This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
Anthropic Function Calling (Deprecated)
This page describes the previous version of the Function Calling API, which has been deprecated and marked for remove in the next release. The current version is available at Tool Calling. See the Migration Guide for more information. |
Starting of Jul 1st, 2024, streaming function calling and Tool use is supported. |
You can register custom Java functions with the AnthropicChatModel
and have the Anthropic models intelligently choose to output a JSON object containing arguments to call one or many of the registered functions.
This allows you to connect the LLM capabilities with external tools and APIs.
The claude-3-5-sonnet-20241022
, claude-3-opus
, claude-3-sonnet
and claude-3-haiku
models are trained to detect when a function should be called and to respond with JSON that adheres to the function signature.
The Anthropic API does not call the function directly; instead, the model generates JSON that you can use to call the function in your code and return the result back to the model to complete the conversation.
Spring AI provides flexible and user-friendly ways to register and call custom functions.
In general, the custom functions need to provide a function name
, description
, and the function call signature
(as JSON schema) to let the model know what arguments the function expects.
The description
helps the model to understand when to call the function.
As a developer, you need to implement a function that takes the function call arguments sent from the AI model, and responds with the result back to the model. Your function can in turn invoke other 3rd party services to provide the results.
Spring AI makes this as easy as defining a @Bean
definition that returns a java.util.Function
and supplying the bean name as an option when invoking the ChatModel
Under the hood, Spring wraps your POJO (the function) with the appropriate adapter code that enables interaction with the AI Model, saving you from writing tedious boilerplate code. The basis of the underlying infrastructure is the FunctionCallback.java interface and the companion Builder utility class to simplify the implementation and registration of Java callback functions.
How it works
Suppose we want the AI model to respond with information that it does not have, for example the current temperature at a given location.
We can provide the AI model with metadata about our own functions that it can use to retrieve that information as it processes your prompt.
For example, if during the processing of a prompt, the AI Model determines that it needs additional information about the temperature in a given location, it will start a server side generated request/response interaction. The AI Model invokes a client side function. The AI Model provides method invocation details as JSON and it is the responsibility of the client to execute that function and return the response.
Spring AI greatly simplifies the code you need to write to support function invocation.
It brokers the function invocation conversation for you.
You can simply provide your function definition as a @Bean
and then provide the bean name of the function in your prompt options.
You can also reference multiple function bean names in your prompt.
Quick Start
Let’s create a chatbot that answer questions by calling our own function. To support the response of the chatbot, we will register our own function that takes a location and returns the current weather in that location.
When the response to the prompt to the model needs to answer a question such as "What’s the weather like in Boston?"
the AI model will invoke the client providing the location value as an argument to be passed to the function. This RPC-like data is passed as JSON.
Our function can some SaaS based weather service API and returns the weather response back to the model to complete the conversation.
In this example we will use a simple implementation named MockWeatherService
that hard codes the temperature for various locations.
The following MockWeatherService.java
represents the weather service API:
public class MockWeatherService implements Function<Request, Response> {
public enum Unit { C, F }
public record Request(String location, Unit unit) {}
public record Response(double temp, Unit unit) {}
public Response apply(Request request) {
return new Response(30.0, Unit.C);
Registering Functions as Beans
With the AnthropicChatModel Auto-Configuration you have multiple ways to register custom functions as beans in the Spring context.
We start with describing the most POJO friendly options.
Plain Java Functions
In this approach you define @Beans
in your application context as you would any other Spring managed object.
Internally, Spring AI ChatModel
will create an instance of a FunctionCallback
that adds the logic for it being invoked via the AI model.
The name of the @Bean
is passed as a ChatOption
static class Config {
@Description("Get the weather in location") // function description
public Function<MockWeatherService.Request, MockWeatherService.Response> weatherFunction1() {
return new MockWeatherService();
The @Description
annotation is optional and provides a function description (2) that helps the model understand when to call the function.
It is an important property to set to help the AI model determine what client side function to invoke.
Another option to provide the description of the function is to use the @JsonClassDescription
annotation on the MockWeatherService.Request
to provide the function description:
public Function<Request, Response> currentWeather3() { // (1) bean name as function name.
@JsonClassDescription("Get the weather in location") // (2) function description
It is a best practice to annotate the request object with information such that the generated JSON schema of that function is as descriptive as possible to help the AI model pick the correct function to invoke.
The FunctionCallWithFunctionBeanIT.java demonstrates this approach.
FunctionCallback
Another way to register a function is to create a FunctionCallback
instance like this:
public FunctionCallback weatherFunctionInfo() {
return FunctionCallback.builder()
.description("Get the weather in location") // (2) function description
.function("CurrentWeather", new MockWeatherService()) // (1) function name and instance
.inputType(MockWeatherService.Request.class) // (3) function signature
It wraps the 3rd party MockWeatherService
function and registers it as a CurrentWeather
function with the AnthropicChatModel
It also provides a description (2) and input type (3) used to generate the JSON schema for the function call.
By default, the response converter does a JSON serialization of the Response object. |
The FunctionCallback internally resolves the function call signature based on the MockWeatherService.Request class.
Specifying functions in Chat Options
To let the model know and call your CurrentWeather
function you need to enable it in your prompt requests:
AnthropicChatModel chatModel = ...
UserMessage userMessage = new UserMessage("What's the weather like in Paris?");
ChatResponse response = this.chatModel.call(new Prompt(List.of(this.userMessage),
AnthropicChatOptions.builder().function("CurrentWeather").build())); // (1) Enable the function
logger.info("Response: {}", response);
Above user question will trigger 3 calls to CurrentWeather
function (one for each city) and produce the final response.
Register/Call Functions with Prompt Options
In addition to the auto-configuration you can register callback functions, dynamically, with your Prompt requests:
var promptOptions = AnthropicChatOptions.builder()
.functionCallbacks(List.of(FunctionCallback.builder()
.build())) // function code
ChatResponse response = this.chatModel.call(new Prompt(List.of(this.userMessage), this.promptOptions));
The in-prompt registered functions are enabled by default for the duration of this request. |
This approach allows to dynamically chose different functions to be called based on the user input.
The FunctionCallWithPromptFunctionIT.java integration test provides a complete example of how to register a function with the AnthropicChatModel
and use it in a prompt request.
