This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT! |
ETL Pipeline
The Extract, Transform, and Load (ETL) framework serves as the backbone of data processing within the Retrieval Augmented Generation (RAG) use case.
The ETL pipeline orchestrates the flow from raw data sources to a structured vector store, ensuring data is in the optimal format for retrieval by the AI model.
The RAG use case is text to augment the capabilities of generative models by retrieving relevant information from a body of data to enhance the quality and relevance of the generated output.
API Overview
The ETL pipelines creates, transforms and stores Document
instances.
The Document
class contains text, metadata and optionally additionall media types like images, audio and video.
There are three main components of the ETL pipeline,
DocumentReader
that implementsSupplier<List<Document>>
DocumentTransformer
that implementsFunction<List<Document>, List<Document>>
DocumentWriter
that implementsConsumer<List<Document>>
The Document
class content is created from PDFs, text files and other document types with the help of DocumentReader
To construct a simple ETL pipeline, you can chain together an instance of each type.
Let’s say we have the following instances of those three ETL types
PagePdfDocumentReader
an implementation ofDocumentReader
TokenTextSplitter
an implementation ofDocumentTransformer
VectorStore
an implementation ofDocumentWriter
To perform the basic loading of data into a Vector Database for use with the Retrieval Augmented Generation pattern, use the following code in Java function style syntax.
vectorStore.accept(tokenTextSplitter.apply(pdfReader.get()));
Alternatively, you can use method names that are more naturally expressive for the domain
vectorStore.write(tokenTextSplitter.split(pdfReader.read()));
ETL Interfaces
The ETL pipeline is composed of the following interfaces and implementations. Detailed ETL class diagram is shown in the ETL Class Diagram section.
DocumentReader
Provides a source of documents from diverse origins.
public interface DocumentReader extends Supplier<List<Document>> {
default List<Document> read() {
return get();
DocumentTransformer
Transforms a batch of documents as part of the processing workflow.
public interface DocumentTransformer extends Function<List<Document>, List<Document>> {
default List<Document> transform(List<Document> transform) {
return apply(transform);
DocumentReaders
JSON
The JsonReader
processes JSON documents, converting them into a list of Document
objects.
Example
@Component
class MyJsonReader {
private final Resource resource;
MyJsonReader(@Value("classpath:bikes.json") Resource resource) {
this.resource = resource;
List<Document> loadJsonAsDocuments() {
JsonReader jsonReader = new JsonReader(this.resource, "description", "content");
return jsonReader.get();
Constructor Options
The JsonReader
provides several constructor options:
JsonReader(Resource resource)
JsonReader(Resource resource, String… jsonKeysToUse)
JsonReader(Resource resource, JsonMetadataGenerator jsonMetadataGenerator, String… jsonKeysToUse)
Parameters
resource
: A SpringResource
object pointing to the JSON file. -
jsonKeysToUse
: An array of keys from the JSON that should be used as the text content in the resultingDocument
objects. -
: An optionalJsonMetadataGenerator
to create metadata for eachDocument
Behavior
The JsonReader
processes JSON content as follows:
It can handle both JSON arrays and single JSON objects.
For each JSON object (either in an array or a single object):
It extracts the content based on the specified
jsonKeysToUse
If no keys are specified, it uses the entire JSON object as content.
It generates metadata using the provided
(or an empty one if not provided). -
It creates a
Document
object with the extracted content and metadata.
Using JSON Pointers
The JsonReader
now supports retrieving specific parts of a JSON document using JSON Pointers. This feature allows you to easily extract nested data from complex JSON structures.
The get(String pointer)
method
public List<Document> get(String pointer)
This method allows you to use a JSON Pointer to retrieve a specific part of the JSON document.
Parameters
pointer
: A JSON Pointer string (as defined in RFC 6901) to locate the desired element within the JSON structure.
Return Value
Returns a
List<Document>
containing the documents parsed from the JSON element located by the pointer.
Behavior
The method uses the provided JSON Pointer to navigate to a specific location in the JSON structure.
If the pointer is valid and points to an existing element:
For a JSON object: it returns a list with a single Document.
For a JSON array: it returns a list of Documents, one for each element in the array.
