This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
Migrating from FunctionCallback to ToolCallback API
This guide helps you migrate from the deprecated FunctionCallback
API to the new ToolCallback
API in Spring AI. For more information about the new APIs, check out the Tools Calling documentation.
Overview of Changes
These changes are part of a broader effort to improve and extend the tool calling capabilities in Spring AI. Among the other things, the new API moves from "functions" to "tools" terminology to better align with industry conventions. This involves several API changes while maintaining backward compatibility through deprecated methods.
Key Changes
FunctionCallback
→ToolCallback
FunctionCallback.builder().function()
→FunctionToolCallback.builder()
FunctionCallback.builder().method()
→MethodToolCallback.builder()
FunctionCallingOptions
→ToolCallingChatOptions
ChatClient.builder().defaultFunctions()
→ChatClient.builder().defaultTools()
ChatClient.functions()
→ChatClient.tools()
FunctionCallingOptions.builder().functions()
→ToolCallingChatOptions.builder().toolNames()
FunctionCallingOptions.builder().functionCallbacks()
→ToolCallingChatOptions.builder().toolCallbacks()
Migration Examples
1. Basic Function Callback
Before:
.function("getCurrentWeather", new MockWeatherService())
.description("Get the weather in location")
.inputType(MockWeatherService.Request.class)
.build()
After:
FunctionToolCallback.builder("getCurrentWeather", new MockWeatherService())
.build()
2. ChatClient Usage
Before:
String response = ChatClient.create(chatModel)
.prompt()
.user("What's the weather like in San Francisco?")
.functions(FunctionCallback.builder()
.build())
.call()
.content();
After:
.prompt()
.tools(FunctionToolCallback.builder("getCurrentWeather", new MockWeatherService())
.build())
.call()
.content();
3. Method-Based Function Callbacks
Before:
.method("getWeatherInLocation", String.class, Unit.class)
.targetClass(TestFunctionClass.class)
.build()
After:
var toolMethod = ReflectionUtils.findMethod(TestFunctionClass.class, "getWeatherInLocation");
.toolDefinition(ToolDefinition.builder(toolMethod)
.build())
.toolMethod(toolMethod)
.build()
Or with the declarative approach:
class WeatherTools {
@Tool(description = "Get the weather in location")
public void getWeatherInLocation(String location, Unit unit) {
And you can use the same ChatClient#tools()
API to register method-based tool callbackes:
.prompt()
.tools(MethodToolCallback.builder()
.build())
.build())
.call()
.content();
.prompt()
.tools(new WeatherTools())
.call()
.content();
4. Options Configuration
Before:
.model(modelName)
.function("weatherFunction")
.build()
After:
.model(modelName)
.toolNames("weatherFunction")
.build()
5. Default Functions in ChatClient Builder
Before:
ChatClient.builder(chatModel)
.defaultFunctions(FunctionCallback.builder()
.build())
.build()
After:
.defaultTools(FunctionToolCallback.builder("getCurrentWeather", new MockWeatherService())
.build())
.build()
6. Spring Bean Configuration
Before:
public FunctionCallback weatherFunctionInfo() {
return FunctionCallback.builder()
.function("WeatherInfo", new MockWeatherService())
.description("Get the current weather")
After:
public ToolCallback weatherFunctionInfo() {
return FunctionToolCallback.builder("WeatherInfo", new MockWeatherService())
Breaking Changes
The
method()
configuration in function callbacks has been replaced with a more explicit method tool configuration usingToolDefinition
andMethodToolCallback
When using method-based callbacks, you now need to explicitly find the method using
ReflectionUtils
and provide it to the builder. Alternatively, you can use the declarative approach with the@Tool
annotation. -
For non-static methods, you must now provide both the method and the target object:
MethodToolCallback.builder() .toolDefinition(ToolDefinition.builder(toolMethod) .description("Description") .build()) .toolMethod(toolMethod) .toolObject(targetObject) .build()
Deprecated Methods
The following methods are deprecated and will be removed in a future release:
ChatClient.Builder.defaultFunctions(String…)
ChatClient.Builder.defaultFunctions(FunctionCallback…)
ChatClient.RequestSpec.functions()
Use their tools
counterparts instead.
Declarative Specification with @Tool
Now you can use the method-level annotation (@Tool
) to register tools with Spring AI:
class Home {
@Tool(description = "Turn light On or Off in a room.")
void turnLight(String roomName, boolean on) {
logger.info("Turn light in room: {} to: {}", roomName, on);
String response = ChatClient.create(this.chatModel).prompt()
.user("Turn the light in the living room On.")
.tools(new Home())
.call()
.content();
Additional Notes
The new API provides better separation between tool definition and implementation.
Tool definitions can be reused across different implementations.
The builder pattern has been simplified for common use cases.
Better support for method-based tools with improved error handling.
Timeline
The deprecated methods will be maintained for backward compatibility in the current milestone version but will be removed in the next milestone release. It’s recommended to migrate to the new API as soon as possible.
