This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
QianFan Chat
Spring AI supports the various AI language models from QianFan. You can interact with QianFan language models and create a multilingual conversational assistant based on QianFan models.spring-doc.cn
Prerequisites
You will need to create an API with QianFan to access QianFan language models.spring-doc.cn
Create an account at QianFan registration page and generate the token on the API Keys page. The Spring AI project defines a configuration property named spring.ai.qianfan.api-key and spring.ai.qianfan.secret-key. you should set to the value of the API Key and Secret Key obtained from API Keys page. Exporting an environment variable is one way to set that configuration property:spring-doc.cn
export SPRING_AI_QIANFAN_API_KEY=<INSERT API KEY HERE>
export SPRING_AI_QIANFAN_SECRET_KEY=<INSERT SECRET KEY HERE>
Add Repositories and BOM
Spring AI artifacts are published in Maven Central and Spring Snapshot repositories. Refer to the Repositories section to add these repositories to your build system.spring-doc.cn
To help with dependency management, Spring AI provides a BOM (bill of materials) to ensure that a consistent version of Spring AI is used throughout the entire project. Refer to the Dependency Management section to add the Spring AI BOM to your build system.spring-doc.cn
Auto-configuration
Spring AI provides Spring Boot auto-configuration for the QianFan Chat Client. To enable it add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-qianfan-spring-boot-starter</artifactId>
</dependency>
or to your Gradle build.gradle build file.spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-qianfan-spring-boot-starter'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Chat Properties
Retry Properties
The prefix spring.ai.retry is used as the property prefix that lets you configure the retry mechanism for the QianFan Chat client.spring-doc.cn
Property Description Default
spring.ai.retry.max-attemptsspring-doc.cn
Maximum number of retry attempts.spring-doc.cn
10spring-doc.cn
spring.ai.retry.backoff.initial-intervalspring-doc.cn
Initial sleep duration for the exponential backoff policy.spring-doc.cn
2 sec.spring-doc.cn
spring.ai.retry.backoff.multiplierspring-doc.cn
Backoff interval multiplier.spring-doc.cn
5spring-doc.cn
spring.ai.retry.backoff.max-intervalspring-doc.cn
Maximum backoff duration.spring-doc.cn
3 min.spring-doc.cn
spring.ai.retry.on-client-errorsspring-doc.cn
If false, throw a NonTransientAiException, and do not attempt retry for 4xx client error codesspring-doc.cn
falsespring-doc.cn
spring.ai.retry.exclude-on-http-codesspring-doc.cn
List of HTTP status codes that should not trigger a retry (e.g. to throw NonTransientAiException).spring-doc.cn
emptyspring-doc.cn
spring.ai.retry.on-http-codesspring-doc.cn
List of HTTP status codes that should trigger a retry (e.g. to throw TransientAiException).spring-doc.cn
emptyspring-doc.cn
Connection Properties
The prefix spring.ai.qianfan is used as the property prefix that lets you connect to QianFan.spring-doc.cn
spring.ai.qianfan.base-urlspring-doc.cn
The URL to connect tospring-doc.cn
api.qianfan.chatspring-doc.cn
spring.ai.qianfan.api-keyspring-doc.cn
The API Keyspring-doc.cn
-spring-doc.cn
spring.ai.qianfan.secret-keyspring-doc.cn
The Secret Keyspring-doc.cn
-spring-doc.cn
Configuration Properties
The prefix spring.ai.qianfan.chat is the property prefix that lets you configure the chat client implementation for QianFan.spring-doc.cn
spring.ai.qianfan.chat.enabledspring-doc.cn
Enable QianFan chat client.spring-doc.cn
truespring-doc.cn
spring.ai.qianfan.chat.base-urlspring-doc.cn
Optional overrides the spring.ai.qianfan.base-url to provide chat specific urlspring-doc.cn
spring.ai.qianfan.chat.api-keyspring-doc.cn
Optional overrides the spring.ai.qianfan.api-key to provide chat specific api-keyspring-doc.cn
-spring-doc.cn
spring.ai.qianfan.chat.secret-keyspring-doc.cn
Optional overrides the spring.ai.qianfan.secret-key to provide chat specific secret-keyspring-doc.cn
-spring-doc.cn
spring.ai.qianfan.chat.options.modelspring-doc.cn
This is the QianFan Chat model to usespring-doc.cn
abab5.5-chat (the abab5.5s-chat, abab5.5-chat, and abab6-chat point to the latest model versions)spring-doc.cn
spring.ai.qianfan.chat.options.maxTokensspring-doc.cn
The maximum number of tokens to generate in the chat completion. The total length of input tokens and generated tokens is limited by the model’s context length.spring-doc.cn
-spring-doc.cn
spring.ai.qianfan.chat.options.temperaturespring-doc.cn
The sampling temperature to use that controls the apparent creativity of generated completions. Higher values will make output more random while lower values will make results more focused and deterministic. It is not recommended to modify temperature and top_p for the same completions request as the interaction of these two settings is difficult to predict.spring-doc.cn
0.7spring-doc.cn
spring.ai.qianfan.chat.options.topPspring-doc.cn
An alternative to sampling with temperature, called nucleus sampling, where the model considers the results of the tokens with top_p probability mass. So 0.1 means only the tokens comprising the top 10% probability mass are considered. We generally recommend altering this or temperature but not both.spring-doc.cn
1.0spring-doc.cn
spring.ai.qianfan.chat.options.presencePenaltyspring-doc.cn
Number between -2.0 and 2.0. Positive values penalize new tokens based on whether they appear in the text so far, increasing the model’s likelihood to talk about new topics.spring-doc.cn
0.0fspring-doc.cn
spring.ai.qianfan.chat.options.frequencyPenaltyspring-doc.cn
Number between -2.0 and 2.0. Positive values penalize new tokens based on their existing frequency in the text so far, decreasing the model’s likelihood to repeat the same line verbatim.spring-doc.cn
0.0fspring-doc.cn
spring.ai.qianfan.chat.options.stopspring-doc.cn
The model will stop generating characters specified by stop, and currently only supports a single stop word in the format of ["stop_word1"]spring-doc.cn
-spring-doc.cn
You can override the common spring.ai.qianfan.base-url, spring.ai.qianfan.api-key and spring.ai.qianfan.secret-key for the ChatClient implementations. The spring.ai.qianfan.chat.base-url, spring.ai.qianfan.chat.api-key and spring.ai.qianfan.chat.secret-key properties if set take precedence over the common properties. This is useful if you want to use different QianFan accounts for different models and different model endpoints.