If the pointer is invalid or points to a non-existent element, it throws an
IllegalArgumentException
Example JSON Structure
"id": 1,
"brand": "Trek",
"description": "A high-performance mountain bike for trail riding."
"id": 2,
"brand": "Cannondale",
"description": "An aerodynamic road bike for racing enthusiasts."
In this example, if the JsonReader
is configured with "description"
as the jsonKeysToUse
, it will create Document
objects where the content is the value of the "description" field for each bike in the array.
Notes
The
JsonReader
uses Jackson for JSON parsing. -
It can handle large JSON files efficiently by using streaming for arrays.
If multiple keys are specified in
jsonKeysToUse
, the content will be a concatenation of the values for those keys. -
The reader is flexible and can be adapted to various JSON structures by customizing the
jsonKeysToUse
andJsonMetadataGenerator
Text
The TextReader
processes plain text documents, converting them into a list of Document
objects.
Example
@Component
class MyTextReader {
MyTextReader(@Value("classpath:text-source.txt") Resource resource) {
List<Document> loadText() {
TextReader textReader = new TextReader(this.resource);
textReader.getCustomMetadata().put("filename", "text-source.txt");
return textReader.read();
Constructor Options
The TextReader
provides two constructor options:
TextReader(String resourceUrl)
TextReader(Resource resource)
Parameters
resourceUrl
: A string representing the URL of the resource to be read. -
resource
: A SpringResource
object pointing to the text file.
Configuration
setCharset(Charset charset)
: Sets the character set used for reading the text file. Default is UTF-8. -
getCustomMetadata()
: Returns a mutable map where you can add custom metadata for the documents.
Behavior
The TextReader
processes text content as follows:
It reads the entire content of the text file into a single
Document
object. -
The content of the file becomes the content of the
Document
Metadata is automatically added to the
Document
charset
: The character set used to read the file (default: "UTF-8"). -
source
: The filename of the source text file.
Any custom metadata added via
getCustomMetadata()
is included in theDocument
Notes
The
TextReader
reads the entire file content into memory, so it may not be suitable for very large files. -
If you need to split the text into smaller chunks, you can use a text splitter like
TokenTextSplitter
after reading the document:
List<Document> documents = textReader.get();
List<Document> splitDocuments = new TokenTextSplitter().apply(this.documents);
The reader uses Spring’s
Resource
abstraction, allowing it to read from various sources (classpath, file system, URL, etc.). -
Custom metadata can be added to all documents created by the reader using the
getCustomMetadata()
method.
Markdown
The MarkdownDocumentReader
processes Markdown documents, converting them into a list of Document
objects.
Example
@Component
class MyMarkdownReader {
MyMarkdownReader(@Value("classpath:code.md") Resource resource) {
List<Document> loadMarkdown() {
MarkdownDocumentReaderConfig config = MarkdownDocumentReaderConfig.builder()
.withHorizontalRuleCreateDocument(true)
.withIncludeCodeBlock(false)
.withIncludeBlockquote(false)
.withAdditionalMetadata("filename", "code.md")
MarkdownDocumentReader reader = new MarkdownDocumentReader(this.resource, config);
return reader.get();
The MarkdownDocumentReaderConfig
allows you to customize the behavior of the MarkdownDocumentReader:
horizontalRuleCreateDocument
: When set totrue
, horizontal rules in the Markdown will create newDocument
objects. -
includeCodeBlock
: When set totrue
, code blocks will be included in the sameDocument
as the surrounding text. Whenfalse
, code blocks create separateDocument
objects. -
includeBlockquote
: When set totrue
, blockquotes will be included in the sameDocument
, blockquotes create separateDocument
objects. -
additionalMetadata
: Allows you to add custom metadata to all createdDocument
objects.
Sample Document: code.md
This is a Java sample application:
```java
package com.example.demo;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
@SpringBootApplication
public class DemoApplication {
SpringApplication.run(DemoApplication.class, args);
Markdown also provides the possibility to `use inline code formatting throughout` the entire sentence.
Another possibility is to set block code without specific highlighting:
./mvnw spring-javaformat:apply
Behavior: The MarkdownDocumentReader processes the Markdown content and creates Document objects based on the configuration:
Headers become metadata in the Document objects.
Paragraphs become the content of Document objects.
