This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!
Milvus
Milvus is an open-source vector database that has garnered significant attention in the fields of data science and machine learning. One of its standout features lies in its robust support for vector indexing and querying. Milvus employs state-of-the-art, cutting-edge algorithms to accelerate the search process, making it exceptionally efficient at retrieving similar vectors, even when handling extensive datasets.
Prerequisites
Dependencies
Then add the Milvus VectorStore boot starter dependency to your project:
<dependency>
	<artifactId>spring-ai-milvus-store-spring-boot-starter</artifactId>
</dependency>
or to your Gradle build.gradle build file.
dependencies {
    implementation 'org.springframework.ai:spring-ai-milvus-store-spring-boot-starter'
Refer to the Dependency Management section to add the Spring AI BOM to your build file. Refer to the Repositories section to add Maven Central and/or Snapshot Repositories to your build file.
The vector store implementation can initialize the requisite schema for you, but you must opt-in by specifying the initializeSchema boolean in the appropriate constructor or by setting …​initialize-schema=true in the application.properties file.
this is a breaking change! In earlier versions of Spring AI, this schema initialization happened by default.
The Vector Store, also requires an EmbeddingModel instance to calculate embeddings for the documents. You can pick one of the available EmbeddingModel Implementations.
To connect to and configure the MilvusVectorStore, you need to provide access details for your instance. A simple configuration can either be provided via Spring Boot’s application.yml
spring:
	ai:
		vectorstore:
			milvus:
				client:
					host: "localhost"
					port: 19530
					username: "root"
					password: "milvus"
				databaseName: "default"
				collectionName: "vector_store"
				embeddingDimension: 1536
				indexType: IVF_FLAT
				metricType: COSINE
Check the list of configuration parameters to learn about the default values and configuration options.
Now you can Auto-wire the Milvus Vector Store in your application and use it
@Autowired VectorStore vectorStore;
List <Document> documents = List.of(
    new Document("Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!! Spring AI rocks!!", Map.of("meta1", "meta1")),
    new Document("The World is Big and Salvation Lurks Around the Corner"),
    new Document("You walk forward facing the past and you turn back toward the future.", Map.of("meta2", "meta2")));
// Add the documents to Milvus Vector Store
vectorStore.add(documents);
// Retrieve documents similar to a query
List<Document> results = this.vectorStore.similaritySearch(SearchRequest.builder().query("Spring").topK(5).build());
Manual Configuration
Instead of using the Spring Boot auto-configuration, you can manually configure the MilvusVectorStore. To add the following dependencies to your project:
<dependency>
	<artifactId>spring-ai-milvus-store</artifactId>
</dependency>
To configure MilvusVectorStore in your application, you can use the following setup:
	public VectorStore vectorStore(MilvusServiceClient milvusClient, EmbeddingModel embeddingModel) {
		return MilvusVectorStore.builder(milvusClient, embeddingModel)
				.collectionName("test_vector_store")
				.databaseName("default")
				.indexType(IndexType.IVF_FLAT)
				.metricType(MetricType.COSINE)
				.batchingStrategy(new TokenCountBatchingStrategy())
				.initializeSchema(true)
	public MilvusServiceClient milvusClient() {
		return new MilvusServiceClient(ConnectParam.newBuilder()
			.withAuthorization("minioadmin", "minioadmin")
			.withUri(milvusContainer.getEndpoint())
			.build());
Metadata filtering
You can leverage the generic, portable metadata filters with the Milvus store.
For example, you can use either the text expression language:
    .query("The World")
    .topK(TOP_K)
    .similarityThreshold(SIMILARITY_THRESHOLD)
    .filterExpression("author in ['john', 'jill'] && article_type == 'blog'").build());
or programmatically using the Filter.Expression DSL:
FilterExpressionBuilder b = new FilterExpressionBuilder();
    .query("The World")
    .topK(TOP_K)
    .filterExpression(b.and(
        b.in("author","john", "jill"),
        b.eq("article_type", "blog")).build()).build());
These filter expressions are converted into the equivalent Milvus filters.
Milvus VectorStore properties
You can use the following properties in your Spring Boot configuration to customize the Milvus vector store.
