriever
or at runtime per request,
advisor context parameter.
.build())
.advisors(a -> a.param(VectorStoreDocumentRetriever.FILTER_EXPRESSION, "type == 'Spring'"))
.user(question)
.call()
.content();
See VectorStoreDocumentRetriever for more information.
Advanced RAG
.queryTransformers(RewriteQueryTransformer.builder()
.chatClientBuilder(chatClientBuilder.build().mutate())
.build())
.build())
.user(question)
.call()
.content();
Modules
Spring AI implements a Modular RAG architecture inspired by the concept of modularity detailed in the paper "Modular RAG: Transforming RAG Systems into LEGO-like Reconfigurable Frameworks".
Pre-Retrieval
Pre-Retrieval modules are responsible for processing the user query to achieve the best possible retrieval results.
Query Transformation
A component for transforming the input query to make it more effective for retrieval tasks, addressing challenges such as poorly formed queries, ambiguous terms, complex vocabulary, or unsupported languages.
When using a QueryTransformer , it’s recommended to configure the ChatClient.Builder with a low temperature (e.g., 0.0) to ensure more deterministic and accurate results, improving retrieval quality. The default temperature for most chat models is typically too high for optimal query transformation, leading to reduced retrieval effectiveness.
CompressionQueryTransformer
A CompressionQueryTransformer
uses a large language model to compress a conversation history and a follow-up query
into a standalone query that captures the essence of the conversation.
This transformer is useful when the conversation history is long and the follow-up query is related to the conversation context.
Query query = Query.builder()
.text("And what is its second largest city?")
.history(new UserMessage("What is the capital of Denmark?"),
new AssistantMessage("Copenhagen is the capital of Denmark."))
QueryTransformer queryTransformer = CompressionQueryTransformer.builder()
.chatClientBuilder(chatClientBuilder)
Query transformedQuery = queryTransformer.transform(query);
The prompt used by this component can be customized via the promptTemplate()
method available in the builder.
A RewriteQueryTransformer
uses a large language model to rewrite a user query to provide better results when
querying a target system, such as a vector store or a web search engine.
This transformer is useful when the user query is verbose, ambiguous, or contains irrelevant information that may affect the quality of the search results.
Query query = new Query("I'm studying machine learning. What is an LLM?");
QueryTransformer queryTransformer = RewriteQueryTransformer.builder()
TranslationQueryTransformer
A TranslationQueryTransformer
uses a large language model to translate a query to a target language that is supported
by the embedding model used to generate the document embeddings. If the query is already in the target language,
it is returned unchanged. If the language of the query is unknown, it is also returned unchanged.
This transformer is useful when the embedding model is trained on a specific language and the user query is in a different language.
Query query = new Query("Hvad er Danmarks hovedstad?");
QueryTransformer queryTransformer = TranslationQueryTransformer.builder()
.targetLanguage("english")
Query Expansion
A component for expanding the input query into a list of queries, addressing challenges such as poorly formed queries by providing alternative query formulations, or by breaking down complex problems into simpler sub-queries.
MultiQueryExpander
A MultiQueryExpander
uses a large language model to expand a query into multiple semantically diverse variations
to capture different perspectives, useful for retrieving additional contextual information and increasing the chances
of finding relevant results.
MultiQueryExpander queryExpander = MultiQueryExpander.builder()
.numberOfQueries(3)
List<Query> queries = queryExpander.expand(new Query("How to run a Spring Boot app?"));
By default, the MultiQueryExpander
includes the original query in the list of expanded queries. You can disable this behavior
via the includeOriginal
method in the builder.
.includeOriginal(false)
Retrieval
Retrieval modules are responsible for querying data systems like vector store and retrieving the most relevant documents.
Document Search
Component responsible for retrieving Documents
from an underlying data source, such as a search engine, a vector store,
a database, or a knowledge graph.
A VectorStoreDocumentRetriever
retrieves documents from a vector store that are semantically similar to the input
query. It supports filtering based on metadata, similarity threshold, and top-k results.
DocumentRetriever retriever = VectorStoreDocumentRetriever.builder()
.similarityThreshold(0.73)
.topK(5)
.filterExpression(new FilterExpressionBuilder()
.eq("genre", "fairytale")
.build())
List<Document> documents = retriever.retrieve(new Query("What is the main character of the story?"));
The filter expression can be static or dynamic. For dynamic filter expressions, you can pass a Supplier
.filterExpression(() -> new FilterExpressionBuilder()
.eq("tenant", TenantContextHolder.getTenantIdentifier())
.build())
List<Document> documents = retriever.retrieve(new Query("What are the KPIs for the next semester?"));
You can also provide a request-specific filter expression via the Query
API, using the FILTER_EXPRESSION
parameter.
If both the request-specific and the retriever-specific filter expressions are provided, the request-specific filter expression takes precedence.
.text("Who is Anacletus?")
.context(Map.of(VectorStoreDocumentRetriever.FILTER_EXPRESSION, "location == 'Whispering Woods'"))
List<Document> retrievedDocuments = documentRetriever.retrieve(query);
Document Join
A component for combining documents retrieved based on multiple queries and from multiple data sources into a single collection of documents. As part of the joining process, it can also handle duplicate documents and reciprocal ranking strategies.
ConcatenationDocumentJoiner
A ConcatenationDocumentJoiner
combines documents retrieved based on multiple queries and from multiple data sources
by concatenating them into a single collection of documents. In case of duplicate documents, the first occurrence is kept.
The score of each document is kept as is.
Map<Query, List<List<Document>>> documentsForQuery = ...
DocumentJoiner documentJoiner = new ConcatenationDocumentJoiner();
List<Document> documents = documentJoiner.join(documentsForQuery);
Post-Retrieval
Post-Retrieval modules are responsible for processing the retrieved documents to achieve the best possible generation results.
Document Post-Processing
A component for post-processing retrieved documents based on a query, addressing challenges such as lost-in-the-middle, context length restrictions from the model, and the need to reduce noise and redundancy in the retrieved information.
For example, it could rank documents based on their relevance to the query, remove irrelevant or redundant documents, or compress the content of each document to reduce noise and redundancy.
Generation
Generation modules are responsible for generating the final response based on the user query and retrieved documents.
Query Augmentation
A component for augmenting an input query with additional data, useful to provide a large language model with the necessary context to answer the user query.
The ContextualQueryAugmenter
augments the user query with contextual data from the content of the provided documents.
QueryAugmenter queryAugmenter = ContextualQueryAugmenter.builder().build();
By default, the ContextualQueryAugmenter
You can enable the allowEmptyContext
option to allow the model to generate a response even when the retrieved context is empty.
The prompts used by this component can be customized via the promptTemplate()
and emptyContextPromptTemplate()
methods