Code blocks can be separated into their own Document objects or included with surrounding text.
Blockquotes can be separated into their own Document objects or included with surrounding text.
Horizontal rules can be used to split the content into separate Document objects.
The reader preserves formatting like inline code, lists, and text styling within the content of the Document objects.
PDF Page
The PagePdfDocumentReader
uses Apache PdfBox library to parse PDF documents
Add the dependency to your project using Maven or Gradle.
<dependency>
<artifactId>spring-ai-pdf-document-reader</artifactId>
</dependency>
or to your Gradle build.gradle
build file.
dependencies {
implementation 'org.springframework.ai:spring-ai-pdf-document-reader'
Example
@Component
public class MyPagePdfDocumentReader {
List<Document> getDocsFromPdf() {
PagePdfDocumentReader pdfReader = new PagePdfDocumentReader("classpath:/sample1.pdf",
PdfDocumentReaderConfig.builder()
.withPageTopMargin(0)
.withPageExtractedTextFormatter(ExtractedTextFormatter.builder()
.withNumberOfTopTextLinesToDelete(0)
.build())
.withPagesPerDocument(1)
.build());
return pdfReader.read();
PDF Paragraph
The ParagraphPdfDocumentReader
uses the PDF catalog (e.g. TOC) information to split the input PDF into text paragraphs and output a single Document
per paragraph.
NOTE: Not all PDF documents contain the PDF catalog.
Dependencies
<dependency>
</dependency>
build file.
dependencies {
Example
@Component
List<Document> getDocsFromPdfWithCatalog() {
ParagraphPdfDocumentReader pdfReader = new ParagraphPdfDocumentReader("classpath:/sample1.pdf",
.build())
.build());
Tika (DOCX, PPTX, HTML…)
The TikaDocumentReader
uses Apache Tika to extract text from a variety of document formats, such as PDF, DOC/DOCX, PPT/PPTX, and HTML. For a comprehensive list of supported formats, refer to the Tika documentation.
Dependencies
<dependency>
<artifactId>spring-ai-tika-document-reader</artifactId>
</dependency>
build file.
dependencies {
implementation 'org.springframework.ai:spring-ai-tika-document-reader'
Example
@Component
class MyTikaDocumentReader {
MyTikaDocumentReader(@Value("classpath:/word-sample.docx")
TikaDocumentReader tikaDocumentReader = new TikaDocumentReader(this.resource);
return tikaDocumentReader.read();
Transformers
TextSplitter
The TextSplitter
an abstract base class that helps divides documents to fit the AI model’s context window.
TokenTextSplitter
The TokenTextSplitter
is an implementation of TextSplitter
that splits text into chunks based on token count, using the CL100K_BASE encoding.
Usage
@Component
class MyTokenTextSplitter {
public List<Document> splitDocuments(List<Document> documents) {
TokenTextSplitter splitter = new TokenTextSplitter();
return splitter.apply(documents);
public List<Document> splitCustomized(List<Document> documents) {
TokenTextSplitter splitter = new TokenTextSplitter(1000, 400, 10, 5000, true);
Constructor Options
TokenTextSplitter()
: Creates a splitter with default settings. -
TokenTextSplitter(int defaultChunkSize, int minChunkSizeChars, int minChunkLengthToEmbed, int maxNumChunks, boolean keepSeparator)
Parameters
defaultChunkSize
: The target size of each text chunk in tokens (default: 800). -
minChunkSizeChars
: The minimum size of each text chunk in characters (default: 350). -
: The minimum length of a chunk to be included (default: 5). -
maxNumChunks
: The maximum number of chunks to generate from a text (default: 10000). -
keepSeparator
: Whether to keep separators (like newlines) in the chunks (default: true).
Behavior
It encodes the input text into tokens using the CL100K_BASE encoding.
It splits the encoded text into chunks based on the
defaultChunkSize
For each chunk:
It decodes the chunk back into text.
It attempts to find a suitable break point (period, question mark, exclamation mark, or newline) after the
minChunkSizeChars
If a break point is found, it truncates the chunk at that point.
It trims the chunk and optionally removes newline characters based on the
keepSeparator
setting. -
If the resulting chunk is longer than
, it’s added to the output.