Property Description Default value
spring.ai.vectorstore.milvus.database-name
The name of the Milvus database to use.
default
spring.ai.vectorstore.milvus.collection-name
Milvus collection name to store the vectors
vector_store
spring.ai.vectorstore.milvus.initialize-schema
whether to initialize Milvus' backend
false
spring.ai.vectorstore.milvus.embedding-dimension
The dimension of the vectors to be stored in the Milvus collection.
1536
spring.ai.vectorstore.milvus.index-type
The type of the index to be created for the Milvus collection.
IVF_FLAT
spring.ai.vectorstore.milvus.metric-type
The metric type to be used for the Milvus collection.
COSINE
spring.ai.vectorstore.milvus.index-parameters
The index parameters to be used for the Milvus collection.
{"nlist":1024}
spring.ai.vectorstore.milvus.id-field-name
The ID field name for the collection
doc_id
spring.ai.vectorstore.milvus.is-auto-id
Boolean flag to indicate if the auto-id is used for the ID field
false
spring.ai.vectorstore.milvus.content-field-name
The content field name for the collection
content
spring.ai.vectorstore.milvus.metadata-field-name
The metadata field name for the collection
metadata
spring.ai.vectorstore.milvus.embedding-field-name
The embedding field name for the collection
embedding
spring.ai.vectorstore.milvus.client.host
The name or address of the host.
localhost
spring.ai.vectorstore.milvus.client.port
The connection port.
19530
spring.ai.vectorstore.milvus.client.uri
The uri of Milvus instance
spring.ai.vectorstore.milvus.client.token
Token serving as the key for identification and authentication purposes.
spring.ai.vectorstore.milvus.client.connect-timeout-ms
Connection timeout value of client channel. The timeout value must be greater than zero .
10000
spring.ai.vectorstore.milvus.client.keep-alive-time-ms
Keep-alive time value of client channel. The keep-alive value must be greater than zero.
55000
spring.ai.vectorstore.milvus.client.keep-alive-timeout-ms
The keep-alive timeout value of client channel. The timeout value must be greater than zero.
20000
spring.ai.vectorstore.milvus.client.rpc-deadline-ms
Deadline for how long you are willing to wait for a reply from the server. With a deadline setting, the client will wait when encounter fast RPC fail caused by network fluctuations. The deadline value must be larger than or equal to zero.
0
spring.ai.vectorstore.milvus.client.client-key-path
The client.key path for tls two-way authentication, only takes effect when "secure" is true
spring.ai.vectorstore.milvus.client.client-pem-path
The client.pem path for tls two-way authentication, only takes effect when "secure" is true
spring.ai.vectorstore.milvus.client.ca-pem-path
The ca.pem path for tls two-way authentication, only takes effect when "secure" is true
spring.ai.vectorstore.milvus.client.server-pem-path
server.pem path for tls one-way authentication, only takes effect when "secure" is true.
spring.ai.vectorstore.milvus.client.server-name
Sets the target name override for SSL host name checking, only takes effect when "secure" is True. Note: this value is passed to grpc.ssl_target_name_override
spring.ai.vectorstore.milvus.client.secure
Secure the authorization for this connection, set to True to enable TLS.
false
spring.ai.vectorstore.milvus.client.idle-timeout-ms
Idle timeout value of client channel. The timeout value must be larger than zero.
24h
spring.ai.vectorstore.milvus.client.username
The username and password for this connection.
root
spring.ai.vectorstore.milvus.client.password
The password for this connection.
milvus
Starting Milvus Store
From within the src/test/resources/ folder run:
docker-compose up
To clean the environment:
docker-compose down; rm -Rf ./volumes
Then connect to the vector store on http://localhost:19530 or for management http://localhost:9001 (user: minioadmin, pass: minioadmin)
Troubleshooting
If Docker complains about resources, then execute:
docker system prune --all --force --volumes
Accessing the Native Client
The Milvus Vector Store implementation provides access to the underlying native Milvus client (MilvusServiceClient) through the getNativeClient() method:
MilvusVectorStore vectorStore = context.getBean(MilvusVectorStore.class);
Optional<MilvusServiceClient> nativeClient = vectorStore.getNativeClient();
if (nativeClient.isPresent()) {
    MilvusServiceClient client = nativeClient.get();
    // Use the native client for Milvus-specific operations
The native client gives you access to Milvus-specific features and operations that might not be exposed through the VectorStore interface.
APP信息
