This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
Weaviate
This section walks you through setting up the Weaviate VectorStore to store document embeddings and perform similarity searches.spring-doc.cn
Weaviate is an open-source vector database that allows you to store data objects and vector embeddings from your favorite ML-models and scale seamlessly into billions of data objects. It provides tools to store document embeddings, content, and metadata and to search through those embeddings, including metadata filtering.spring-doc.cn
Prerequisites
Dependencies
Add the Weaviate Vector Store dependency to your project:spring-doc.cn
<dependency>
    <artifactId>spring-ai-weaviate-store</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-weaviate-store'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Configuration
To connect to Weaviate and use the WeaviateVectorStore, you need to provide access details for your instance. A simple configuration can either be provided via Spring Boot’s application.properties,spring-doc.cn
spring.ai.vectorstore.weaviate.host=<host_of_your_weaviate_instance>
spring.ai.vectorstore.weaviate.scheme=<http_or_https>
spring.ai.vectorstore.weaviate.api-key=<your_api_key>
# API key if needed, e.g. OpenAI
spring.ai.openai.api-key=<api-key>
environment variables,spring-doc.cn
export SPRING_AI_VECTORSTORE_WEAVIATE_HOST=<host_of_your_weaviate_instance>
export SPRING_AI_VECTORSTORE_WEAVIATE_SCHEME=<http_or_https>
export SPRING_AI_VECTORSTORE_WEAVIATE_API_KEY=<your_api_key>
export SPRING_AI_OPENAI_API_KEY=<api-key>
or can be a mix of those.spring-doc.cn
If you choose to create a shell script for ease in future work, be sure to run it prior to starting your application by "sourcing" the file, i.e. source <your_script_name>.sh.
Auto-configuration
Spring AI provides Spring Boot auto-configuration for the Weaviate Vector Store. To enable it, add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-weaviate-store-spring-boot-starter</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-weaviate-store-spring-boot-starter'
Please have a look at the list of configuration parameters for the vector store to learn about the default values and configuration options.spring-doc.cn
Refer to the Repositories section to add Maven Central and/or Snapshot Repositories to your build file.
Additionally, you will need a configured EmbeddingModel bean. Refer to the EmbeddingModel section for more information.spring-doc.cn
Here is an example of the needed bean:spring-doc.cn
public EmbeddingModel embeddingModel() {
    // Can be any other Embeddingmodel implementation.
    return new OpenAiEmbeddingModel(new OpenAiApi(System.getenv("SPRING_AI_OPENAI_API_KEY")));
Now you can auto-wire the WeaviateVectorStore as a vector store in your application.spring-doc.cn
Manual Configuration
Instead of using Spring Boot auto-configuration, you can manually configure the WeaviateVectorStore using the builder pattern:spring-doc.cn
public WeaviateClient weaviateClient() {
    return new WeaviateClient(new Config("http", "localhost:8080"));
public VectorStore vectorStore(WeaviateClient weaviateClient, EmbeddingModel embeddingModel) {
    return WeaviateVectorStore.builder(weaviateClient, embeddingModel)
        .objectClass("CustomClass")                    // Optional: defaults to "SpringAiWeaviate"
        .consistencyLevel(ConsistentLevel.QUORUM)      // Optional: defaults to ConsistentLevel.ONE
        .filterMetadataFields(List.of(                 // Optional: fields that can be used in filters
            MetadataField.text("country"),
            MetadataField.number("year")))
Metadata filtering
You can leverage the generic, portable metadata filters with Weaviate store as well.spring-doc.cn
For example, you can use either the text expression language:spring-doc.cn
vectorStore.similaritySearch(
    SearchRequest.builder()
        .query("The World")
        .topK(TOP_K)
        .similarityThreshold(SIMILARITY_THRESHOLD)
        .filterExpression("country in ['UK', 'NL'] && year >= 2020").build());
or programmatically using the Filter.Expression DSL:spring-doc.cn
FilterExpressionBuilder b = new FilterExpressionBuilder();
vectorStore.similaritySearch(SearchRequest.builder()
    .query("The World")
    .topK(TOP_K)
    .filterExpression(b.and(
        b.in("country", "UK", "NL"),
        b.gte("year", 2020)).build()).build());
Those (portable) filter expressions get automatically converted into the proprietary Weaviate where filters.
For example, this portable filter expression:spring-doc.cn
is converted into the proprietary Weaviate GraphQL filter format:spring-doc.cn
operator: And
operands:
        operator: Or
        operands:
                path: ["meta_country"]
                operator: Equal
                valueText: "UK"
                operator: Equal
                valueText: "NL"
        path: ["meta_year"]
        operator: GreaterThanEqual
        valueNumber: 2020
Run Weaviate in Docker
To quickly get started with a local Weaviate instance, you can run it in Docker:spring-doc.cn
docker run -it --rm --name weaviate \
    -e AUTHENTICATION_ANONYMOUS_ACCESS_ENABLED=true \
    -e PERSISTENCE_DATA_PATH=/var/lib/weaviate \
    -e QUERY_DEFAULTS_LIMIT=25 \
    -e DEFAULT_VECTORIZER_MODULE=none \
    -e CLUSTER_HOSTNAME=node1 \
    -p 8080:8080 \
    semitechnologies/weaviate:1.22.4
This starts a Weaviate instance accessible at localhost:8080.spring-doc.cn
WeaviateVectorStore properties
You can use the following properties in your Spring Boot configuration to customize the Weaviate vector store.spring-doc.cn
Property Description Default value
spring.ai.vectorstore.weaviate.hostspring-doc.cn
The host of the Weaviate serverspring-doc.cn
localhost:8080spring-doc.cn
spring.ai.vectorstore.weaviate.schemespring-doc.cn
Connection schemaspring-doc.cn
httpspring-doc.cn
spring.ai.vectorstore.weaviate.api-keyspring-doc.cn
The API key for authenticationspring-doc.cn
spring.ai.vectorstore.weaviate.object-classspring-doc.cn
The class name for storing documentsspring-doc.cn
SpringAiWeaviatespring-doc.cn
spring.ai.vectorstore.weaviate.consistency-levelspring-doc.cn
Desired tradeoff between consistency and speedspring-doc.cn
ConsistentLevel.ONEspring-doc.cn
spring.ai.vectorstore.weaviate.filter-fieldspring-doc.cn
Configures metadata fields that can be used in filters. Format: spring.ai.vectorstore.weaviate.filter-field.<field-name>=<field-type>spring-doc.cn
Accessing the Native Client
The Weaviate Vector Store implementation provides access to the underlying native Weaviate client (WeaviateClient) through the getNativeClient() method:spring-doc.cn
WeaviateVectorStore vectorStore = context.getBean(WeaviateVectorStore.class);
Optional<WeaviateClient> nativeClient = vectorStore.getNativeClient();
if (nativeClient.isPresent()) {
    WeaviateClient client = nativeClient.get();
    // Use the native client for Weaviate-specific operations
The native client gives you access to Weaviate-specific features and operations that might not be exposed through the VectorStore interface.spring-doc.cn