All properties prefixed with spring.ai.qianfan.chat.options can be overridden at runtime by adding a request specific Runtime Options to the Prompt call.
Runtime Options
The QianFanChatOptions.java provides model configurations, such as the model to use, the temperature, the frequency penalty, etc.spring-doc.cn
On start-up, the default options can be configured with the QianFanChatModel(api, options) constructor or the spring.ai.qianfan.chat.options.* properties.spring-doc.cn
At run-time you can override the default options by adding new, request specific, options to the Prompt call. For example to override the default model and temperature for a specific request:spring-doc.cn
ChatResponse response = chatClient.call(
    new Prompt(
        "Generate the names of 5 famous pirates.",
        QianFanChatOptions.builder()
            .model(QianFanApi.ChatModel.ERNIE_Speed_8K.getValue())
            .temperature(0.5)
        .build()
In addition to the model specific QianFanChatOptions you can use a portable ChatOptions instance, created with the ChatOptionsBuilder#builder().
Sample Controller
Create a new Spring Boot project and add the spring-ai-qianfan-spring-boot-starter to your pom (or gradle) dependencies.spring-doc.cn
Add a application.properties file, under the src/main/resources directory, to enable and configure the QianFan Chat client:spring-doc.cn
spring.ai.qianfan.api-key=YOUR_API_KEY
spring.ai.qianfan.secret-key=YOUR_SECRET_KEY
spring.ai.qianfan.chat.options.model=ernie_speed
spring.ai.qianfan.chat.options.temperature=0.7
replace the api-key and secret-key with your QianFan credentials.
This will create a QianFanChatModel implementation that you can inject into your class. Here is an example of a simple @Controller class that uses the chat client for text generations.spring-doc.cn
@RestController
public class ChatController {
    private final QianFanChatModel chatClient;
    @Autowired
    public ChatController(QianFanChatModel chatClient) {
        this.chatClient = chatClient;
    @GetMapping("/ai/generate")
    public Map generate(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
        return Map.of("generation", this.chatClient.call(message));
    @GetMapping("/ai/generateStream")
	public Flux<ChatResponse> generateStream(@RequestParam(value = "message", defaultValue = "Tell me a joke") String message) {
        var prompt = new Prompt(new UserMessage(message));
        return this.chatClient.stream(prompt);
Manual Configuration
The QianFanChatModel implements the ChatClient and StreamingChatClient and uses the Low-level QianFanApi Client to connect to the QianFan service.spring-doc.cn
Add the spring-ai-qianfan dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-qianfan</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-qianfan'
Next, create a QianFanChatModel and use it for text generations:spring-doc.cn
var qianFanApi = new QianFanApi(System.getenv("QIANFAN_API_KEY"), System.getenv("QIANFAN_SECRET_KEY"));
var chatClient = new QianFanChatModel(this.qianFanApi, QianFanChatOptions.builder()
                .temperature(0.4)
                .maxTokens(200)
                .build());
ChatResponse response = this.chatClient.call(
    new Prompt("Generate the names of 5 famous pirates."));
// Or with streaming responses
Flux<ChatResponse> streamResponse = this.chatClient.stream(
The QianFanChatOptions provides the configuration information for the chat requests. The QianFanChatOptions.Builder is fluent options builder.spring-doc.cn
The QianFanApi provides is lightweight Java client for QianFan API.spring-doc.cn
Here is a simple snippet how to use the api programmatically:spring-doc.cn
String systemMessage = "Your name is QianWen";
QianFanApi qianFanApi =
ChatCompletionMessage chatCompletionMessage =
    new ChatCompletionMessage("Hello world", Role.USER);
// Sync request
ResponseEntity<ChatCompletion> response = this.qianFanApi.chatCompletionEntity(
    new ChatCompletionRequest(List.of(this.chatCompletionMessage), this.systemMessage, QianFanApi.ChatModel.ERNIE_Speed_8K.getValue(), 0.7, false));
// Streaming request
Flux<ChatCompletionChunk> streamResponse = this.qianFanApi.chatCompletionStream(
        new ChatCompletionRequest(List.of(this.chatCompletionMessage), this.systemMessage, QianFanApi.ChatModel.ERNIE_Speed_8K.getValue(), 0.7, true));
Follow the QianFanApi.java's JavaDoc for further information.spring-doc.cn
QianFanApi Samples
