This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
watsonx.ai Embeddings
With Watsonx.ai you can run various Large Language Models (LLMs) and generate embeddings from them. Spring AI supports the Watsonx.ai text embeddings with WatsonxAiEmbeddingModel.spring-doc.cn
An embedding is a vector (list) of floating point numbers. The distance between two vectors measures their relatedness. Small distances suggest high relatedness and large distances suggest low relatedness.spring-doc.cn
Prerequisites
You first need to have a SaaS instance of watsonx.ai (as well as an IBM Cloud account).spring-doc.cn
Refer to free-trial to try watsonx.ai for freespring-doc.cn
More info can be found here
Add Repositories and BOM
Spring AI artifacts are published in Maven Central and Spring Snapshot repositories. Refer to the Repositories section to add these repositories to your build system.spring-doc.cn
To help with dependency management, Spring AI provides a BOM (bill of materials) to ensure that a consistent version of Spring AI is used throughout the entire project. Refer to the Dependency Management section to add the Spring AI BOM to your build system.spring-doc.cn
Auto-configuration
Spring AI provides Spring Boot auto-configuration for the Watsonx.ai Embedding Model. To enable it add the following dependency to your Maven pom.xml file:spring-doc.cn
<dependency>
   <artifactId>spring-ai-watsonx-ai-spring-boot-starter</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-watsonx-ai-spring-boot-starter'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
The spring.ai.watsonx.embedding.options.* properties are used to configure the default options used for all embedding requests.spring-doc.cn
Embedding Properties
The prefix spring.ai.watsonx.ai is used as the property prefix that lets you connect to watsonx.ai.spring-doc.cn
Property Description Default
spring.ai.watsonx.ai.base-urlspring-doc.cn
The URL to connect tospring-doc.cn
us-south.ml.cloud.ibm.comspring-doc.cn
spring.ai.watsonx.ai.embedding-endpointspring-doc.cn
The text endpointspring-doc.cn
ml/v1/text/embeddings?version=2023-05-29spring-doc.cn
spring.ai.watsonx.ai.project-idspring-doc.cn
The project IDspring-doc.cn
-spring-doc.cn
spring.ai.watsonx.ai.iam-tokenspring-doc.cn
The IBM Cloud account IAM tokenspring-doc.cn
-spring-doc.cn
The prefix spring.ai.watsonx.embedding.options is the property prefix that configures the EmbeddingModel implementation for Watsonx.ai.spring-doc.cn
spring.ai.watsonx.ai.embedding.enabledspring-doc.cn
Enable Watsonx.ai embedding modelspring-doc.cn
truespring-doc.cn
spring.ai.watsonx.ai.embedding.options.modelspring-doc.cn
The embedding model to be usedspring-doc.cn
ibm/slate-30m-english-rtrvrspring-doc.cn
Runtime Options
The WatsonxAiEmbeddingOptions.java provides the Watsonx.ai configurations, such as the model to use.spring-doc.cn
The default options can be configured using the spring.ai.watsonx.embedding.options properties as well.spring-doc.cn
EmbeddingResponse embeddingResponse = embeddingModel.call(
    new EmbeddingRequest(List.of("Hello World", "World is big and salvation is near"),
        WatsonxAiEmbeddingOptions.create()
            .withModel("Different-Embedding-Model-Deployment-Name"))
Sample Controller
This will create an EmbeddingModel implementation that you can inject into your class. Here is an example of a simple @Controller class that uses the EmbeddingModel implementation.spring-doc.cn
@RestController
public class EmbeddingController {
    private final EmbeddingModel embeddingModel;
    @Autowired
    public EmbeddingController(EmbeddingModel embeddingModel) {
        this.embeddingModel = embeddingModel;
    @GetMapping("/ai/embedding")
    public ResponseEntity<Embedding> embedding(@RequestParam String text) {
        EmbeddingResponse response = this.embeddingModel.embedForResponse(List.of(text));
        return ResponseEntity.ok(response.getResult());
