This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
MiniMax Chat
Spring AI supports the various AI language models from MiniMax. You can interact with MiniMax language models and create a multilingual conversational assistant based on MiniMax models.spring-doc.cn
Prerequisites
You will need to create an API with MiniMax to access MiniMax language models.spring-doc.cn
Create an account at MiniMax registration page and generate the token on the API Keys page. The Spring AI project defines a configuration property named spring.ai.minimax.api-key that you should set to the value of the API Key obtained from API Keys page. Exporting an environment variable is one way to set that configuration property:spring-doc.cn
export SPRING_AI_MINIMAX_API_KEY=<INSERT KEY HERE>
Add Repositories and BOM
Spring AI artifacts are published in Maven Central and Spring Snapshot repositories. Refer to the Repositories section to add these repositories to your build system.spring-doc.cn
To help with dependency management, Spring AI provides a BOM (bill of materials) to ensure that a consistent version of Spring AI is used throughout the entire project. Refer to the Dependency Management section to add the Spring AI BOM to your build system.spring-doc.cn
Auto-configuration
Spring AI provides Spring Boot auto-configuration for the Azure MiniMax Embedding Model. To enable it add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-minimax-spring-boot-starter</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-minimax-spring-boot-starter'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Embedding Properties
Retry Properties
The prefix spring.ai.retry is used as the property prefix that lets you configure the retry mechanism for the MiniMax Embedding model.spring-doc.cn
Property Description Default
spring.ai.retry.max-attemptsspring-doc.cn
Maximum number of retry attempts.spring-doc.cn
10spring-doc.cn
spring.ai.retry.backoff.initial-intervalspring-doc.cn
Initial sleep duration for the exponential backoff policy.spring-doc.cn
2 sec.spring-doc.cn
spring.ai.retry.backoff.multiplierspring-doc.cn
Backoff interval multiplier.spring-doc.cn
5spring-doc.cn
spring.ai.retry.backoff.max-intervalspring-doc.cn
Maximum backoff duration.spring-doc.cn
3 min.spring-doc.cn
spring.ai.retry.on-client-errorsspring-doc.cn
If false, throw a NonTransientAiException, and do not attempt retry for 4xx client error codesspring-doc.cn
falsespring-doc.cn
spring.ai.retry.exclude-on-http-codesspring-doc.cn
List of HTTP status codes that should not trigger a retry (e.g. to throw NonTransientAiException).spring-doc.cn
emptyspring-doc.cn
spring.ai.retry.on-http-codesspring-doc.cn
List of HTTP status codes that should trigger a retry (e.g. to throw TransientAiException).spring-doc.cn
emptyspring-doc.cn
Connection Properties
The prefix spring.ai.minimax is used as the property prefix that lets you connect to MiniMax.spring-doc.cn
spring.ai.minimax.base-urlspring-doc.cn
The URL to connect tospring-doc.cn
api.minimax.chatspring-doc.cn
spring.ai.minimax.api-keyspring-doc.cn
The API Keyspring-doc.cn
-spring-doc.cn
Configuration Properties
The prefix spring.ai.minimax.embedding is property prefix that configures the EmbeddingModel implementation for MiniMax.spring-doc.cn
spring.ai.minimax.embedding.enabledspring-doc.cn
Enable MiniMax embedding model.spring-doc.cn
truespring-doc.cn
spring.ai.minimax.embedding.base-urlspring-doc.cn
Optional overrides the spring.ai.minimax.base-url to provide embedding specific urlspring-doc.cn
-spring-doc.cn
spring.ai.minimax.embedding.api-keyspring-doc.cn
Optional overrides the spring.ai.minimax.api-key to provide embedding specific api-keyspring-doc.cn
-spring-doc.cn
spring.ai.minimax.embedding.options.modelspring-doc.cn
The model to usespring-doc.cn
embo-01spring-doc.cn
You can override the common spring.ai.minimax.base-url and spring.ai.minimax.api-key for the ChatModel and EmbeddingModel implementations. The spring.ai.minimax.embedding.base-url and spring.ai.minimax.embedding.api-key properties if set take precedence over the common properties. Similarly, the spring.ai.minimax.chat.base-url and spring.ai.minimax.chat.api-key properties if set take precedence over the common properties. This is useful if you want to use different MiniMax accounts for different models and different model endpoints.
All properties prefixed with spring.ai.minimax.embedding.options can be overridden at runtime by adding a request specific Runtime Options to the EmbeddingRequest call.
Runtime Options
The MiniMaxEmbeddingOptions.java provides the MiniMax configurations, such as the model to use and etc.spring-doc.cn
The default options can be configured using the spring.ai.minimax.embedding.options properties as well.spring-doc.cn
At start-time use the MiniMaxEmbeddingModel constructor to set the default options used for all embedding requests. At run-time you can override the default options, using a MiniMaxEmbeddingOptions instance as part of your EmbeddingRequest.spring-doc.cn
For example to override the default model name for a specific request:spring-doc.cn
EmbeddingResponse embeddingResponse = embeddingModel.call(
    new EmbeddingRequest(List.of("Hello World", "World is big and salvation is near"),
        MiniMaxEmbeddingOptions.builder()
            .model("Different-Embedding-Model-Deployment-Name")
        .build()));
Sample Controller
This will create a EmbeddingModel implementation that you can inject into your class. Here is an example of a simple @Controller class that uses the EmbeddingC implementation.spring-doc.cn
spring.ai.minimax.api-key=YOUR_API_KEY
spring.ai.minimax.embedding.options.model=embo-01
@RestController
public class EmbeddingController {
    private final EmbeddingModel embeddingModel;
    @Autowired
    public EmbeddingController(EmbeddingModel embeddingModel) {
        this.embeddingModel = embeddingModel;
    @GetMapping("/ai/embedding")
    public Map embed(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
        EmbeddingResponse embeddingResponse = this.embeddingModel.embedForResponse(List.of(message));
        return Map.of("embedding", embeddingResponse);
Manual Configuration
If you are not using Spring Boot, you can manually configure the MiniMax Embedding Model. For this add the spring-ai-minimax dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-minimax</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-minimax'
The spring-ai-minimax dependency provides access also to the MiniMaxChatModel. For more information about the `MiniMaxChatModel refer to the MiniMax Chat Client section.
Next, create an MiniMaxEmbeddingModel instance and use it to compute the similarity between two input texts:spring-doc.cn
var miniMaxApi = new MiniMaxApi(System.getenv("MINIMAX_API_KEY"));
var embeddingModel = new MiniMaxEmbeddingModel(minimaxApi, MetadataMode.EMBED,
MiniMaxEmbeddingOptions.builder().model("embo-01").build());
	.embedForResponse(List.of("Hello World", "World is big and salvation is near"));
The MiniMaxEmbeddingOptions provides the configuration information for the embedding requests. The options class offers a builder() for easy options creation.spring-doc.cn