This process continues until all tokens are processed or
maxNumChunks
is reached. -
Any remaining text is added as a final chunk if it’s longer than
Example
Document doc1 = new Document("This is a long piece of text that needs to be split into smaller chunks for processing.",
Map.of("source", "example.txt"));
Document doc2 = new Document("Another document with content that will be split based on token count.",
Map.of("source", "example2.txt"));
List<Document> splitDocuments = this.splitter.apply(List.of(this.doc1, this.doc2));
for (Document doc : splitDocuments) {
System.out.println("Chunk: " + doc.getContent());
System.out.println("Metadata: " + doc.getMetadata());
Notes
The
TokenTextSplitter
uses the CL100K_BASE encoding from thejtokkit
library, which is compatible with newer OpenAI models. -
The splitter attempts to create semantically meaningful chunks by breaking at sentence boundaries where possible.
Metadata from the original documents is preserved and copied to all chunks derived from that document.
The content formatter (if set) from the original document is also copied to the derived chunks if
copyContentFormatter
is set totrue
(default behavior). -
This splitter is particularly useful for preparing text for large language models that have token limits, ensuring that each chunk is within the model’s processing capacity.
KeywordMetadataEnricher
The KeywordMetadataEnricher
is a DocumentTransformer
that uses a generative AI model to extract keywords from document content and add them as metadata.
Usage
@Component
class MyKeywordEnricher {
private final ChatModel chatModel;
MyKeywordEnricher(ChatModel chatModel) {
this.chatModel = chatModel;
List<Document> enrichDocuments(List<Document> documents) {
KeywordMetadataEnricher enricher = new KeywordMetadataEnricher(this.chatModel, 5);
return enricher.apply(documents);
Constructor
constructor takes two parameters:
ChatModel chatModel
: The AI model used for generating keywords. -
int keywordCount
: The number of keywords to extract for each document.
Behavior
processes documents as follows:
For each input document, it creates a prompt using the document’s content.
It sends this prompt to the provided
ChatModel
to generate keywords. -
The generated keywords are added to the document’s metadata under the key "excerpt_keywords".
The enriched documents are returned.
Customization
The keyword extraction prompt can be customized by modifying the KEYWORDS_TEMPLATE
constant in the class. The default template is:
\{context_str}. Give %s unique keywords for this document. Format as comma separated. Keywords:
Where {context_str}
is replaced with the document content, and %s
is replaced with the specified keyword count.
Example
ChatModel chatModel = // initialize your chat model
KeywordMetadataEnricher enricher = new KeywordMetadataEnricher(chatModel, 5);
Document doc = new Document("This is a document about artificial intelligence and its applications in modern technology.");
List<Document> enrichedDocs = enricher.apply(List.of(this.doc));
Document enrichedDoc = this.enrichedDocs.get(0);
String keywords = (String) this.enrichedDoc.getMetadata().get("excerpt_keywords");
System.out.println("Extracted keywords: " + keywords);
Notes
The
requires a functioningChatModel
The keyword count must be 1 or greater.
The enricher adds the "excerpt_keywords" metadata field to each processed document.
The generated keywords are returned as a comma-separated string.
This enricher is particularly useful for improving document searchability and for generating tags or categories for documents.
SummaryMetadataEnricher
The SummaryMetadataEnricher
that uses a generative AI model to create summaries for documents and add them as metadata. It can generate summaries for the current document, as well as adjacent documents (previous and next).
Usage
class EnricherConfig {
public SummaryMetadataEnricher summaryMetadata(OpenAiChatModel aiClient) {
return new SummaryMetadataEnricher(aiClient,
List.of(SummaryType.PREVIOUS, SummaryType.CURRENT, SummaryType.NEXT));
@Component
class MySummaryEnricher {
private final SummaryMetadataEnricher enricher;
MySummaryEnricher(SummaryMetadataEnricher enricher) {
this.enricher = enricher;
return this.enricher.apply(documents);
Constructor
provides two constructors:
SummaryMetadataEnricher(ChatModel chatModel, List<SummaryType> summaryTypes)
SummaryMetadataEnricher(ChatModel chatModel, List<SummaryType> summaryTypes, String summaryTemplate, MetadataMode metadataMode)
Parameters
chatModel
: The AI model used for generating summaries. -
summaryTypes
: A list ofSummaryType
enum values indicating which summaries to generate (PREVIOUS, CURRENT, NEXT). -
summaryTemplate
: A custom template for summary generation (optional). -
metadataMode
: Specifies how to handle document metadata when generating summaries (optional).
