This version is still in development and is not considered stable yet. For the latest snapshot version, please use Spring AI 1.0.0-SNAPSHOT!spring-doc.cn
OpenAI Text-to-Speech (TTS)
Introduction
The Audio API provides a speech endpoint based on OpenAI’s TTS (text-to-speech) model, enabling users to:spring-doc.cn
Prerequisites
  1. Create an OpenAI account and obtain an API key. You can sign up at the OpenAI signup page and generate an API key on the API Keys page.spring-doc.cn
  2. Add the spring-ai-openai dependency to your project’s build file. For more information, refer to the Dependency Management section.spring-doc.cn
Auto-configuration
Spring AI provides Spring Boot auto-configuration for the OpenAI Text-to-Speech Client. To enable it add the following dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-openai-spring-boot-starter</artifactId>
</dependency>
or to your Gradle build.gradle build file:spring-doc.cn
dependencies {
    implementation 'org.springframework.ai:spring-ai-openai-spring-boot-starter'
Refer to the Dependency Management section to add the Spring AI BOM to your build file.
Speech Properties
Connection Properties
The prefix spring.ai.openai is used as the property prefix that lets you connect to OpenAI.spring-doc.cn
Propertyspring-doc.cn
Descriptionspring-doc.cn
Defaultspring-doc.cn
spring.ai.openai.base-urlspring-doc.cn
The URL to connect tospring-doc.cn
api.openai.comspring-doc.cn
spring.ai.openai.api-keyspring-doc.cn
The API Keyspring-doc.cn
-spring-doc.cn
spring.ai.openai.organization-idspring-doc.cn
Optionally you can specify which organization used for an API request.spring-doc.cn
-spring-doc.cn
spring.ai.openai.project-idspring-doc.cn
Optionally, you can specify which project is used for an API request.spring-doc.cn
-spring-doc.cn
For users that belong to multiple organizations (or are accessing their projects through their legacy user API key), optionally, you can specify which organization and project is used for an API request. Usage from these API requests will count as usage for the specified organization and project.
Configuration Properties
The prefix spring.ai.openai.audio.speech is used as the property prefix that lets you configure the OpenAI Text-to-Speech client.spring-doc.cn
Property Description Default
spring.ai.openai.audio.speech.base-urlspring-doc.cn
spring.ai.openai.audio.speech.api-keyspring-doc.cn
-spring-doc.cn
spring.ai.openai.audio.speech.organization-idspring-doc.cn
-spring-doc.cn
spring.ai.openai.audio.speech.project-idspring-doc.cn
-spring-doc.cn
spring.ai.openai.audio.speech.options.modelspring-doc.cn
ID of the model to use. Only tts-1 is currently available.spring-doc.cn
tts-1spring-doc.cn
spring.ai.openai.audio.speech.options.voicespring-doc.cn
The voice to use for the TTS output. Available options are: alloy, echo, fable, onyx, nova, and shimmer.spring-doc.cn
alloyspring-doc.cn
spring.ai.openai.audio.speech.options.response-formatspring-doc.cn
The format of the audio output. Supported formats are mp3, opus, aac, flac, wav, and pcm.spring-doc.cn
mp3spring-doc.cn
spring.ai.openai.audio.speech.options.speedspring-doc.cn
The speed of the voice synthesis. The acceptable range is from 0.25 (slowest) to 4.0 (fastest).spring-doc.cn
1.0spring-doc.cn
You can override the common spring.ai.openai.base-url, spring.ai.openai.api-key, spring.ai.openai.organization-id and spring.ai.openai.project-id properties. The spring.ai.openai.audio.speech.base-url, spring.ai.openai.audio.speech.api-key, spring.ai.openai.audio.speech.organization-id and spring.ai.openai.audio.speech.project-id properties if set take precedence over the common properties. This is useful if you want to use different OpenAI accounts for different models and different model endpoints.
All properties prefixed with spring.ai.openai.image.options can be overridden at runtime.
Runtime Options
The OpenAiAudioSpeechOptions class provides the options to use when making a text-to-speech request. On start-up, the options specified by spring.ai.openai.audio.speech are used but you can override these at runtime.spring-doc.cn
For example:spring-doc.cn
OpenAiAudioSpeechOptions speechOptions = OpenAiAudioSpeechOptions.builder()
    .model("tts-1")
    .voice(OpenAiAudioApi.SpeechRequest.Voice.ALLOY)
    .responseFormat(OpenAiAudioApi.SpeechRequest.AudioResponseFormat.MP3)
    .speed(1.0f)
SpeechPrompt speechPrompt = new SpeechPrompt("Hello, this is a text-to-speech example.", this.speechOptions);
SpeechResponse response = openAiAudioSpeechModel.call(this.speechPrompt);
Manual Configuration
Add the spring-ai-openai dependency to your project’s Maven pom.xml file:spring-doc.cn
<dependency>
    <artifactId>spring-ai-openai</artifactId>
</dependency>
dependencies {
    implementation 'org.springframework.ai:spring-ai-openai'
Next, create an OpenAiAudioSpeechModel:spring-doc.cn
var openAiAudioApi = new OpenAiAudioApi(System.getenv("OPENAI_API_KEY"));
var openAiAudioSpeechModel = new OpenAiAudioSpeechModel(this.openAiAudioApi);
var speechOptions = OpenAiAudioSpeechOptions.builder()
    .speed(1.0f)
    .model(OpenAiAudioApi.TtsModel.TTS_1.value)
var speechPrompt = new SpeechPrompt("Hello, this is a text-to-speech example.", this.speechOptions);
SpeechResponse response = this.openAiAudioSpeechModel.call(this.speechPrompt);
// Accessing metadata (rate limit info)
OpenAiAudioSpeechResponseMetadata metadata = this.response.getMetadata();
byte[] responseAsBytes = this.response.getResult().getOutput();
Streaming Real-time Audio
The Speech API provides support for real-time audio streaming using chunk transfer encoding. This means that the audio is able to be played before the full file has been generated and made accessible.spring-doc.cn
    .speed(1.0f)
SpeechPrompt speechPrompt = new SpeechPrompt("Today is a wonderful day to build something people love!", this.speechOptions);
Flux<SpeechResponse> responseStream = this.openAiAudioSpeechModel.stream(this.speechPrompt);
Example Code
