This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
MCP Utilities
The MCP utilities provide foundational support for integrating Model Context Protocol with Spring AI applications. These utilities enable seamless communication between Spring AI’s tool system and MCP servers, supporting both synchronous and asynchronous operations. They are typically used for programmatic MCP Client and Server configuration and interaction. For a more streamlined configuration, consider using the boot starters.spring-doc.cn
ToolCallback Utility
Tool Callback Adapter
Adapts MCP tools to Spring AI’s tool interface with both synchronous and asynchronous execution support.spring-doc.cn
McpSyncClient mcpClient = // obtain MCP client
Tool mcpTool = // obtain MCP tool definition
ToolCallback callback = new SyncMcpToolCallback(mcpClient, mcpTool);
// Use the tool through Spring AI's interfaces
ToolDefinition definition = callback.getToolDefinition();
String result = callback.call("{\"param\": \"value\"}");
McpAsyncClient mcpClient = // obtain MCP client
ToolCallback callback = new AsyncMcpToolCallback(mcpClient, mcpTool);
Tool Callback Providers
Discovers and provides MCP tools from MCP clients.spring-doc.cn
ToolCallbackProvider provider = new SyncMcpToolCallbackProvider(mcpClient);
// Get all available tools
ToolCallback[] tools = provider.getToolCallbacks();
For multiple clients:spring-doc.cn
List<McpSyncClient> clients = // obtain list of clients
List<ToolCallback> callbacks = SyncMcpToolCallbackProvider.syncToolCallbacks(clients);
ToolCallbackProvider provider = new AsyncMcpToolCallbackProvider(mcpClient);
List<McpAsyncClient> clients = // obtain list of clients
Flux<ToolCallback> callbacks = AsyncMcpToolCallbackProvider.asyncToolCallbacks(clients);
McpToolUtils
ToolCallbacks to ToolRegistrations
Converting Spring AI tool callbacks to MCP tool registrations:spring-doc.cn
List<ToolCallback> toolCallbacks = // obtain tool callbacks
List<SyncToolRegistration> syncToolRegs = McpToolUtils.toSyncToolRegistration(toolCallbacks);
then you can use the McpServer.SyncSpec to register the tool registrations:spring-doc.cn
McpServer.SyncSpec syncSpec = ...
syncSpec.tools(syncToolRegs);
List<AsyncToolRegistration> asyncToolRegs = McpToolUtils.toAsyncToolRegistration(toolCallbacks);
then you can use the McpServer.AsyncSpec to register the tool registrations:spring-doc.cn
McpServer.AsyncSpec asyncSpec = ...
asyncSpec.tools(asyncToolRegs);
MCP Clients to ToolCallbacks
Getting tool callbacks from MCP clientsspring-doc.cn
List<McpSyncClient> syncClients = // obtain sync clients
List<ToolCallback> syncCallbacks = McpToolUtils.getToolCallbacksFromSyncClients(syncClients);
List<McpAsyncClient> asyncClients = // obtain async clients
List<ToolCallback> asyncCallbacks = McpToolUtils.getToolCallbacksFromAsyncClients(asyncClients);
Native Image Support
The McpHints class provides GraalVM native image hints for MCP schema classes. This class automatically registers all necessary reflection hints for MCP schema classes when building native images.spring-doc.cn