Behavior
For each input document, it creates a prompt using the document’s content and the specified summary template.
ChatModel
to generate a summary. -
Depending on the specified
summaryTypes
, it adds the following metadata to each document:-
section_summary
: Summary of the current document. -
prev_section_summary
: Summary of the previous document (if available and requested). -
next_section_summary
: Summary of the next document (if available and requested).
Customization
The summary generation prompt can be customized by providing a custom summaryTemplate
Here is the content of the section:
{context_str}
Summarize the key topics and entities of the section.
Summary:
Example
SummaryMetadataEnricher enricher = new SummaryMetadataEnricher(chatModel,
Document doc1 = new Document("Content of document 1");
Document doc2 = new Document("Content of document 2");
List<Document> enrichedDocs = enricher.apply(List.of(this.doc1, this.doc2));
// Check the metadata of the enriched documents
for (Document doc : enrichedDocs) {
System.out.println("Current summary: " + doc.getMetadata().get("section_summary"));
System.out.println("Previous summary: " + doc.getMetadata().get("prev_section_summary"));
System.out.println("Next summary: " + doc.getMetadata().get("next_section_summary"));
The provided example demonstrates the expected behavior:
For a list of two documents, both documents receive a
section_summary
The first document receives a
but noprev_section_summary
The second document receives a
but nonext_section_summary
The
section_summary
of the first document matches theprev_section_summary
of the second document. -
The
of the first document matches thesection_summary
Notes
The
to generate summaries. -
The enricher can handle document lists of any size, properly handling edge cases for the first and last documents.
This enricher is particularly useful for creating context-aware summaries, allowing for better understanding of document relationships in a sequence.
The
MetadataMode
parameter allows control over how existing metadata is incorporated into the summary generation process.
Writers
File
The FileDocumentWriter
is a DocumentWriter
implementation that writes the content of a list of Document
objects into a file.
Usage
@Component
class MyDocumentWriter {
public void writeDocuments(List<Document> documents) {
FileDocumentWriter writer = new FileDocumentWriter("output.txt", true, MetadataMode.ALL, false);
writer.accept(documents);
Constructors
provides three constructors:
FileDocumentWriter(String fileName)
FileDocumentWriter(String fileName, boolean withDocumentMarkers)
FileDocumentWriter(String fileName, boolean withDocumentMarkers, MetadataMode metadataMode, boolean append)
Parameters
fileName
: The name of the file to write the documents to. -
withDocumentMarkers
: Whether to include document markers in the output (default: false). -
metadataMode
: Specifies what document content to be written to the file (default: MetadataMode.NONE). -
append
: If true, data will be written to the end of the file rather than the beginning (default: false).
Behavior
It opens a FileWriter for the specified file name.
For each document in the input list:
If
withDocumentMarkers
is true, it writes a document marker including the document index and page numbers. -
It writes the formatted content of the document based on the specified
metadataMode
The file is closed after all documents have been written.
Document Markers
When withDocumentMarkers
is set to true, the writer includes markers for each document in the following format:
### Doc: [index], pages:[start_page_number,end_page_number]
Metadata Handling
The writer uses two specific metadata keys:
page_number
: Represents the starting page number of the document. -
end_page_number
: Represents the ending page number of the document.
These are used when writing document markers.
Example
List<Document> documents = // initialize your documents
FileDocumentWriter writer = new FileDocumentWriter("output.txt", true, MetadataMode.ALL, true);
This will write all documents to "output.txt", including document markers, using all available metadata, and appending to the file if it already exists.
Notes
The writer uses
FileWriter
, so it writes text files with the default character encoding of the operating system. -
If an error occurs during writing, a
RuntimeException
is thrown with the original exception as its cause. -
The
metadataMode
parameter allows control over how existing metadata is incorporated into the written content. -
This writer is particularly useful for debugging or creating human-readable outputs of document collections.
VectorStore
Provides integration with various vector stores. See Vector DB Documentation for a full listing.
